xxJonoxx 4 Posted December 30, 2016 Posted December 30, 2016 Hi Team! Im not sure if this is an issue with the server, or the xbox app itself. But sound during playpack of anything is about 1/2 of what it should be. As an example, my soundbar is set to 20 - perfectly fine for watching anything through the Xbox (games, Netflix, blur ray etc).. but when i veiw anything with Embry its about 1/2 - so I need to crank the soundbar up to 40 to hear it.
Luke 42241 Posted December 30, 2016 Posted December 30, 2016 Hi @@xxJonoxx there is an audio boost setting in the emby server dashboard under the Transcoding menu.
xxJonoxx 4 Posted December 30, 2016 Author Posted December 30, 2016 Hi Luke, Thanks for the reply, I found that setting but unfortunatly (fortunatly?) the majority of my media is 'direct playing' and makes no difference if i set it to 1,2 or 3 Though, playing around i found a few quirks(?) I changed/reduced the 'Max streaming Bitrate' in the client to force the transcode.. When attempting to playback, I get nothing but black screen. I then recall this new version was the one that supported the H/W Transcoding on the Evansports - So I enabled the VA API in transcoding (not sure if that is correct) but this showed up in the log AVHWDeviceContext @ 0x80a3c40] No VA display found for device: /dev/dri/card0.[vaapi @ 0x80886a4] Failed to create a VAAPI device So im guessing it wasnt?
Luke 42241 Posted December 30, 2016 Posted December 30, 2016 Ok, unfortunately, if it's direct playing then there''s not much we can do. If it's transcoding then there are things we can do but most people will not want to force transcoding just for that very reason. And yes, try disabling Va Api.
xxJonoxx 4 Posted December 30, 2016 Author Posted December 30, 2016 Ok, unfortunately, if it's direct playing then there''s not much we can do. If it's transcoding then there are things we can do but most people will not want to force transcoding just for that very reason. And yes, try disabling Va Api. Hi Luke, I did that, back to 'none'. I'm staring at a black screen for the last few mins - so its not playing anything. its also unresponsive. So I have to go back to the dash and force quit the Xbox app. it looks like its transcoding albeit poorly at about 22fps. frame= 36 fps= 35 q=20.0 size= 1kB time=00:00:01.72 bitrate= 4.0kbits/s speed=1.66x frame= 45 fps= 28 q=22.0 size= 125kB time=00:00:02.08 bitrate= 491.0kbits/s speed=1.31x frame= 51 fps= 24 q=22.0 size= 125kB time=00:00:02.36 bitrate= 431.3kbits/s speed=1.13x frame= 61 fps= 23 q=20.0 size= 125kB time=00:00:02.81 bitrate= 362.7kbits/s speed=1.08x frame= 69 fps= 22 q=19.0 size= 125kB time=00:00:03.10 bitrate= 329.0kbits/s speed=0.996x frame= 82 fps= 22 q=20.0 size= 125kB time=00:00:03.64 bitrate= 279.9kbits/s speed=0.998x frame= 93 fps= 22 q=21.0 size= 125kB time=00:00:04.16 bitrate= 245.5kbits/s speed=0.995x frame= 104 fps= 22 q=22.0 size= 125kB time=00:00:04.67 bitrate= 218.6kbits/s speed=0.992x frame= 115 fps= 22 q=22.0 size= 125kB time=00:00:05.18 bitrate= 197.0kbits/s speed=0.989x frame= 126 fps= 22 q=22.0 size= 1081kB time=00:00:05.44 bitrate=1627.8kbits/s speed=0.945x frame= 138 fps= 22 q=21.0 size= 1081kB time=00:00:05.95 bitrate=1487.7kbits/s speed=0.945x As for the sound, just as a another test, I loaded up the native 'media player' app it is the correct volume. It seems to isolated the Xbox app and there is a definite reduction in volume.
Luke 42241 Posted December 31, 2016 Posted December 31, 2016 The volume is already at max value in the app and we just leave it up to device volume rather than having the user manage volume in app. Your transcoding is just not happening fast enough. What is the input audio codec?
xxJonoxx 4 Posted December 31, 2016 Author Posted December 31, 2016 (edited) The volume is already at max value in the app and we just leave it up to device volume rather than having the user manage volume in app. Your transcoding is just not happening fast enough. What is the input audio codec? That particular file was AC3 Duration: 01:58:04.29, start: 0.078000, bitrate: 3246 kb/s Stream #0:0: Video: h264 (High), yuv420p(tv, bt709, progressive), 1280x536, SAR 1:1 DAR 160:67, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default) For what its worth, James used my NAS as a test for the Evansport's to enable HW Trancoding, we got it up to 90-95fps So mine may have some 'manual' changes to it (?) - more than happy to provide him (or yourself) admin access to it again. Please don't take this the wrong way, you guys are the pros and coding is way over my head -- but are you sure with the sound that its set too max in the app? Whilst far from scientific I made a clip on my mobile that will hopefully demonstrate the difference in volume between 'direct playing' in the app vs DLNA via the Xbox media player app. (excuse the middle bit where I dropped the controller) https://1drv.ms/v/s!Av7wkvTuoBNbhM9x6MfHWJ5EXIuHtA Its quite dramatic. Also, with lack of propper tools, using a dB meter on the phone as a baseline the room with nothing going was averaging 40db, with Emby 47db and media player 60db Edited December 31, 2016 by xxJonoxx
solabc16 379 Posted December 31, 2016 Posted December 31, 2016 Hi @@xxJonoxx The latest release for Synology/XPEnology (3.1.2.0-2) includes support for h/w transcoding on Evansport machines, it's just not enabled by default. Essentially, this is the packaged result of the progress/developments we made a little while ago and tested on your machine (thanks again!). The Evansport machine h/w transcoding implementation is proprietary, so can't be tackled in the same was as other platforms with VAAPI or QSV. I'll post details in 2017... we're not quite there yet over here! Best - James
Solution xxJonoxx 4 Posted January 2, 2017 Author Solution Posted January 2, 2017 I'll post details in 2017... we're not quite there yet over here! Best - James Hi James! Oh, that's good to hear. Look forward to you opening it up for everyone. The volume is already at max value in the app and we just leave it up to device volume rather than having the user manage volume in app. Hi Luke, Without making myself look like a boob, you were right. After much playing around, I found the cause of the issue more by mistake than anything. What happens on the X1 app, is the use of that new background music functionally. As it happens Emby uses that same value - I am assuming if I wanted to stream music while gaming. Well I personally use Groove, but it remembered the volume level from when I had groove in the background. Best explained it this pic. I adjusted that slider and it all went back to normal... Thanks for your time. 1
solabc16 379 Posted January 2, 2017 Posted January 2, 2017 Hello @@xxJonoxx Well done on finding the cause of the issue with the sound volume levels, I'm sure that's going to be useful to a number of other people! I've posted the details on enabling/disabling hardware transcoding on Evansport machines now. You can find them here: https://emby.media/community/index.php?/topic/43282-hw-transcoding-on-evansport-ds415playds214play-machines/ - James
