Disorganise 15 Posted January 28, 2014 Posted January 28, 2014 I'd like to see the Android app being able to be used as a traditional remote. ie generating the keyboard presses to navigate MB classic and theatre. I have media centre control which is an android app that navigates WMC which is great, but it fails once MBC starts. it's much easier showing details on the big screen than handing the phone around. cheers Sent from my GT-I9305 using Forum Fiend v1.1.7.
Redshirt 1487 Posted January 28, 2014 Posted January 28, 2014 The server would need to be modified to support this, but I'm willing to do my part if/when the time comes.
Luke 42241 Posted January 28, 2014 Posted January 28, 2014 well i think we would just do the flick to bring up the play to function. as far as actually telling the ui fling it, i'm not so sure because not all of them will be able to do that. so that part is probably not worth the effort.
kamakamadaun 6 Posted February 2, 2014 Posted February 2, 2014 Would it be possible to somehow access the controls of a file you have started on another client? Right when you start a file on another client you get basic controls. but if you exit I cannot find a way to get back the controls.
Disorganise 15 Posted February 2, 2014 Author Posted February 2, 2014 Well I've just discovered that my Media Centre Control app does navigate Media Browser Classic. Previously the mcc plug in was failing after MB fired up but it seems to be OK. changes being removal of my movies and update of MBC. It was something that was said in another thread about the fact that there's no player in MB, it hands off to WMC that got me to retry. So I'm happy for now....but would like to see it in the MB android app at some point Sent from my GT-I9305 using Forum Fiend v1.1.7.
trusselo 225 Posted February 2, 2014 Posted February 2, 2014 Try Unified Remote, it can control WMC (MBC) also on our site, in the tools section, there is a MBT plugin/remote for unified remote, It works fine for MBC as well, except for the colored buttons. http://mediabrowser.tv/community/index.php?/topic/3487-media-browser-3-controls-for-unified-remote/
kamakamadaun 6 Posted February 26, 2014 Posted February 26, 2014 I am using unified remote when needed. It would just be nice to be able to get back to the controls in the android client so I don't have to change program. It will be even more important when chromecast arrives.
