mediacowboy 438 Posted May 15, 2017 Author Posted May 15, 2017 More than 60°C: Is too hot 40°C to 55°C: Acceptable 25°C to 40°C: Ideal Less than 25°C: Too cold You never get good cool out that case design and fact are hot swap are poor at air flow any way I try flopping the 2 side fans around from blow in to out and same with rear fan see if lower the temp any That is what I was thinking. Would Yall agree motherboard controlling the fans might help? Sent from my SM-G955U using Tapatalk
CBers 7554 Posted May 15, 2017 Posted May 15, 2017 That is what I was thinking. Would Yall agree motherboard controlling the fans might help? Yes. What MB is it, as for my Gigabyte MB, they have a suite of utilities that includes fan speed management. Alternately, try SPEEDFAN.
SHSPVR 125 Posted May 15, 2017 Posted May 15, 2017 That is what I was thinking. Would Yall agree motherboard controlling the fans might help? Sent from my SM-G955U using Tapatalk Are ref to PWM fans ? You just need get some kind of static pressure, therefore a reduced CFM of airflow on one or more fans depend on setup. If all fans have same CFM rating the one or two with the a higher static pressure rating or high rpm is needed will pull flow more air draw a cross the parts which should lower temps.
Guest asrequested Posted May 16, 2017 Posted May 16, 2017 (edited) Using the motherboard heat sensors won't help much. They monitor the ambient temperature. The drives will be hotter. Unless you can adjust the threshold to mimic the drive temps. My fan controller thermal probe is right nest to my hottest drive, and it's still off by 2-3C. I had to run tests to dial it in, to where I wanted it. With your fan placement, you need to get as much static pressure air flow being pull through the drive bays, as you can. So if you have open vents, the fans will just pull air through those, instead of the drive bays. You need to get air moving through the drives, any way you can. How big is the rear fan? Edited May 16, 2017 by Doofus
mediacowboy 438 Posted May 16, 2017 Author Posted May 16, 2017 All three are 120 mm. Sent from my SM-G955U using Tapatalk
Guest asrequested Posted May 16, 2017 Posted May 16, 2017 (edited) Chuck one of these in there https://www.amazon.com/gp/product/B00KFCRATC/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 At the back Edited May 16, 2017 by Doofus
Guest asrequested Posted May 16, 2017 Posted May 16, 2017 Looking at this, I'd replace those fans, too. With the Noctua fans. That'll knock down the ambient temp in the case. At 50% they are really good. They are PWM, so you mobo can control them.
Swynol 375 Posted May 17, 2017 Posted May 17, 2017 (edited) my seagate SAS drives always run hot. they were 46c quite often. i then installed some noctua 120mm 3000rpm fans and it brought the temps down to 36c-40c. Seagate says the drives are fine up to 50c, reliability starts to diminish above that. I have slowly been swapping out my SAS drives for slower RPM drives which run much cooler and use less watts. try to get some fans that can suck the air through the hot swap bays and then exhaust fans at the rear sucking the air out. you can just about see my fan wall with the noctuas here. Edited May 17, 2017 by Swynol
mediacowboy 438 Posted May 17, 2017 Author Posted May 17, 2017 So I was looking at my logs for something and keep seeing the following error's. As this is the first time I have used any LSI type cards in my personal equipment can someone help me out. Error Event 11 LSI_SAS2i The driver detected a controller error on \Device\RaidPort0. Warning Even 129 LSI_SAS2i Reset to device, \Device\RaidPort0, was issued. I did download a sas2 flash and ran sas2flash -listall and got back the following. _Windows\sas2flash_win_x64_rel>sas2flash -listall LSI Corporation SAS2 Flash Utility Version 20.00.00.00 (2014.09.18) Copyright (c) 2008-2014 LSI Corporation. All rights reserved Adapter Selected is a LSI SAS: SAS2008(B2) Num Ctlr FW Ver NVDATA x86-BIOS PCI Addr ---------------------------------------------------------------------------- 0 SAS2008(B2) 20.00.00.00 14.00.00.07 07.39.00.00 00:01:00:00 Finished Processing Commands Successfully. Exiting SAS2Flash. Any idea's?
Guest asrequested Posted May 17, 2017 Posted May 17, 2017 (edited) I read a lot of reviews talking about the SAS connectors not in fully. Check your connections. It looks like you have the latest firmware. Edited May 17, 2017 by Doofus
PenkethBoy 2068 Posted May 17, 2017 Posted May 17, 2017 I have a few Error 11 approx 6 a month - i am not seeing any issues - i suspect its drives which are spun down not coming backup quick enough - or before the LSi timeout - not 100% about that Have no error 129 - which i would be more worried about my firmware is 20.00.07/7.39.02 Win 2012R2
mediacowboy 438 Posted May 19, 2017 Author Posted May 19, 2017 So I've been thinking about the errors and delay in boot up. Could all of this steam from the pci-e riser cable?
Swynol 375 Posted May 19, 2017 Posted May 19, 2017 i've been having Error 129 on my LSI card since i installed it about 6 months ago. Doesnt seem to affect my machine in any way.
Guest asrequested Posted May 21, 2017 Posted May 21, 2017 Norco has something similar to your new build. http://www.norcotek.com/product/itx-s8/ Here's the smaller S4 case
mediacowboy 438 Posted May 21, 2017 Author Posted May 21, 2017 I like that it can support a full PCI card but that is about it. No room for water cooling and not a fan of the 1u power supply.
Guest asrequested Posted May 21, 2017 Posted May 21, 2017 I like that it can support a full PCI card but that is about it. No room for water cooling and not a fan of the 1u power supply. Yeah, the PSU was something I didn't like, too.
CBers 7554 Posted May 23, 2017 Posted May 23, 2017 @@mediacowboy - new versions of DriveBender and CloudXtender were released today. https://www.division-m.com/downloads/
