Tur0k 148 Posted January 4, 2018 Posted January 4, 2018 That sounds like nice long project Sounds like you're a hunter, with a gun safe and freezer? Yep, that I am. Sent from my iPhone using Tapatalk
pir8radio 1313 Posted January 6, 2018 Posted January 6, 2018 (edited) OK guys. Looks like I'm going to sell both of the Unifi US-16-XG 10G 16-Port Managed Aggregation Switches and my Quanta LB6M 10G switch. Before I put them on ebay, I figured I'd give you guys first refusal at a lower price. The Unifis $300 + shipping (each) and the Quanta $100 = shipping. USA shipping, only. If interested, PM me. what SFP's do you have in the unifi switch? Edited January 6, 2018 by pir8radio
Guest asrequested Posted January 6, 2018 Posted January 6, 2018 what SFP's do you have in the unifi switch? The cables, you mean? I got these, and they are surprisingly good quality. Not greatly flexible, though. They are nice and thick
pir8radio 1313 Posted January 6, 2018 Posted January 6, 2018 The cables, you mean? I got these, and they are surprisingly good quality. Not greatly flexible, though. They are nice and thick Ahh, I was hoping you had some fiber modules installed.. https://www.ubnt.com/accessories/fiber-modules-cable/
Guest asrequested Posted January 6, 2018 Posted January 6, 2018 Ahh, I was hoping you had some fiber modules installed.. https://www.ubnt.com/accessories/fiber-modules-cable/ I looked into that, but they were much more expensive for no significant gain. It wasn't worth it, for me. I would like to have fiber, though.
Tur0k 148 Posted January 6, 2018 Posted January 6, 2018 I wish the US-24-250W had SFP+ Sent from my iPhone using Tapatalk
Guest asrequested Posted January 6, 2018 Posted January 6, 2018 I wish the US-24-250W had SFP+ Sent from my iPhone using Tapatalk I love my 10G. I often use 5+ 1
chef 3811 Posted January 6, 2018 Posted January 6, 2018 I know it isn't super awesome... but if you had seen my crappy server last year you would understand what a massive step up this is. There are quite a few drives in the main emby box. This also runs Home Automation and Security as well. I'm waiting for zip ties to better manage the cords because they are a mess right now. I shrouded all the power lines with the same black 'cord-shroud'. It actually looks pretty alien, and when they are all tied up properly it is going to look pretty great I think. All the cat5e and cat6 lines will be color-coded for each device and bundled properly into a brand new 8 channel switch, which is connected to a Fibre line to the outside world. The main server runs core i5 right now, but I'm going to update the Mobo and chipset this year. Perhaps someone here might have an answer to a question I have. When I attempt to fill the current Mobo's RAM slots with RAM sticks (same timing on all of them), the PC refuses to boot. Instead, I can only fill two of the RAM slots. Wierd?!? I really want my 32 gigs of RAM working. Right now it is only 16. Well, love it or hate it, this is my setup 2
Guest asrequested Posted January 6, 2018 Posted January 6, 2018 Looks good! Maybe you have a bad stick of memory? Have you tried two at a time?
chef 3811 Posted January 6, 2018 Posted January 6, 2018 Looks good! Maybe you have a bad stick of memory? Have you tried two at a time? Yeah when switching between all of them in two slots everything seems okay. Just when I fill all the DIM slots the computer won't boot.
Tur0k 148 Posted January 6, 2018 Posted January 6, 2018 What is the manufacturer and model mobo and chipset? Are you perhaps mixing ECC memory in on a mobo that doesn't fully support it? Sent from my iPhone using Tapatalk 1
PenkethBoy 2068 Posted January 6, 2018 Posted January 6, 2018 is the memory from different suppliers? are we talking dual channel or perhaps quad channel? reset you timing on the MB to default and try one from each as a pair - does it boot then? do you get an error code from the MB that you can check in the manual for more(maybe) info? 2
chef 3811 Posted January 6, 2018 Posted January 6, 2018 (edited) The ram is: 8gb PC-3-12800 DIMM Motherboard is: ASROCK h97 Anniversary I think it's time for a new motherboard. I'll attempt to reset timing and see what happens. Edited January 7, 2018 by chef
pir8radio 1313 Posted January 7, 2018 Posted January 7, 2018 Did you get one of those switches? late response, no I was looking at buying yours lol.
