Flashing an LSI SAS card to IT
PenkethBoy
No, it's stuck like that. If I check it and hit set, it doesn't retain the setting. It goes right back to that  :blink:
Probably because the disk does not support Adv Pow Man - check on the Disk Details in Scanner
But i dont think its your problem as the HGST drives do have APM and i do not have it set either and they do go into standby
PenkethBoy
I does happen - not that it helps  :P
Guest asrequested
lol...I don't seem to have that column. I was looking for it. I just disabled the windows search, and rebooted
PenkethBoy
see post #44 !  :P
Guest asrequested
I got it. I had it disabled. And presently they are all active.....I'm removing the indexing BS :)
PenkethBoy
ok hopefully you are close to getting it sorted
as a test set the spindown in win10 power management to a short period and see if each disk goes to sleep
did you remove the indexing on every drive?
Guest asrequested
I'm in the process. I have to use disk management, as they don't have drive letters.
PenkethBoy
yeah will take time if you have lots of small files
Guest asrequested
The music is the worst, but it seems to be quick enough. I don't have anywhere near what you have :)
  • Like 1
PenkethBoy
right will leave you too it and check back in later
Guest asrequested
Well, even selecting to put the drives into standby, they keep moving right along. So I think that there is no direct control of the drives, through software. I'll have to see if I can update the firmware...
Guest asrequested
I was able to update the firmware on my backup server,last night. It only has one card, and now it boots much quicker :) When I tried it on the main server, it came back with could not find any LSI devices. I have a feeling its because there are two. They are both present in the device manager. This may also be why there is no power control. I'm going to pull one, today, and try updating it. If that works, I'll test the power control. I may need to use an expander. Not a big deal. I hope I'm right.
PenkethBoy
Could be - i only have one with a HP expander - in my 2012r2 server
Guest asrequested
That's a bust. The one I upgraded, I put in the main server by itself. Same thing, the disks just spin, no control what so ever. I've got a SATA card. I'm gonna test with that, and rule out the backplanes. And for whatever reason, I can't update the firmware on the other LSI cards, through windows. I don't think I need to, though. They are both P19
PenkethBoy
IIRC you have to update the bios on the cards in uefi not windows that comes later in the process i detailed early on in this thread a few months ago.
PenkethBoy
You are using this to change the disk sleep option time?
Guest asrequested
Yes. I've tried different times.
The first card updated perfectly, through the command line. The other two, won't. I've got the SATA card in. Running tests
Guest asrequested
Well, I can't explain it. They just don't turn off. The only thing left to try is pull the drives and connect them directly to SATA cables.
Guest asrequested
If I use scanner to put them in standby, I can feel them turn off. But they turn on again, within seconds. I'm trying to narrow it down to what is doing that
Guest asrequested
Apparently there's no way around this, in windows 10. A lot of people have reported the same issue, with no resolution. I've tried every configuration I can come up with. No bueno!
PenkethBoy
hmm odd - but thats MS for you
if i get some time in near future i will pop in a HDD to my win10 machine and give it a go
Guest asrequested
One guy said there was an issue with Intel rapid storage, and the solution was to uninstall it. But I don't have it installed. I'm wondering if its to do with having SSDs and mechanical drives, and there's a bug where it can't tell the different, so it wakes all the drives? I have no evidence, just an idea...
PenkethBoy
irs has been seen to have issue - but no that i have seen for spin down - more crashing/errors
anythings possible i suppose - have you got samsung magician loaded?
Guest asrequested
I looked through everything that's installed, nothing stood out.
PenkethBoy
Just been reading about this
the intel RST drivers - ver 13.6.3.1001 appear to work (spin HDD down) with win10 anything later does not - these are for win 8.1 but work with Win10
Your m/b manufacturer might have them listed for your board
I dont use them at all - dont load them as no need with DP
Edited by PenkethBoy
