Magilla 8 Posted December 27, 2016 Posted December 27, 2016 Hello, not sure I'm doing something wrong or I found a small bug in ET (last version installed on a clean Windows 10 PC, together with Emby Server). My PC has three audio devices outputs (speakers, Optical Audio and HDMI). In my case ET completely ignores the WASAPI Audio device setting in the configuration and always plays audio from the default playback device which is setup on my PC. as my TV is connected to my PC via HDMI I assumed I could leave my default playback device on PC to speaker and configure ET to get audio from HDMI when is playing, so that I don't have to change manually the audio device (I use my PC to listen to music when I'm not playing videos with ET). Am I doing something wrong or is a known issue? Thx Magilla Note: PC has no graphic card (using on board Intel HD530)
Solution Guest asrequested Posted December 27, 2016 Solution Posted December 27, 2016 At the bottom you have a selection for your WASAPI device, select your receiver. 1
Magilla 8 Posted December 28, 2016 Author Posted December 28, 2016 Well, this is exactly what I'm doing, but in my case ET ignore my selection and only play sound based on the playback device selected on my Server (ET and Emby Server are on the same PC). I can select "Samsung" below (is the name of my HDMI playback device", but if my PC has "Speakers" as default device I'm not hearing any sound. I did a similar test on another PC which has ET and is connected with my EMBY Server remotely...same result. I was expecting ET could be configured to be independent from the default playback device on the PC, otherwise what's the point? Maybe I'm missing something basic here.... Magilla
Luke 42243 Posted December 28, 2016 Posted December 28, 2016 Can you provide an Emby Theater log from a playback attempt? C:\Users\user\AppData\Roaming\Emby-Theater\logs Thanks.
Guest asrequested Posted December 28, 2016 Posted December 28, 2016 (edited) In my case ET completely ignores the WASAPI Audio device setting in the configuration and always plays audio from the default playback device which is setup on my PC. as my TV is connected to my PC via HDMIYour computer should be connected to your AVR and so should your TV, with HDMI. It's reading your TV, not your AVR. Edited December 28, 2016 by Doofus
Magilla 8 Posted December 29, 2016 Author Posted December 29, 2016 @@Luke, attached the log when I play a short trailer. PC is setup with Speakers as default playback device, while ET has SAMSUNG as default (is the HDMI audio). The audio comes out of PC speakers only. If instead I setup SAMSUMG (HDMI) as default playback device, the audio comes out from the TV set and not from the PC (as I want to) BTW, I managed to force the other audio program (squeezelite) to use speakers as playback device while SAMSUNG (HDMI) is the default, and this setup is ok for my needs. However would be useful to understand what is wrong with my setup @, my PC is connected via HDMI directly to a TV Set and not to an AVR. Sorry if I was not clear. Thanks in advance Magilla theater-63618631053.txt
Guest asrequested Posted December 29, 2016 Posted December 29, 2016 In my case ET completely ignores the WASAPI Audio device setting in the configuration Your WASAPI device is your TV, if you don't want to connect your computer to your AVR. That's what that setting in ET is for. The device info is sent over HDMI. In your case, it's reading your TV. So it's working correctly.
Magilla 8 Posted December 30, 2016 Author Posted December 30, 2016 Sorry guys but I still don't get it... I expect that by selecting the audio device to use inside ET, that would overwrite the default playback device which is configured on the PC and play audio to the WASAPI Device I select. This is the same behavior other media apps have (like squeezeplay which is working as expected on the very same PC). If my expectation is correct, then ET is not working correctly for me. if my expectation is wrong, then I don't understand the feature to enable WASAPI Audio selection inside ET. ...and...is not that I don't want to connect my PC to my AVR....is that I don't have/need an AVR to use ET on my TV Magilla
Guest asrequested Posted December 30, 2016 Posted December 30, 2016 (edited) OK, can you please specify exactly what you are trying to achieve? And post a screenshot of your audio settings in ET. Edited December 31, 2016 by Doofus
Magilla 8 Posted January 1, 2017 Author Posted January 1, 2017 Hi @Dofuss, and Happy New Year! I was pretty sure I was doing something wrong and I've found it this morning In essence, I was selecting the WASAPI Audio Device I wanted but I did not change the Audio Renderer in ET Audio Options...By selecting WASAPI as audio renderer then ET Works as I expected and wanted Apologies for the confusion created, I should have noticed it before. Thanks anyway for trying to help me and for everything you do to build and expand a great Media platform and ecosystem like Emby. Magilla
Guest asrequested Posted January 1, 2017 Posted January 1, 2017 I had a feeling that was the case. I'm glad you figured it out. Happy New Year! 1
