GoldFiNNger 1 Posted December 24, 2016 Posted December 24, 2016 When importing audio files with a "/" (forward-slash) in the name, it will import them into two genres. (e.g., Rap/Hip-Hop → Rap and Hip-Hop) After clearing the genres (through Emby) and adding a genre name with a "/" in it, it will split into two genres, BUT the genres will NOT be shown in the "Genres" subsection. [see attachment 01] - When I clip on the genre "Hip-Hop" or "Rap" on the album's page, it will load a blank screen with the full (slash included) genre name on top [see attachment 02] It's a minor issue, but a nuisance. Now, I cannot access music from the "genres subsection" if their genres included "slashes". It would be nice to either (1) allow special characters like "slashes" in genre names, or (2) employ a feedback mechanism that prevents the use of slashes in genre names & notifies the user in real-time when attempting to add a genre with a "/", or other special characters in it.
GoldFiNNger 1 Posted December 25, 2016 Author Posted December 25, 2016 UPDATE - Genre cleaner was installed upon initial music import. - I've uninstalled Genre Cleaner - I've removed the Music folders, passed them through MusicBrainz Picard to correct Metadata, then readied Music folders - PROBLEM = still, genres with "/" in their name are not being displayed on the genres subsection * NOTE - I can still filter by "Rap" and "Hip-Hop" individually using Emby's filter function, it's just that the genre does not show up in the genres subsection, neither as one (Rap/Hip-Hop), nor two separate genres (Rap + Hip-Hop)
Solution Luke 42186 Posted December 26, 2016 Solution Posted December 26, 2016 Hi @@GoldFiNNger, when parsing music tags, this is by design as the / character is commonly used as a delimiter. @@ginjaninja You can however manually add genres with a /. The editing worked fine for me as far as showing up in genres, but with a caveat - it did not show up in the genres view until after the next library scan. that's something we can look at improving for a future release so that you don't need to do that. 2
GoldFiNNger 1 Posted December 26, 2016 Author Posted December 26, 2016 Subsequent library scans didn't help make those genres visible in the genres view. I've tried removing them from the Library, performing a clean database function, re-entering the metadata with Picard, then importing them a new to no avail. I even tried using Emby's metadata editor. Good news is that Kodi's genres view does display the /-delimited genres as separate genres, which I can live with peacefully. ________ It would be hIghly appreciated if you, or anybody else, can help direct me as to how to add genres while preventing the / from behaving as a delimiter. Definitely not a high-priority issue, but I hope Emby apps can display these genres at least as Kodi currently does in the future.
Luke 42186 Posted December 26, 2016 Posted December 26, 2016 In your audio tags try using a semi-colon for a delimiter.
Luke 42186 Posted December 26, 2016 Posted December 26, 2016 As far as newly added genres not showing up after a library scan. I tested with the web app, and no problem found. The genre showed up in the Genres tab. Thanks !
GoldFiNNger 1 Posted December 26, 2016 Author Posted December 26, 2016 As far as newly added genres not showing up after a library scan. I tested with the web app, and no problem found. The genre showed up in the Genres tab. Thanks ! Thanks @@Luke, I'll play around with it again and look at the logs more closely when I find the free time to tinker, and I'll update you if I'm still hitting a wall
GoldFiNNger 1 Posted December 27, 2016 Author Posted December 27, 2016 In your audio tags try using a semi-colon for a delimiter. For anybody confronted with the same issue, save yourself from the hassle and just use another character to separate the genres, unless you're insistent on importing multi-genre tracks. I know how OCD some of us can get when organizing music libraries, and how ugly a semicolon ( ; ) might look, but there are plenty other characters you can use that will allow you to not lose sleep at night. Try an ampersand ( & ) instead, personally my favorite and looks good in all my apps. All is running smoothly now. Though, with some work, it is possible to use the ( / ) without it behaving like a delimiter, I highly recommend you follow @@Luke's suggestion and use any other symbol that won't drive you crazy in the interest of long-term stability and cross-app/platform compatibility.
