Got network?
Guest asrequested
PenkethBoy
lol
maybe its come from China or has a code page setup for another language?
Does it have a web page for config other than the console?
Whats the make and model again?
Guest asrequested
It's a Quanta LB6M. It works just fine, but I think the packet size is around 1Gb. If I set the NICs to 1000, the transfer works without any problems at around 1Gb/s. If I push the packet size to 1400 or higher, the transfer stalls part way through, and once complete, is reported at around 300Mb/s. Fortunately, I don't need the switch, it's just for extra ports. So I've got time to play with it. I'm also working on better cooling. It idles at 40C. I've replaced the fans with quieter ones. but I'm going to double up, in hopes that it will move more air through the case
Guest asrequested
Finally got the jumbo packets configured. Got me sum 10G goin' on :D
Now I want to figure out how to get the web interface to work...
Guest asrequested
No web interface :(
I'm taking the switch offline for a bit. The fans that I replaced the originals with aren't PWM, and the firmware needs them to be PWM for it to gather all the environmental data (PSU, fan speed, temp etc). So I need to find 40mm PWM fans that are quieter. My chosen fans (Noctua A4-10) don't move quite enough air. I may say "screw it" to the environmental control and double/triple stack the Noctua fans, and let them run. The other alternative is to use these. They are a little quieter, but maybe not be quiet enough. If anyone knows of fans that would be better than the stock fans, let me know. I could also modify the lid, to allow better ventilation. Any other ideas?
MSattler
No web interface :(
So I have the same switch and bought the fans below.
(FASTPATH Routing) #show env
Temp (Celsius)................................. 44
Fan Speed, RPM................................. 6185
Fan Duty Level................................. 55%
Temperature traps range: 0 to 45 degrees (Celsius)
Temperature Sensors:
Unit     Sensor  Description       Temp (Celsius)  State
1        1                         44              Normal
Fans:
Unit   Fan     Type        Speed      Duty level State
1      1       Fixed       6185              55% Operational
1      2       Fixed       5973              55% Operational
1      3       Fixed       5973              55% Operational
Top Motor 40x28mm 12V 9000 rpm PWM fan with connector #DF124028BL-PWMG × 3
16.32cfm
www.coolerguys.com
Edited by MSattler
Guest asrequested
1        1                         44              Normal
Fans:
16.32cfm
www.coolerguys.com
Thanks. I ended up ordering some of these. They move a little less air, but should be quieter
http://www.evercool.com.tw/categories/global/fan/pwmfan/ec-4020/ec4020.php
Guest asrequested
I replaced the power supply fans, too. I used Noctua fans. You have to reverse the wires, but it's silent.
MSattler
I may look at that next.  Just worries me to mess with the power supply.  Don't want it to overheat.
Guest asrequested
Well, you have a spare :) I've got the spare, pulled out. Less weight on the back, and allows more air inside.
Edited by Doofus
JeremyFr79
Comcast/Xfinity Cisco DPC3941T Gateway (180/25)
      - Cisco UCS200B Server - pfSense router/firewall/openVPN host (1G/1G)
      - Cisco WS-C2960S-48LPS-L 48Port POE Gigabit Switch
      - 2 EnGenius ECB1200 AC WAPS
      - 3 Netwrok Security Cameras
     - 2 Physical Servers
     - 8 Virtual Servers
     - 1 TV HeadEnd PC
      - 1 Media PC
      - 3 Laptops
      - 1 Desktop
      - 2 TV's
       - Chromecast
       - Nexus Player
       - 2 Xbox's
      - 1 Receiver
       - Printer
       - Refrigerator
       - 2 Phones
       - 3 Tablets
       - Smartwatch
       - Harmony Hub
I think that's it :D
3 vLans (main, guest wireless, VPN)
3 WiFi SSID's
Edited by JeremyFr79
  • Like 1
Guest asrequested
Lol... Are you sure that's all? I'm wondering why 8 virtual servers?
colejack
Because VMs are "cool"  ;)
  • Like 1
PenkethBoy
wondering if the fridge does transcoding...  :P
  • Like 1
Guest asrequested
I'm sure it direct plays lol
Oh wait, is the fridge a VM? Lol
I'm looking to upgrade my switches.  They are simple 5 port Netgear models and my WMC extender often looses connection.  Can anyone recommend a reasonable switch to switch to?  I'd look at 10G, but none of my nodes have that.  Yet....
JeremyFr79
No but it let's you know when the built in Kuerig is heated, or the filter needs to be replaced lol
JeremyFr79
Emby
Print Server
Web Server
SMTP Host
WSUS Server (recently decommissioned)
WDS Server
secondary DC/DNS which reminds me I have 3 physical servers lol forgot about the primary DC/DNS server lol
Security Camera Server
And then a few test servers/vms from time to time lol
So 7 fulltime VMS now
Guest asrequested
Wait! You have a kuerig in your fridge? Lol
JeremyFr79
Yes and IT'S AWESOME! :D
PenkethBoy
lol a coffee maker in a fridge...
Maybe Emby can run on it?
  • Like 1
JeremyFr79
If you develop it, we will come lol
  • Like 2
