Adminelite 4 Posted January 5, 2022 Posted January 5, 2022 6 minutes ago, darkside40 said: If thats the user on the working dlls, what do you think? Sorry but do you think it is a good idea to ssh into your NAS as root, where posssibly could break anything, if you are obviously not know what you are doing? I know.... but it is not possible for normal users
darkside40 108 Posted January 5, 2022 Posted January 5, 2022 You know that this does not work because you are not logged in as root? So you dont have write permissions on that folder. Sorry but if somebody give itself the nickname "Adminelite" i suspect that he knows the absolute basic's how to work on the command line. You only need to login as root, than use cp to copy the dll into the plugin folder, use chown to give it to the right owner and that should be everything. Nothing special. Then restart the Emby Server. If it does not appear than i would suggest having a look at the Emby Log, if it complains about that DLL for some kind of reason. I hope you are on the latest Stable Version of Emby.
Adminelite 4 Posted January 6, 2022 Posted January 6, 2022 14 hours ago, darkside40 said: You know that this does not work because you are not logged in as root? So you dont have write permissions on that folder. Sorry but if somebody give itself the nickname "Adminelite" i suspect that he knows the absolute basic's how to work on the command line. You only need to login as root, than use cp to copy the dll into the plugin folder, use chown to give it to the right owner and that should be everything. Nothing special. Then restart the Emby Server. If it does not appear than i would suggest having a look at the Emby Log, if it complains about that DLL for some kind of reason. I hope you are on the latest Stable Version of Emby. It works thank you
darkside40 108 Posted January 22, 2022 Posted January 22, 2022 Okay i created a new thread alongside with the newest version of the plugin: If you have any question, please use that thread.
