vigilian 1 Posted January 1, 2017 Posted January 1, 2017 error in opening the video on chrome (remux) last chrome version and yandex doesn't appear with emby on ios apparently the coding of the video is in itunes but let's see the logs for that. joneses.txt
Luke 42244 Posted January 1, 2017 Posted January 1, 2017 Hi @@vigilian, can you provide a sample video for testing? thanks !
vigilian 1 Posted January 3, 2017 Author Posted January 3, 2017 can't I just give you access to my server? it would simpler for me than taking time for all this since I'm working...?
vigilian 1 Posted January 5, 2017 Author Posted January 5, 2017 I've sent you the credentials but it just hits me, if you are gonna play, it will automatically transcode the thing so you won't see any problem since it is within direct playback where is the problem. I will try in a couple of hours to make a sample of the beginning of the movie file since it is from the beginning of the playback it gives the error. but here for example it's another usecase where my feature request would it be interesting! : https://emby.media/community/index.php?/topic/43224-feature-requested/ to avoid been annoyed by this problem.
vigilian 1 Posted January 5, 2017 Author Posted January 5, 2017 here is the sample. So i don't know if it will be enough. I follow the tutorial anyway. I hope that the error will be visible on these sample, I didn't try it. hundredfootsample.7z keepingupsample.7z
Luke 42244 Posted January 5, 2017 Posted January 5, 2017 @@vigilian, in chrome these samples both played perfectly.
vigilian 1 Posted January 6, 2017 Author Posted January 6, 2017 (edited) @@Luke then what should I do? it's a docker container, so untouched by definition. maybe you can even see it with your admin credentials that I gave you. Edited January 6, 2017 by vigilian
vigilian 1 Posted January 6, 2017 Author Posted January 6, 2017 I've shown you the log and you can well see that there is a problem so tell me what should I do.
