PenkethBoy 2068 Posted January 10, 2017 Posted January 10, 2017 Did you load the latest intel drivers to get all the config goodies
Guest asrequested Posted January 10, 2017 Posted January 10, 2017 I just let Windows find its own driver. They came discs, but I haven't installed the software, yet.
PenkethBoy 2068 Posted January 10, 2017 Posted January 10, 2017 Ok the newest intel drivers have some fixes i believe but the default ones work ok i think
Guest asrequested Posted January 10, 2017 Posted January 10, 2017 They worked perfectly, last night. I did test on file copying. 225MB/s. I've ordered those other SFP+ cards, in case I decide to be impatient and buy that other switch lol
PenkethBoy 2068 Posted January 10, 2017 Posted January 10, 2017 lol - Doofus getting carried away i think
Guest asrequested Posted January 10, 2017 Posted January 10, 2017 So easy to do, lol. What I want is to be able to transfer files at the full write speed of the drives, and be able to download and stream simultaneously, with room to spare. Even with 2g, file transfer eats all the bandwidth.
Guest asrequested Posted January 10, 2017 Posted January 10, 2017 You getting SMB MP? I'll confess to not fully understanding that... Maybe? Sure? I don't know?
pir8radio 1313 Posted January 11, 2017 Posted January 11, 2017 Do you not have the intel drivers installed? Teaming and VLAN's work on windows 10 for me, but you cant use the Microsoft drivers.
Guest asrequested Posted January 11, 2017 Posted January 11, 2017 Do you not have the intel drivers installed? Teaming and VLAN's work on windows 10 for me, but you cant use the Microsoft drivers. I downloaded the latest they had
PenkethBoy 2068 Posted January 11, 2017 Posted January 11, 2017 Yep they are the same as mine Intel Teaming in Win 10 is disabled but the next release of the Intel drivers should (fingers crossed) fix that.as they have found the issue SMB MP => SMB Multipath - if you have multipath then teaming is a bit redundant
Swynol 375 Posted January 11, 2017 Posted January 11, 2017 what version of win10 are you using? not sure it matters but incase it only works on enterprise and pro
Guest asrequested Posted January 11, 2017 Posted January 11, 2017 I'm running windows 10 pro. I've got both ports hooked up. So I assume that's multi-path with smb3. I want to see if can use the onboard port with teaming.
PenkethBoy 2068 Posted January 11, 2017 Posted January 11, 2017 Not until Intel release the drivers - or you have other lan ports by other manufacturers
PenkethBoy 2068 Posted January 12, 2017 Posted January 12, 2017 Cool - thats not play fair though - lol
Guest asrequested Posted January 12, 2017 Posted January 12, 2017 Lol... When I was there, there was a stack of switches sitting on the work surface, but they may not be functional.
punchycool 6 Posted January 13, 2017 Posted January 13, 2017 (edited) 120 mbps / 10 mbps download/upload lines from Xfinity cable //hardwired via RG59U into >> Netgear C3000 //Modem hardwired via cat6 to downstairs >> Netgear R8000 Nighthawk X6 AC3200 //used as router/wifi that feeds (1) Synology DS416 NAS //hardwired to router via USB 3.0 (4) iphones //wifi (1) Apple TV //hardwired to router via cat6 that servers up Emby, HBOGo, DirecTVNow, etc (2) ipads //wifi (1) Emby server running in old (2007) Micro-ATX case w/Athlon 64 X2 4400+/8GB DDR2 RAM / Ubuntu //hardwired to router via cat6 (1) Dell 2015 laptop //wifi (1) Wii //wifi (2) Roku 3 //feeds a couple extra TVs Extremely happy with this setup less the hardware behind #5 . I get consistent 1000 mbps internal data transfer speeds across the ethernet and 100-120 mbps wifi data speeds all over my 1/3 acre lot. Edited January 13, 2017 by punchycool
Rumbaar 13 Posted January 14, 2017 Posted January 14, 2017 I've always found the USB interface on my routers to be slow and speed limiting. That's faster than network attached?
Guest asrequested Posted January 14, 2017 Posted January 14, 2017 Is it USB 2.0? I'm assuming you're referring to attaching an external hard drive?
punchycool 6 Posted January 14, 2017 Posted January 14, 2017 Synology nas via USB 3 to the nighthawk.
Guest asrequested Posted February 23, 2017 Posted February 23, 2017 @@PenkethBoy @@pir8radio the new X540-T2 drivers now support teaming in Windows 10 2
PenkethBoy 2068 Posted February 23, 2017 Posted February 23, 2017 cool!!!!!!!!!!!! I wonder if SMB Multipath still works when the cards are teamed ....hmmm...my guess is not but we will see now where do i get a 10G+ stream from to test?
Guest asrequested Posted February 23, 2017 Posted February 23, 2017 cool!!!!!!!!!!!! I wonder if SMB Multipath still works when the cards are teamed ....hmmm...my guess is not but we will see now where do i get a 10G+ stream from to test? Lol I know, right? Probably just have to use a testing app. I feel like I'm going buy a 12 Gb/s SAS card in the not too distant future
