rholborok 4 Posted December 26, 2016 Posted December 26, 2016 When using the Android app only with my hdhomerun it leaves the emby app logo on the stream. Attaching screenshot. If I play it on a external player it works . On the Android TV app when I play live tv using my hdhomerun I get no audio unless I click the ! Symbol. Any suggestions?
maegibbons 1287 Posted December 26, 2016 Posted December 26, 2016 There is currently a bug with android app showing logo when playing recordings. Re Android tv/Homerun go in settings and check audio mode is direct. Also In live tv setting section check that is direct stream is ticked and try to use VLC is ticked. Works for me Krs Mark
Luke 42242 Posted December 27, 2016 Posted December 27, 2016 An update is rolling out to resolve the loading spinner logo. thanks.
