grizlyadams 19 Posted December 28, 2016 Posted December 28, 2016 (edited) Hi, I'm moving my Emby server install from FreeNAS to unRaid. the libraries will not be in exactly the same folders/shares. Is there any way to maintain viewing history for all users when I do the move? thanks in advance Griz Edited December 28, 2016 by grizlyadams
ebr 16307 Posted December 28, 2016 Posted December 28, 2016 We store that information keyed off of global IDs (like from tmdb) to allow this type of thing. So, if you give the library scan the time to re-identify everything properly, it should all come back. 1
MrWebsmith 598 Posted December 28, 2016 Posted December 28, 2016 We store that information keyed off of global IDs (like from tmdb) to allow this type of thing. So, if you give the library scan the time to re-identify everything properly, it should all come back. this always makes me smile now, coming from the old mb2.x days where it was based on location i think... this is a small thing but very helpful
grizlyadams 19 Posted December 28, 2016 Author Posted December 28, 2016 (edited) We store that information keyed off of global IDs (like from tmdb) to allow this type of thing. So, if you give the library scan the time to re-identify everything properly, it should all come back. Thanks for the info, but how does that tie in with the old and new users? They are not Emby Connect users, they're only local to my install of Emby on the FreeNAS box and as such will be created (with the same names) on the new Emby unRaid box. Edited December 28, 2016 by grizlyadams
Luke 42186 Posted December 28, 2016 Posted December 28, 2016 Thanks for the info, but how does that tie in with the old and new users? They are not Emby Connect users, they're only local to my install of Emby on the FreeNAS box and as such will be created (with the same names) on the new Emby unRaid box. Hi @@grizlyadams, this is fine. The data is stored in your database. I would suggest using the Server Backup & Restore plugin (which requires Emby Premiere), as it will help make this process very easy for you.
grizlyadams 19 Posted December 28, 2016 Author Posted December 28, 2016 (edited) Hi @@grizlyadams, this is fine. The data is stored in your database. I would suggest using the Server Backup & Restore plugin (which requires Emby Premiere), as it will help make this process very easy for you. Hi - I've just paid for Premier Lifetime. when I go to plugins cataloge all i get is a spinning circle and no list of plugins.... (on IE11, Chrome and Firefox) Edited December 28, 2016 by grizlyadams
ebr 16307 Posted December 28, 2016 Posted December 28, 2016 Hmmm.... that's not supposed to happen . Can you please try restarting your server and , if the issue persists, please post a server log from that session. Instructions here. Thanks.
grizlyadams 19 Posted December 28, 2016 Author Posted December 28, 2016 (edited) Hmmm.... that's not supposed to happen . Can you please try restarting your server and , if the issue persists, please post a server log from that session. Instructions here. Thanks. I can't do that now - there are 3 copy sessions running, copying 12 TB of data and they won't be finished any time soon. The instructions link only refers to Windows logs location - this is a FreeNAS emby jail - I can get the logs from that if I know where to find them.... thanks is there any other way to add the backup/restore plugin? Edited December 28, 2016 by grizlyadams
Happy2Play 9801 Posted December 28, 2016 Posted December 28, 2016 Have you tried restarting the server process not the machine itself? The machine would be the next step.
Luke 42186 Posted December 29, 2016 Posted December 29, 2016 Can you please provide the emby server log? sounds like you might be having trouble connecting to our admin server. you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ thanks !
grizlyadams 19 Posted December 29, 2016 Author Posted December 29, 2016 Hi - can you tell me the path to the log files please - the server will not start now (Http error 502 bad gateway in the freenas console log) i'll be soooooo happy to see the back of FreeNAS
Happy2Play 9801 Posted December 29, 2016 Posted December 29, 2016 Hi - can you tell me the path to the log files please - the server will not start now (Http error 502 bad gateway in the freenas console log) i'll be soooooo happy to see the back of FreeNAS Go to the Dashboard and look at the "Paths" drop down section.
ebr 16307 Posted December 29, 2016 Posted December 29, 2016 Since his server won't start, he can't get there now. However, all the log is probably going to tell us now is that same "Bad Gateway" message on any attempt to get out. So, the issue is that the app cannot access the network.
grizlyadams 19 Posted December 29, 2016 Author Posted December 29, 2016 (edited) Since his server won't start, he can't get there now. However, all the log is probably going to tell us now is that same "Bad Gateway" message on any attempt to get out. So, the issue is that the app cannot access the network. Correct - can't get to the dashboard. i had to change some permissions to get btsync to work - I'm guessing that broke Emby - i can't see how though as the perms i changed were nothing to do with Emby, they were just on the Media shares. So my situation now is that I have less than no interest in getting this godawful FreeNAS/Emby to work ever again, especially after how simple and easy unRaid/docker/Emby was to set up. (I regret ever touching FreeNAS now), but I would like to keep my viewing history for all the users. ( I bought Premier to be able to do the backup/restore and now can't do it. Oh, the irony) Is there any other way to keep the history? thanks Griz Edited December 29, 2016 by grizlyadams
grizlyadams 19 Posted December 29, 2016 Author Posted December 29, 2016 Correct - can't get to the dashboard. i had to change some permissions to get btsync to work - I'm guessing that broke Emby - i can't see how though as the perms i changed were nothing to do with Emby, they were just on the Media shares. So my situation now is that I have less than no interest in getting this godawful FreeNAS/Emby to work ever again, especially after how simple and easy unRaid/docker/Emby was to set up. (I regret ever touching FreeNAS now), but I would like to keep my viewing history for all the users. ( I bought Premier to be able to do the backup/restore and now can't do it. Oh, the irony) Is there any other way to keep the history? thanks Griz quick update - its the jail that's broken. I created another jail with btsync in and it works fine.
Luke 42186 Posted December 30, 2016 Posted December 30, 2016 hi @@grizlyadams, what you can try to do is grab the userdata_v2.db file from your old install. then on the new install, copy that into the data folder. then delete the library.db file and startup the server. let us know if this helps. thanks !
grizlyadams 19 Posted December 31, 2016 Author Posted December 31, 2016 hi @@grizlyadams, what you can try to do is grab the userdata_v2.db file from your old install. then on the new install, copy that into the data folder. then delete the library.db file and startup the server. let us know if this helps. thanks ! thanks for the suggestion - sadly, freeNAS has helpfully destroyed the jail when I tired to reinstall Emby so, somewhat inevitably, i'm back to scratch. Looking forward to a life without FreeNAS thanks Griz
