hokey1 0 Posted December 26, 2016 Posted December 26, 2016 On my android box (shield) when I use a standalone IPTV app like perfect viewer or progtv the channels pop up usually around 3 to 5 seconds. When using emby on the same box it could take 15 seconds or longer or sometimes never. I can go right back to perfect viewer and the stream, or any stream pops right up. Same problem happens on my windows PC. If I use a web interface my IPTV pops right up, on the emby web client or emby theater it is very slow and sometimes never happens. I am open to any suggestions. Attached is my server log server.txt
Luke 42242 Posted December 26, 2016 Posted December 26, 2016 Hi, can you please discuss what you did during the timeframe of this log? if an ffmpeg log was also created, please attach that as well. thanks.
hokey1 0 Posted December 26, 2016 Author Posted December 26, 2016 Mainly clicking on channels via the tvguide. And then waiting for the channels to come in. I only used the Web interface and the emby theater (on same pc) during this time (I think) Where can I find the ffmpeg logs?
Luke 42242 Posted December 26, 2016 Posted December 26, 2016 in the same folder as the regular server log, thanks.
hokey1 0 Posted December 27, 2016 Author Posted December 27, 2016 Here it is: Thanks for looking into this. ffmpeg.txt
