x-cimo 23 Posted December 28, 2016 Posted December 28, 2016 I was having issue with seeking (forward/backward) in a video stream (it was either slow, or not working). I found in the android client a bunch of REFUSED_STREAM error.. then I found https://github.com/square/okhttp/issues/2506 Which point to a bug in nginx with HTTP 2.0 (I think Emby just moved to HTTP 2 in 3.1.0 ?). On ubuntu 16.04 fully patch the latest version of nginx is 1.10, for which the issue is not resolved.. You can get the latest version 1.11.7 by doing the following (found on http://www.ubuntumaniac.com/2016/05/install-nginx-1110-on-ubuntu-1604.html) sudo add-apt-repository ppa:chris-lea/nginx-devel sudo apt-get update sudo apt-get upgrade Hope it helps someone else. 1
Luke 42246 Posted December 28, 2016 Posted December 28, 2016 Emby Server has not yet implemented http2, fyi.
x-cimo 23 Posted December 28, 2016 Author Posted December 28, 2016 Good to know, I swear it was fine before, but I just put in place nginx a couples days ago so maybe it was always there. nginx is receiving HTTP/2.0 from my phone (android client). Which triggered the issue on nginx itself. thanks for clarifying
pir8radio 1313 Posted December 28, 2016 Posted December 28, 2016 so is there an issue still or was it just miscommunication about http2?
Luke 42246 Posted December 29, 2016 Posted December 29, 2016 It sounds valid if the proxy is using http2.
Luke 42246 Posted January 27, 2020 Posted January 27, 2020 @@x-cimo Emby Server 4.4 will have http2 support on Windows and Linux.
