shaefurr 1340 Posted January 28, 2014 Posted January 28, 2014 (edited) Just thought id share this, I keep breaking my cheap MCE remotes and wanted to find a decent android wifi remote, but I also use the keyboard/mouse a lot for things like amazon instant. Anyway I came across this Roccat Power Grid It has extra "grids" for keyboard, trackpad, remote, music, volume etc, plus its easy to make your own so im making one specifically for MBT with buttons for the OSD etc, possibilities seem pretty endless. By far the best android wifi remote/keyboard ive tried. Plus has a lot of grids for PC gaming which is awesome. Anyway just wanted to mention it. Edited January 29, 2014 by shaefurr 4
LiquidFX 144 Posted January 28, 2014 Posted January 28, 2014 Good find, I havnt had much time to play with it but seems cool
shaefurr 1340 Posted January 28, 2014 Author Posted January 28, 2014 Have a basic working remote for MBT, just need to design the buttons/ icons now, but that wont be happening for a while since I have too much other stuff to do
shaefurr 1340 Posted January 28, 2014 Author Posted January 28, 2014 Changed the layout a bit, only problem ive seen with this app is its 99% likely you will hit a button when scrolling, so I made a gap between icons to give some area to scroll, and made the MBT launcher bigger. Yes, I accidentally blasted my volume from 10-100% while playing music thanks to the weird scrolling bug, definitely not fun. They need to fix that
LiquidFX 144 Posted January 29, 2014 Posted January 29, 2014 Changed the layout a bit, only problem ive seen with this app is its 99% likely you will hit a button when scrolling, so I made a gap between icons to give some area to scroll, and made the MBT launcher bigger. Yes, I accidentally blasted my volume from 10-100% while playing music thanks to the weird scrolling bug, definitely not fun. They need to fix that You need to share it for the rest of us
shaefurr 1340 Posted January 29, 2014 Author Posted January 29, 2014 I had submitted it to their site for approval earlier, if you dont want to wait here's the download. https://www.mediafire.com/?kn6k76si5m8264m PS: Still need to make a few changes but ill update it later. Theres a few graphical issues in the arrow keys and I want to add a transparent background to those buttons as well.
Koleckai Silvestri 1154 Posted January 29, 2014 Posted January 29, 2014 This is available for iOS as well. https://itunes.apple.com/us/app/roccat-power-grid/id663679239?mt=8
shaefurr 1340 Posted January 29, 2014 Author Posted January 29, 2014 Its in their store now if you want to get it from there. http://power-grid.roccat.org/en/Store/Grids/Programs/Windows/224/
Koleckai Silvestri 1154 Posted January 29, 2014 Posted January 29, 2014 (edited) Thanks. This is definitely handy. Don't have to buy a remote for my PC now. This will work on the third generation iPod Touch we have. Edited January 29, 2014 by Wayne Luke
shaefurr 1340 Posted January 29, 2014 Author Posted January 29, 2014 (edited) Submitted another update, fixes the few graphical issues in the arrow buttons, button style is slightly changed on them as well. And the navigation buttons will now continue to scroll if you hold them down. Its not live yet but you'll know when the version changes from 1.0 to 1.1 EDIT: new version is finally live Edited January 31, 2014 by shaefurr
