Nathanio 35 Posted December 28, 2016 Posted December 28, 2016 Version 3.1.6206.5924 dev When streaming live SD channels on either webapp or fire tv box, the aspect ratio is all out: It's all squashed up horizontally (or stretched to meet the vertical requirements) I have attached a log file when doing a transcode from 4Music SD Ratio.txt
Luke 42186 Posted December 28, 2016 Posted December 28, 2016 Hi, can you try without quicksync? There's nothing new from the server here, encoding hasn't changed and also, if you look at this particular command line, we're not doing any scaling or stretching, so the resolution should be preserved as-is. thanks.
Nathanio 35 Posted December 28, 2016 Author Posted December 28, 2016 HI Luke, I can do. It was working previously ok with QuickSync. I'll give it ago now
Nathanio 35 Posted December 28, 2016 Author Posted December 28, 2016 @@Luke, Just tried it and it now is working fine.As I say it had been working fine with QuickSync. It had also fixed the issue with buffering on the webapp over 8mbps. I've switched it off for now. Is C:\Users\Administrator\AppData\Roaming\Emby-Server\ffmpeg\20160410\ffmpeg.exe the correct level of FFMPEG to run? Thanks
Nathanio 35 Posted December 28, 2016 Author Posted December 28, 2016 (edited) @@Luke, Since switching off QuickSync I now can't watch SD channels on my FireTV box. It tries to play and then stops with "Too Many Errors - Stopping" Log: http://172.0.0.1:8096/emby/videos/e7516336a8e06ebcbef065d0260f6329/stream.mkv?DeviceId=d9817f6026fe3234&MediaSourceId=a997aadffa7b481f9502ea5399069548_native_54211d4ce8cdf32f0402f83a6c2c696d&VideoCodec=h264&AudioCodec=aac,mp3&AudioStreamIndex=1&VideoBitrate=71513791&AudioBitrate=128000&MaxAudioChannels=8&PlaySessionId=ca54ad0412ec4c5b8669f2ec759f6191&api_key=401cebda0c17436b962d90b302c89d1c&LiveStreamId=a17c75760a04e99b68cf766e11316e1c_09efa0d56b934a82adec00a87b837fb0_a997aadffa7b481f9502ea5399069548_native_54211d4ce8cdf32f0402f83a6c2c696d&CopyTimestamps=true&TranscodingMaxAudioChannels=6&EnableSubtitlesInManifest=false&RequireAvc=false {"Protocol":"Http","Id":"a997aadffa7b481f9502ea5399069548_native_54211d4ce8cdf32f0402f83a6c2c696d","Path":"http://127.0.0.1:8096/LiveTv/LiveStreamFiles/0fe59c874e9a41bc8080c92c325ed026/stream.ts","Type":"Default","Container":"mpegts","ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":false,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"SupportsProbing":true,"LiveStreamId":"a17c75760a04e99b68cf766e11316e1c_09efa0d56b934a82adec00a87b837fb0_a997aadffa7b481f9502ea5399069548_native_54211d4ce8cdf32f0402f83a6c2c696d","BufferMs":0,"MediaStreams":[{"Codec":"mpeg2video","TimeBase":"1/90000","CodecTimeBase":"1/50","IsInterlaced":true,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":576,"Width":544,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"Main","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":8,"IsAnamorphic":false},{"Codec":"mp2","Language":"eng","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"Eng MP2 stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":128000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"mp3","Language":"eng","TimeBase":"1/90000","CodecTimeBase":"1/0","DisplayTitle":"Eng MP3 0 ch","IsInterlaced":false,"Channels":0,"SampleRate":0,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"dvbsub","Language":"eng","TimeBase":"1/90000","CodecTimeBase":"1/90000","DisplayTitle":"Eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":3,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":128000,"RequiredHttpHeaders":{},"DefaultAudioStreamIndex":1} C:\Users\Administrator\AppData\Roaming\Emby-Server\ffmpeg\20160410\ffmpeg.exe -fflags +genpts -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/0fe59c874e9a41bc8080c92c325ed026/stream.ts" -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -force_key_frames "expr:gte(t,n_forced*5)" -vf "yadif=0:-1:0" -pix_fmt yuv420p -preset superfast -crf 23 -tune zerolatency -maxrate 71513791 -bufsize 143027582 -vsync -1 -flags -global_header -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 aac -strict experimental -ac 2 -ab 128000 -af "aresample=async=1" -y "S:\Transcode\transcoding-temp\b64c541df56329747d3901873ebd1f31.mkv" ffmpeg version N-79277-g0c90b2e Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.3.0 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib libavutil 55. 