climbingmike 0 Posted January 28, 2014 Posted January 28, 2014 Hello Every one I have recently upgraded to the new Media Browser Server and Client on my Window 8.1 Media PC. I have used Media Browser for a while now and it used to load my local Blu Ray folders though Total Media 6 Blu Ray software. Now with the new version of MB3 it seems to load the Blu Ray nativity with MB3 and just plays the main film without the menu's. This would be an issue, but it randomly picks the audio track so some time I get English, German or maybe the audio for the blind and I can not select the audio from with in Media Center/MB3. Is there a way to tell MB3 to use Total Media 6 when a Blu Ray folder is selected? Many thanks MIke
ebr 16332 Posted January 29, 2014 Posted January 29, 2014 Did you re-configure your external player with the Configurator? If using TMT6 you should probably just use the generic player profile.
climbingmike 0 Posted January 29, 2014 Author Posted January 29, 2014 Thank you for the info, that works great