Guest asrequested Posted January 7, 2018 Posted January 7, 2018 (edited) late response, no I was looking at buying yours lol. Ah.too late. I've already sold the Unifi switches. I still have the Quanta. Edited January 7, 2018 by Doofus
PenkethBoy 2068 Posted January 7, 2018 Posted January 7, 2018 The ram is: 8gb PC-3-12800 DIMM Motherboard is: ASROCK h97 Anniversary I think it's time for a new motherboard. I'll attempt to reset timing and see what happens. any luck?
chef 3811 Posted January 8, 2018 Posted January 8, 2018 Frustratingly no. I'm looking into new motherboards now. Needs lga1150 so limited options unfortunately. But I did buy a brand new TP link switch with a gigabit connection.
Tur0k 148 Posted January 15, 2018 Posted January 15, 2018 (edited) My network rack is here!!! I got the rack put together and will get it mounted this week. I am also refreshing the power systems on the rack with: 1. Upgrading the 500 VA backup UPS with a 1200VA unit. The old unit needs new batteries and my work was cycling out some old backup UPS systems out of our remote site network closets. 2. A 6 outlet (4 controlled) aeotech Zwave surge strip. Aeotec by Aeon Labs DSC11 Smart Power Strip Z-Wave Power Sockets https://www.amazon.com/dp/B00H3RL6JW/ref=cm_sw_r_cp_api_3AcxAbYV2ZXVZ It will integrate with my existing home automation system So I can monitor power utilization and power cycle the equipment in the event they go belly up or have to be power cycled to restore connectivity (cable modem). Sent from my iPhone using Tapatalk Edited January 15, 2018 by Tur0k 2
Guest asrequested Posted January 15, 2018 Posted January 15, 2018 Nice! I like the power monitor/cycling idea. I still need to get a UPS 1
Tur0k 148 Posted January 15, 2018 Posted January 15, 2018 Nice! I like the power monitor/cycling idea. I still need to get a UPS Yea, I can’t take credit for it, a buddy of mine showed me his event config. He pings google DNS if he gets doesn’t receive 10 replies consecutively he assume Internet is down, sends a broadcast on his WHA system and power cycles the modem. That new backup UPS is a hoss too. I looking it up I should be able to pickup oversized batteries for it. I just wish it had a NIC and supported SNMP. Sent from my iPhone using Tapatalk
Guest asrequested Posted January 15, 2018 Posted January 15, 2018 (edited) I'll have to take a look at that UPS. I was looking at a Tripp-lite https://www.amazon.com/gp/product/B000DZRY9C/ref=ox_sc_sfl_title_34?ie=UTF8&psc=1&smid=ATVPDKIKX0DER Edited January 15, 2018 by Doofus 1
Tur0k 148 Posted January 15, 2018 Posted January 15, 2018 (edited) I'll have to take a look at that UPS. I was looking at a Tripp-lite https://www.amazon.com/gp/product/B000DZRY9C/ref=ox_sc_sfl_title_34?ie=UTF8&psc=1&smid=ATVPDKIKX0DER We use those in our smaller clinics. They are work horses. The screens are pretty but don’t give much info. Right now I have a pair of 1200VA APCs from work (that need new batteries), a 1500VA APC, and a 500VA APC (that needs new batteries). Sent from my iPhone using Tapatalk Edited January 15, 2018 by Tur0k
Guest asrequested Posted January 15, 2018 Posted January 15, 2018 (edited) We use those in our smaller clinics. They are work horses. The screens are pretty but don’t give much info. Right now I have a pair of 1200VA APCs from work (that need new batteries), a 1500VA APC, and a 500VA APC (that needs new batteries). Sent from my iPhone using Tapatalk I'm not ready to buy one, yet. But I'll shop around when I am. I only want it for the server and network equipment. Edited January 15, 2018 by Doofus
