MindBullet 93 Posted July 28, 2018 Posted July 28, 2018 (edited) @@darkside40 great job! Working flawlessly on 3.5.0.1 over here Do you think there's a chance to add more variaty to messages? What I'd love to see would be a "Recently added" notification, which shoots, when there's something added to the server. Do you think that's possible? Kind regards Also I think it would be great to fix the textfield misbehavior. If you once added a Chat ID or token for a specific user you can't go back. If you once saved it and then want to disable it for this user, you can't save it, because it's asking you to fill in the token. Only way out seems to be reinstalling it Cheers Edited July 28, 2018 by GodOnEmby
darkside40 108 Posted August 2, 2019 Posted August 2, 2019 @@Luke what would be needed to get that Plugin into the Emby Plugin Catalog. It works so far for one year now for me. I know there are some issues to be targeted, for example that sometimes only a filename is posted, instead of the movie name, but i first have to find out if this is a problem only to this plugin.
ebr 16332 Posted August 2, 2019 Posted August 2, 2019 @@Luke what would be needed to get that Plugin into the Emby Plugin Catalog. It works so far for one year now for me. I know there are some issues to be targeted, for example that sometimes only a filename is posted, instead of the movie name, but i first have to find out if this is a problem only to this plugin. A developer willing to fully support it. That means keep it up to date with server versions as well as fix any issues and respond to user help requests. Do we have that for this plug-in?
darkside40 108 Posted August 6, 2019 Posted August 6, 2019 First of all i think i will try to resolve some issues with the plugin, like improper URL encoding or missing rate limiting.
darkside40 108 Posted August 13, 2019 Posted August 13, 2019 (edited) Okay pushed a new Version to the repo addressing the problem with inproper URL encoding: https://github.com/bjoerns1983/Emby.Plugin.TelegramNotification/releases Next issue is moving to newer .netstandard2.0 and a newer Emby Server Core. Edited August 13, 2019 by darkside40
darkside40 108 Posted August 22, 2019 Posted August 22, 2019 New version is online: https://github.com/bjoerns1983/Emby.Plugin.TelegramNotification/releases/tag/v1.1.0.0
StewieGreen 160 Posted August 24, 2019 Posted August 24, 2019 Thanks for resurrecting this, I just tried it out last night and it works great. Only issue I've had is that apostrophes don't show properly so "Adam's" turns into "Adam's".
darkside40 108 Posted August 24, 2019 Posted August 24, 2019 Thanks for the info, i have a look at it in the next couple of days.
StewieGreen 160 Posted August 24, 2019 Posted August 24, 2019 Another thing, when I pause a show I get a notification saying that the show has finished (which it hasn't). and when I play it doesn't say it's playing again
darkside40 108 Posted August 25, 2019 Posted August 25, 2019 That is no problem of the plugin, because it just forwards the messages it gets from the notification framework.
gewbert 2 Posted August 25, 2019 Posted August 25, 2019 Thanks very much for this! Is there any chance of getting the ability to send cover art with the message? I have a friend who uses Plex and his channel puts out a message like this when something is added.
darkside40 108 Posted August 25, 2019 Posted August 25, 2019 In the moment it is not possible to add Coverart to the message. Thats another limitation of the Emby Notification Framework, see here: https://emby.media/community/index.php?/topic/76676-sending-a-picture-in-an-notification/
darkside40 108 Posted August 25, 2019 Posted August 25, 2019 (edited) Thanks for resurrecting this, I just tried it out last night and it works great. Only issue I've had is that apostrophes don't show properly so "Adam's" turns into "Adam's". Hi there, i just tried it by modifying the Test Message and the apostrophe was correct escaped. Are you using the latest Version of the Plugin? Edited August 25, 2019 by darkside40
StewieGreen 160 Posted August 25, 2019 Posted August 25, 2019 I did some digging and that's how the default fire tv name appears to Emby, so I changed its display name (which I didn't know I could do until now).
dual-o 19 Posted March 24, 2020 Posted March 24, 2020 Since several days the "new media report" didn't work. Got anybody the problem too? 1
vincentmarles 0 Posted March 25, 2020 Posted March 25, 2020 hello, it does not work for me the test is ok but not the carry over of new content
vincentmarles 0 Posted March 25, 2020 Posted March 25, 2020 it works it's good, but it's not possible to have the covers on it? because here I just have the name of the movie that was downloaded but nothing else.
dual-o 19 Posted March 25, 2020 Posted March 25, 2020 Which Emby Version are you using. Newest one (4.40) Find out whe i uncheck notifications for "New Media Report" and check it again it works ... will check this ne next days... I think its a "Playback Report" Issue
darkside40 108 Posted March 25, 2020 Posted March 25, 2020 it works it's good, but it's not possible to have the covers on it? because here I just have the name of the movie that was downloaded but nothing else. Covers are not possible because the internal Notification Function of Emby does not support it.
vincentmarles 0 Posted March 25, 2020 Posted March 25, 2020 (edited) Edited March 25, 2020 by vincentmarles
darkside40 108 Posted March 25, 2020 Posted March 25, 2020 Updated my own Docker to 4.4.040 with Playback Report 1.6.9.1. No issues. The Plugin works as expected.
pir8radio 1313 Posted March 25, 2020 Posted March 25, 2020 who is using telegram anyway, discord is where it's at... (im just kidding btw, dont get riled up) You could take the alert title and run it through one of the movie database api's to get the cover image.
