wedgekc 12 Posted January 3, 2017 Posted January 3, 2017 For a temporary fix, I downloaded a previous build from Github (https://github.com/MediaBrowser/Emby.Releases/commit/d81288e950093de9badd2f05c6da97e923a7119a). It solved the "blurry" video problem and the logo issue. I know it doesn't help for resolving the issue but it stopped the kids from whining.
maegibbons 1287 Posted January 3, 2017 Posted January 3, 2017 2.8.39 still shows icon for me :-( On BOTH LiveTV and recordings. In android mobile, where does it show the version number? At the moment I have to look at the Dashboard on another PC to verify the client version. Krs Mar
tobedeleted 4 Posted January 3, 2017 Posted January 3, 2017 How do I get the beta version? Is there any direct download, as I don't use Google services?
tobedeleted 4 Posted January 4, 2017 Posted January 4, 2017 2.8.39 doesn't show the logo for the first video. Every following video playback is unusable because of the logo...
revengineer 142 Posted January 5, 2017 Posted January 5, 2017 (edited) Same problem here. This started a few days ago on the beta. I left the beta channel and installed the stable app. worked for a few days until yesterday when the emby app updated. since then the stable app has the same problem. I see the problem with live tv but not with playing movies. Please post link to previous apk while fix the issue. Thanks. EDIT: Hm weird, the problem is hit or miss, not 100% reproducible. Edited January 5, 2017 by revengineer
Scott D 69 Posted January 5, 2017 Posted January 5, 2017 (edited) Having the same problem here. I have found that if you force transcoding by lowering the bit rate the logo will go away. Auto play of next episode does not work. Will start the process and then hang with --:-- displayed. Found that 2.8.19 does not have any of the above problems. Edited January 5, 2017 by Scott D
tobedeleted 4 Posted January 5, 2017 Posted January 5, 2017 (edited) Any place where I can download the old, working APK? Edited January 5, 2017 by Larx
Scott D 69 Posted January 5, 2017 Posted January 5, 2017 Any place where I can download the old, working APK? http://apkbeast.com/com.mb.android/
haeffnkr 3 Posted January 6, 2017 Posted January 6, 2017 I am seeing the static logo on my S5 during live TV. I have the latest version from the play store. Any update on the fix? thanks haeffnkr
tobedeleted 4 Posted January 6, 2017 Posted January 6, 2017 Just for the record: The current beta version doesn't work, either. Unfortunately there is no way of getting the current version number from within the app.
revengineer 142 Posted January 7, 2017 Posted January 7, 2017 http://apkbeast.com/com.mb.android/ I prefer the developers provide the apk on the emby website. I am not a fan of these uncontrolled repositories because of malware danger. 1
tobedeleted 4 Posted January 7, 2017 Posted January 7, 2017 Fully ACK!!! Emby developers, please think about that!!
Scott D 69 Posted January 7, 2017 Posted January 7, 2017 I prefer the developers provide the apk on the emby website. I am not a fan of these uncontrolled repositories because of malware danger. True, but not many options for pulling an old version. I haven't had any bad experience at this site. (So far). It would be nice to have an "official" apk.
Luke 42243 Posted January 8, 2017 Posted January 8, 2017 Please try 2.8.40 which is headed up to the open beta. Thanks !
revengineer 142 Posted January 8, 2017 Posted January 8, 2017 Luke, I tried one movie and three different life TV shows and it appears the issue is fixed. Just in time for my next business trip. Thank you!
rikiwi 32 Posted January 8, 2017 Posted January 8, 2017 Yes the logo has gone which is great. But I'm still getting stuttery audio unless I change from stereo to English Dolby 5.1. Also turning subtitles on and off is erratic resulting in crash. Sorry I can't be more helpful with logs as I'm not sure how to do this using Tapatalk app, and I'm not well enough to get out of bed at the moment. Sent from my D6653 using Tapatalk
maegibbons 1287 Posted January 8, 2017 Posted January 8, 2017 Looks as though you took drastic action!! Logo does not appear at all now - its been nuked (or us that luked)! Which is a lot better than just sitting in the middle of the screen. Thanks Mark
revengineer 142 Posted January 8, 2017 Posted January 8, 2017 Yes the logo has gone which is great. But I'm still getting stuttery audio unless I change from stereo to English Dolby 5.1. Also turning subtitles on and off is erratic resulting in crash. Sorry I can't be more helpful with logs as I'm not sure how to do this using Tapatalk app, and I'm not well enough to get out of bed at the moment. Sent from my D6653 using Tapatalk I suggest creating a separate post for this. It's off-topic here and your input may get lost in this thread.
rikiwi 32 Posted January 8, 2017 Posted January 8, 2017 Will do, but maybe a while before I get to my PC server to post decent report with logs. Sent from my D6653 using Tapatalk
