Luke 42238 Posted August 13, 2017 Posted August 13, 2017 @@haraldov you shouldn't need the -enable-transparent-visual
geaves 13 Posted August 13, 2017 Posted August 13, 2017 Use the command whereis for searching in the path pi@raspberrypi:~/emby-theater-electron $ whereis electron electron: /usr/lib/electron /usr/local/bin/electron /opt/nodejs/bin/electron Edit et.sh and write in the correct electron path like this: /usr/local/bin/electron --enable-transparent-visual main.js /opt/nodejs/bin/electron works.....but this # After ET startup choose Setting --> Video Setting --> Hardware acceleration mode --> RPI I don't see this, it's all windows options.....
haraldov 10 Posted August 14, 2017 Posted August 14, 2017 (edited) @@Luke Here is my et.sh without -enable-transparent-visual. Works without problem. Thanks for the tip. #!/bin/bash # The command xset are available when you install the package x11-xserver-utils # sudo apt install x11-xserver-utils xset s off # don't activate screensaver xset -dpms # disable DPMS (Energy Star) features. xset s noblank # don't blank the video device # sudo apt install xdotool xdotool mousemove 2000 2000 electron main.js @@geaves After ET startup choose Setting --> Video Setting --> Hardware acceleration mode --> RPI I don't see this, it's all windows options..... Have you done a update of the repository? pi@raspberrypi:~ $ cd emby-theater-electron/ pi@raspberrypi:~/emby-theater-electron $ git pull Already up-to-date. pi@raspberrypi:~/emby-theater-electron $ Edited August 14, 2017 by haraldov
geaves 13 Posted August 14, 2017 Posted August 14, 2017 @@Luke Here is my et.sh without -enable-transparent-visual. Works without problem. Thanks for the tip. #!/bin/bash # The command xset are available when you install the package x11-xserver-utils # sudo apt install x11-xserver-utils xset s off # don't activate screensaver xset -dpms # disable DPMS (Energy Star) features. xset s noblank # don't blank the video device # sudo apt install xdotool xdotool mousemove 2000 2000 electron main.js @@geaves Have you done a update of the repository? pi@raspberrypi:~ $ cd emby-theater-electron/ pi@raspberrypi:~/emby-theater-electron $ git pull Already up-to-date. pi@raspberrypi:~/emby-theater-electron $ That returns the same as above
haraldov 10 Posted August 14, 2017 Posted August 14, 2017 @@geaves As a workaround for the missing RPI option in ET you can make a mpv.config with the same mpv option for rpi video output. pi@raspberrypi:~ $ mkdir .config/mpv pi@raspberrypi:~ $ touch .config/mpv/mpv.conf Here are mine choosen mpv option # Use rpi video output by default. vo=opengl # Use rpi hardware acceleration #hwdec=rpi # Mpv start up fullscreen fs # No youtube-dl intergration no-ytdl # No probing of the video stream demuxer-lavf-probe-info=no
Luke 42238 Posted August 14, 2017 Posted August 14, 2017 The rpi and rpi-copy options should be there.
geaves 13 Posted August 15, 2017 Posted August 15, 2017 Ok this is working now, complete with RPI hardware set however as of yet I don't have a Premiere, so the 1 minute timer seems to stop a movie playing, (I thought this was set for 5 originally) although it attempts too, but it's 'windowed' obviously there is something to set for full screen will backtrack to see if I can find anything.....running from the chromium browser and signing into emby this does work as I expected.
denz 501 Posted August 15, 2017 Posted August 15, 2017 (edited) I gave it another go I have upgraded to debian scratch installed mpv no errors but video is so slow. I then compiled new mpv build per instructions by haraldov installed it installs mpv in the same location but still the same error. Edit: Restarted my pi run emby theater no error and live tv starts faster than my i5 kaby lake pc both hd and sd channels. What a huge excercise at least it is working now will give it a lot of testing on the weekend. Edited August 15, 2017 by denz
denz 501 Posted August 16, 2017 Posted August 16, 2017 It is very impressive so far Very strange issue the first time I start theatre no issues close theatre start it again error that I previously have pops up try to play something just a spinning circle start again same issues restart pi start it again no issue close theatre start again error again nothing plays restart pi again start theatre works again I have done this 8 times and the same thing happens. I thought Linux is not like windows. Out of the 16 channels only two are not getting displayed properly the deinterlace is not being applied and after so many start and stopping live tv and recorded tv have managed to freeze the pi video is frozen and keyboard is not responding.