20.100 / 55. 20.100 libavcodec 57. 34.100 / 57. 34.100 libavformat 57. 32.100 / 57. 32.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 41.100 / 6. 41.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 [mpeg2video @ 000000000059e0c0] Invalid frame dimensions 0x0. Last message repeated 8 times [mpegts @ 000000000059a3c0] Could not find codec parameters for stream 2 (Audio: mp3 ([3][0][0][0] / 0x0003), 0 channels, s16p): unspecified frame size Consider increasing the value for the 'analyzeduration' and 'probesize' options [mpegts @ 000000000059a3c0] Could not find codec parameters for stream 4 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, mpegts, from 'http://127.0.0.1:8096/LiveTv/LiveStreamFiles/0fe59c874e9a41bc8080c92c325ed026/stream.ts': Duration: N/A, start: 68844.961211, bitrate: N/A Program 25664 Stream #0:0[0x65]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv), 544x576 [SAR 32:17 DAR 16:9], max. 15000 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:1[0x66](eng): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16p, 128 kb/s Stream #0:2[0x68](eng): Audio: mp3 ([3][0][0][0] / 0x0003), 0 channels, s16p (visual impaired) Stream #0:3[0x67](eng): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) Stream #0:4[0xe12]: Unknown: none ([11][0][0][0] / 0x000B) [libx264 @ 0000000002d8c960] using SAR=32/17 [libx264 @ 0000000002d8c960] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [libx264 @ 0000000002d8c960] profile High, level 5.0 Output #0, matroska, to 'S:\Transcode\transcoding-temp\b64c541df56329747d3901873ebd1f31.mkv': Metadata: encoder : Lavf57.32.100 Stream #0:0: Video: h264 (libx264) (H264 / 0x34363248), yuv420p, 544x576 [SAR 32:17 DAR 16:9], q=-1--1, max. 71513 kb/s, 25 fps, 1k tbn, 25 tbc Metadata: encoder : Lavc57.34.100 libx264 Side data: cpb: bitrate max/min/avg: 71513000/0/0 buffer size: 143027000 vbv_delay: -1 Stream #0:1: Audio: aac (LC) ([255][0][0][0] / 0x00FF), 48000 Hz, stereo, fltp, 128 kb/s Metadata: encoder : Lavc57.34.100 aac Stream mapping: Stream #0:0 -> #0:0 (mpeg2video (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (mp2 (native) -> aac (native)) Press [q] to stop, [?] for help frame= 76 fps=0.0 q=20.0 size= 369kB time=00:00:04.24 bitrate= 712.6kbits/s speed=8.45x frame= 142 fps=138 q=20.0 size= 774kB time=00:00:06.88 bitrate= 922.1kbits/s speed=6.67x frame= 204 fps=130 q=18.0 size= 1173kB time=00:00:09.36 bitrate=1026.4kbits/s speed=5.97x frame= 209 fps=101 q=23.0 size= 1241kB time=00:00:09.56 bitrate=1063.7kbits/s speed=4.61x frame= 231 fps= 89 q=19.0 size= 1291kB time=00:00:10.44 bitrate=1013.0kbits/s speed=4.02x frame= 243 fps= 75 q=19.0 size= 1432kB time=00:00:10.92 bitrate=1074.0kbits/s speed=3.38x frame= 252 fps= 67 q=19.0 size= 1510kB time=00:00:11.28 bitrate=1096.6kbits/s speed= 3x frame= 273 fps= 64 q=19.0 size= 1560kB time=00:00:12.12 bitrate=1054.7kbits/s speed=2.85x frame= 287 fps= 60 q=18.0 Lsize= 1746kB time=00:00:12.68 bitrate=1128.3kbits/s speed=2.66x video:1555kB audio:184kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.393132% [libx264 @ 0000000002d8c960] frame I:8 Avg QP:14.86 size: 31783 [libx264 @ 0000000002d8c960] frame P:279 Avg QP:18.14 size: 4797 [libx264 @ 0000000002d8c960] mb I I16..4: 20.5% 34.0% 45.5% [libx264 @ 0000000002d8c960] mb P I16..4: 2.8% 1.3% 0.2% P16..4: 41.2% 0.0% 0.0% 0.0% 0.0% skip:54.5% It generates around 5 logs like this. Can play via webapp . HD channels play back fiine (direct play) on the FireTV box EDIT: If I select direct play on LiveTV on AFTV it does now play the SD channels Edited December 28, 2016 by Nathanio
Luke 42186 Posted December 28, 2016 Posted December 28, 2016 Please submit an in-app log so that @@ebr can look at it. thanks.
