snake98 10 Posted December 27, 2016 Posted December 27, 2016 I'm slowly trying to migrate to emby live tv function, but I have waf to worry about. I would like to keep using Serverwmc to only pull recordings from wmc. Is that possible? I got the live tv function working in emby, but the channels get duplicated because of serverwmc. Thanks for a great product.
Luke 42237 Posted December 27, 2016 Posted December 27, 2016 Hi, no, it's not currently possible. I would suggest switching entirely. Let us know how it goes. Thanks !
snake98 10 Posted December 28, 2016 Author Posted December 28, 2016 I wonder if that something krustyreturns could add in on the plugin side. That would be helpful for people migrating between the two without messing the guides up. 1
Luke 42237 Posted December 28, 2016 Posted December 28, 2016 We plan to add channel selection to Emby, so that you could just disable all the channels if that's what you wanted.
krustyreturns 191 Posted December 29, 2016 Posted December 29, 2016 In serverwmc settings file (see debug tab), find 'HideAllChannels' and set it to true. Then save and restart. That might do it.
Luke 42237 Posted December 29, 2016 Posted December 29, 2016 Ah, didn't know about that. That's very useful, thanks !
snake98 10 Posted August 16, 2017 Author Posted August 16, 2017 In serverwmc settings file (see debug tab), find 'HideAllChannels' and set it to true. Then save and restart. That might do it. Just an update to say that works perfect. Thanks
