alltester 0 Posted January 1, 2017 Posted January 1, 2017 Hi Everyone, I'd like to report what seems to be a glitch/bug. I've been trying to set up the camera upload section for our mobile devices and everything was going great until I tried to set a custom path for each of the devices. According to the Camera Upload WIKI, there should be a place in the Devices section that allows me specify a path for the camera upload for each of the devices, but that option does not exist. I've attached screenshots to show what my server is displaying, I can set the base path under Sync -> Camera Upload, but the device itself under the device settings does not have an option for a specific path. I am currently running version 3.1.2.0 on Windows 8.1, and my mobile devices are running Android 6 and 7 In order to make my setup work for the moment, I edited the device.json file for the devices that have the feature enabled and changed the following line: From: "CameraUploadPath":"" To: "CameraUploadPath":"Drive:/Folder/Device1" After making the changes to the files and restarting the service, I re-checked the device in the Devices tab and all I see still is the name change option and nothing else. Camera upload is working fine so far, but there is no way to edit the specific path as described in the WIKI through the server interface nor the android app.
Luke 42197 Posted January 2, 2017 Posted January 2, 2017 Hi @@alltester, thanks for the report. We'll resolve this for the next release, thanks !
Fallen Archangel 0 Posted January 8, 2017 Posted January 8, 2017 I've noticed this as well. They go to the default location of %appdata%\Emby\data\camerauploads\devicenameI just symlinked this folder to my external drive where I store everything. (Actually I have the entire Emby folder symlinked in order to keep it off my SSD)
Luke 42197 Posted January 8, 2017 Posted January 8, 2017 Hi @@Fallen Archangel, thanks for the report. We'll resolve this for the next release, thanks !
moosedookie 1 Posted January 31, 2017 Posted January 31, 2017 Hello, I was just looking for an update on this issue. It doesn't appear to be resolved in the latest update, v3.1.5
Luke 42197 Posted January 31, 2017 Posted January 31, 2017 @@moosedookie, If i click on devices, then click on an android mobile device, the camera upload path is there for me to customize. 1
moosedookie 1 Posted January 31, 2017 Posted January 31, 2017 (edited) @@Luke, Hmm, that's strange. I do not have the option. See screenshots attached.Not sure what is going on... Any ideas? Edited January 31, 2017 by moosedookie
Luke 42197 Posted February 1, 2017 Posted February 1, 2017 Make sure you're running the latest version of the app. Once you've done that, log into the app again, then check in the server dashboard.
moosedookie 1 Posted February 1, 2017 Posted February 1, 2017 Make sure you're running the latest version of the app. Once you've done that, log into the app again, then check in the server dashboard. @@Luke, It's the craziest thing... Just got home from work and tried it again and now it works. I can now see the camera upload path. Not sure what that was all about but it's working. Thanks for the help.
