Danee 57 Posted January 27, 2014 Posted January 27, 2014 Hello, Is there a maximum number of items in a boxset? I've just installed the boxset plugin and it works great (thumbs up for that one!). I do however have a problem in the webclient and mbt: my James Bond boxset only shows 18 movies while there are 23 on my server. I've checked the auto created boxset folder and there all movies are shown and all shortcuts work. I've checked the info for all movies and they all show the correct tmdb collection id (645). Is this a known issue?
ebr 16354 Posted January 27, 2014 Posted January 27, 2014 No, there is no limit. Can you please provide screenshots of what you are seeing? 1
yardameus 221 Posted January 27, 2014 Posted January 27, 2014 Are the ones that don't show missing the Set Title (or collection or whatever it's called) label? 1
bigjohn 754 Posted January 27, 2014 Posted January 27, 2014 Must be a problem somewhere in your metadata. All 24 Bond movies show up in my boxset in the web client. Don't know about MBT, but I can check when I get home. 1
jordy 284 Posted January 28, 2014 Posted January 28, 2014 Hi, I have a similar issue with the James Bond collection. I have two versions of Casino Royale 1967 and 2006. The Boxsets plugin is picking both up and providing the mblink (see pic) but the web browser and MBC only show the 1967 version. I have checked all meta data and re-run the library scan and Boxset scan several times but the 2006 version still does not appear in the web browser or MBC. Perhaps a duplicate movie name issue although I would think the the bracketed year attached to the file name and mblink should take care of that. Thanks for looking
Danee 57 Posted January 28, 2014 Author Posted January 28, 2014 Well, I've checked and rechecked the data of all movies, all was good, finally I decided to empty out the boxset folder and let the plugin rescan my movies, that fixed it! Thanks for all help anyways! 1
jordy 284 Posted January 28, 2014 Posted January 28, 2014 @@Danee I tried your suggestion and it worked, both Casino Royale movies are now listed in the web client, so thanks for the tip.
