mediacowboy 438 Posted February 5, 2017 Author Posted February 5, 2017 No because there is no openings for the hose.
mediacowboy 438 Posted February 6, 2017 Author Posted February 6, 2017 (edited) Okay so I think I have a solution for airflow now. I flip the radiator 180 degrees to all more airflow over the motherboard. I also plan on buying a much shorter PCIe extension cable made of ribbon cable instead of the metal like I bought. http://www.newegg.com/Product/Product.aspx?Item=12-183-015 It is only 200 mm instead of 500 mm. The 500 mm stretch longer then the case so this should help and will also be more flexible. Edited February 6, 2017 by mediacowboy
naeonline 27 Posted February 8, 2017 Posted February 8, 2017 @@mediacowboy That case is a Silverstone DS380B, right? I read up on the newegg reviews and it's either explained in one of those or there is a link in one of the review to discussion on how to get the airflow to work so your drives won't overheat and die. It seems the default airflow configuration for that case sucks regarding the drive cage. The best fix was drilling some holes in the back metal section of the drive cage (back meaning the side where port connections are) and then fitting a piece of cardboard between the drive cage and the side of the case so that the 2 side case fans can blow directly into the drive cage. This would mean you need to move your raid card mount, however.I almost pulled the trigger on this case and a new setup until I realized my current power supply had multiple 12v rails instead of a single one and a simple wiring reconfig saved me from $1k new setup and hours of recovering drive data.Oh, also there are some issues if you went with a Silverstone SFX power supply with it not supplying enough amps for powering 8 drives in that case. What PSU did you get?
Guest asrequested Posted February 9, 2017 Posted February 9, 2017 Okay so I think I have a solution for airflow now. I flip the radiator 180 degrees to all more airflow over the motherboard. I also plan on buying a much shorter PCIe extension cable made of ribbon cable instead of the metal like I bought. http://www.newegg.com/Product/Product.aspx?Item=12-183-015 It is only 200 mm instead of 500 mm. The 500 mm stretch longer then the case so this should help and will also be more flexible. I'm really interested to see how this comes out 1
mediacowboy 438 Posted February 9, 2017 Author Posted February 9, 2017 I'm really interested to see how this comes outThanks I'm hoping I can finish buying everything but storage this Friday and get it booted.
mediacowboy 438 Posted February 25, 2017 Author Posted February 25, 2017 Well it's been awhile in the making but hopefully this time next week the new server will be put together with the expectation of the storage drives. I really can't wait to get this up and running. I also bought some heat shrink to try and help with cable management. I will post more pictures and stuff once everything is installed.
mediacowboy 438 Posted March 2, 2017 Author Posted March 2, 2017 Its my Friday at work. Can anyone guess what I'm doing this weekend?
CBers 7554 Posted March 2, 2017 Posted March 2, 2017 Its my Friday at work. Can anyone guess what I'm doing this weekend? Paintball? 1
mediacowboy 438 Posted March 2, 2017 Author Posted March 2, 2017 Paintball?Nope but it isn't bad weather here to got to a gun range. 1
Guest asrequested Posted March 2, 2017 Posted March 2, 2017 Its my Friday at work. Can anyone guess what I'm doing this weekend? Nice! What's in the bag?
mediacowboy 438 Posted March 2, 2017 Author Posted March 2, 2017 Nice! What's in the bag?100 mm PCIe extension
Guest asrequested Posted March 2, 2017 Posted March 2, 2017 100 mm PCIe extension Ah! I guess you'll be needing that. Do You have any drives, yet? One of my customers has 10 external hard drives, ranging from 750MB to 4GB. He's moving all his files onto a different system, and he said he'll give me all the old drives. We'll see if he actually does, but I think I'll get a few of them, at least. Does your MotherBoard have any M.2 ports?
mediacowboy 438 Posted March 2, 2017 Author Posted March 2, 2017 (edited) I don't have the drives I want but I am thinking for now remove my drives from the current system and put them in the new one to free up my current rig for gaming. I want Seagate Ironwolf 8tb and need atleast four of them. Edited March 2, 2017 by mediacowboy
Guest asrequested Posted March 3, 2017 Posted March 3, 2017 I don't have the drives I want but I am thinking for now remove my drives from the current system and put them in the new one to free up my current rig for gaming. I want Seagate Ironwolf 8tb and need atleast four of them. That sounds like a good plan, that's what I would do.
mediacowboy 438 Posted March 3, 2017 Author Posted March 3, 2017 Ah! I guess you'll be needing that. Do You have any drives, yet? One of my customers has 10 external hard drives, ranging from 750MB to 4GB. He's moving all his files onto a different system, and he said he'll give me all the old drives. We'll see if he actually does, but I think I'll get a few of them, at least. Does your MotherBoard have any M.2 ports?This is the motherboard I have. http://www.newegg.com/Product/Product.aspx?Item=13-157-669 It looks like it does m2 but I didn't know if I would have room for that or not so I didn't get one. Future upgrade possibly. Room is already pretty tight without everything in it yet.
Guest asrequested Posted March 3, 2017 Posted March 3, 2017 This is the motherboard I have. http://www.newegg.com/Product/Product.aspx?Item=13-157-669 It looks like it does m2 but I didn't know if I would have room for that or not so I didn't get one. Future upgrade possibly. Room is already pretty tight without everything in it yet. Ah! It's vertical, pity.
CBers 7554 Posted March 3, 2017 Posted March 3, 2017 M.2 ports? What are they for? I want Seagate Ironwolf 8tb and need atleast four of them. Are Seagate discs better than they used to be? I've always stayed away from them. How much are the 8Tb's?
PenkethBoy 2068 Posted March 3, 2017 Posted March 3, 2017 M.2 - either m.2 sata SSD's drives or NVME SSD's About the same - Ironwolf is a marketing change, the disks are still the same as the previous models So have i after getting 8 of 12 have issues or die - however have 3 of the 8TB archive drives now and they appear to be ok The archive disks cost ~£235 each from Overclockers.co.uk or Scan.co.uk at ~£250 Normal 8TB will be £300+
mediacowboy 438 Posted March 3, 2017 Author Posted March 3, 2017 What are they for? Are Seagate discs better than they used to be? I've always stayed away from them. How much are the 8Tb's? I've had more issues with WD. Here in the US it is 300 and up for a 8tb.
mediacowboy 438 Posted March 8, 2017 Author Posted March 8, 2017 SHE IS ALIVE. As you can see cable management went from great to crap. She is alive and installing windows 10 now. Once windows 10 is installed I plan to test each hot swap bay and maybe this weekend shut it down and swap media drives over. 1
Guest asrequested Posted March 8, 2017 Posted March 8, 2017 Awesome! You'll have plenty of time to tidy things up, if you want to. All your work is paying off 1
mediacowboy 438 Posted March 8, 2017 Author Posted March 8, 2017 (edited) Work and funds. [emoji2] There really isn't much more I can do with the PCIe cable in the way. I just need new media drives and I will be set. Plus install all the software and set it up. I've installed Google and a AntiVirus. Can you guess what in installing now? Edited March 8, 2017 by mediacowboy
Guest asrequested Posted March 8, 2017 Posted March 8, 2017 I have no patience, I'd have to get it all done in one shot, lol...I doff my hat to you
mediacowboy 438 Posted March 8, 2017 Author Posted March 8, 2017 I have no patience, I'd have to get it all done in one shot, lol...I doff my hat to youIt's been hard but funds and family (Wife and 3 Kids) make my hobby life slim.
