Luke 42243 Posted December 30, 2016 Posted December 30, 2016 it's still playing from the server wmc urls, try refreshing the guide data.
PrincessClevage 175 Posted December 30, 2016 Author Posted December 30, 2016 (edited) it's still playing from the server wmc urls, try refreshing the guide data.I have always had the play recordings using url un ticked. In previous version tiles used to populate with images similar to recordings view and ff and rw work when playing though live tv view Edited December 30, 2016 by PrincessClevage
krustyreturns 191 Posted December 30, 2016 Posted December 30, 2016 @@PrincessClevage, please restart serverwmc then post its log (see debug tab) after trying to play a recording.
PrincessClevage 175 Posted December 30, 2016 Author Posted December 30, 2016 @@PrincessClevage, please restart serverwmc then post its log (see debug tab) after trying to play a recording. ServerWMC log attached ServerWMC.log
krustyreturns 191 Posted December 31, 2016 Posted December 31, 2016 On the debug tab of serverwmc DO NOT CHECK 'remux the playback of all wtv files'. That is only there as an option for debugging purposes. You may need to restart serverwmc and emby after the change. If it still doesn't work post the serverwmc log again.
PrincessClevage 175 Posted December 31, 2016 Author Posted December 31, 2016 (edited) On the debug tab of serverwmc DO NOT CHECK 'remux the playback of all wtv files'. That is only there as an option for debugging purposes. You may need to restart serverwmc and emby after the change. If it still doesn't work post the serverwmc log again.Still the same, made the change, restarted Emby service, ET and Serverwmc ServerWMC2.txt Edited December 31, 2016 by PrincessClevage
PrincessClevage 175 Posted December 31, 2016 Author Posted December 31, 2016 Is it also possible to move the tempswmc folder from the recordings folder or this is something done by WMC?
krustyreturns 191 Posted December 31, 2016 Posted December 31, 2016 Did you make the change by editing the settings file? Because if you did, you did it wrong. This is what the log file shows: 2016/12/31 10:53:35.774 RemuxActiveRecordings: False >>Default: True 2016/12/31 10:53:35.774 Debug_RemuxAllRecordings: True >>Default: False RemuxActiveRecordings should be true Debug_RemuxAllRecordings should be false.
PrincessClevage 175 Posted December 31, 2016 Author Posted December 31, 2016 (edited) Did you make the change by editing the settings file? Because if you did, you did it wrong. This is what the log file shows: 2016/12/31 10:53:35.774 RemuxActiveRecordings: False >>Default: True 2016/12/31 10:53:35.774 Debug_RemuxAllRecordings: True >>Default: False RemuxActiveRecordings should be true Debug_RemuxAllRecordings should be false. No just un ticket the "remux active recordings" check box under the "recordings "tab in Serverwmc Edited December 31, 2016 by PrincessClevage
PrincessClevage 175 Posted December 31, 2016 Author Posted December 31, 2016 (edited) Did you make the change by editing the settings file? Because if you did, you did it wrong. This is what the log file shows: 2016/12/31 10:53:35.774 RemuxActiveRecordings: False >>Default: True 2016/12/31 10:53:35.774 Debug_RemuxAllRecordings: True >>Default: False RemuxActiveRecordings should be true Debug_RemuxAllRecordings should be false. I have changed these two settings in the config file and now live tv is playing correctly with ff and rw options and images have been refreshed and displaying correctly.Thanks a lot for the quick support! P.s I am not sure how this setting changed as I have only ever used the gui and there does not seem to be change value for debug_Remuxallrecordings Edited December 31, 2016 by PrincessClevage
krustyreturns 191 Posted December 31, 2016 Posted December 31, 2016 I don't what happened either, but I am glad you got it working.