Luke 42238 Posted August 16, 2017 Posted August 16, 2017 Are you closing the app with video still playing?
denz 501 Posted August 17, 2017 Posted August 17, 2017 (edited) I did more testing I discovered the issue with frozen picture is to do with keyboard not responding i keep pressing buttons to find which one will exit mpv but none work so as i am pressing i eventually press pause so i think it is frozen but it is not and after some seconds keyboard starts responding but still only pause and play button works so the only way to recover is to use putty to shutdown mpv. I have managed to reproduce this few times but it seems random and i think it is related to error below. Regarding the mpv I have removed everything this time noticed that apt-get was letting me know to use autoremove so I did and that removed ffmpeg etc and then I installed 0.26 version and have only managed to reproduce the error twice and the only way to recover is to restart but it wasn't the same error it is actually different. Edited August 17, 2017 by denz
denz 501 Posted August 19, 2017 Posted August 19, 2017 I have tried it with clean install of raspbian stretch as it was just released and this time theater can´t find the built in mpv or the one I compiled. I have even tried copying mpv to emby-theater-electron folder and still the same. Where the hell is it looking for it.
haraldov 10 Posted August 20, 2017 Posted August 20, 2017 (edited) theater can´t find the built in mpv or the one I compiled @denz Have you remembered to install the node-mpv package? I have done a clean install of raspbian stretch and I have no problem to use ET with this release. But the install of the node-mpv package gives a error message about No license field. pi@raspberrypi:~/emby-theater-electron/node_modules $ npm install node-mpv/ npm WARN package.json node-mpv@1.0.3 No license field. node-mpv@1.0.3 node-mpv ├── promise@7.3.1 (asap@2.0.6) ├── cuid@1.3.8 (node-fingerprint@0.0.2, browser-fingerprint@0.0.1, core-js@1.2.7) └── lodash@4.17.4 pi@raspberrypi:~/emby-theater-electron/node_modules $ Edited August 20, 2017 by haraldov
haraldov 10 Posted August 20, 2017 Posted August 20, 2017 (edited) Videos play and I am able to control them -- BUT... there are no onscreen controls displayed. Mpv(git) seems to render in the top most layer with nothing else being able to be overlayed on that layer. This also happens if I start mpv from the desktop not in fs mode -- it renders the movie, but you can not place another window over the render. I see the same problem with ET as @@mitomac reported. When I use the mpv fullscreen option mpv play the video fullscreen in ET. But the onscreen control do not display. Without the mpv fullscreen option the video play in the middel of the screen and it is half in size. The onscreen control displays under the video. Edited August 20, 2017 by haraldov
denz 501 Posted August 20, 2017 Posted August 20, 2017 I installed stretch again and I am noticing that your version is different than mine. pi@raspberrypi:~/emby-theater-electron $ npm install node-mpv node-mpv@1.2.1 node_modules/node-mpv ├── promise@7.3.1 (asap@2.0.6) ├── cuid@1.3.8 (node-fingerprint@0.0.2, browser-fingerprint@0.0.1, core-js@1.2.7) └── lodash@4.17.4 pi@raspberrypi:~/emby-theater-electron $ I also installed your version and still the same error.
gene0915 42 Posted August 27, 2017 Posted August 27, 2017 Having problems installing ET on Linux Mint. I followed the steps from the 1st post and ran into some problems: Everything was going good until this step: (note the warnings at the bottom) gene@gene-desktop ~ $ sudo npm install node-mpv/home/gene└─┬ node-mpv@1.3.1 ├─┬ cuid@1.3.8 │ ├── browser-fingerprint@0.0.1 │ ├── core-js@1.2.7 │ └── node-fingerprint@0.0.2 ├── lodash@4.17.4 └─┬ promise@7.3.1 └── asap@2.0.6npm WARN enoent ENOENT: no such file or directory, open '/home/gene/package.json'npm WARN gene No descriptionnpm WARN gene No repository field.npm WARN gene No README datanpm WARN gene No license field.then a few more steps later.....it says to: cd emby-theater-linuxBut I don't have that directory, I have a emby-theater-electron and inside there, I see the et.sh file but when I type ./et.sh, I get:gene@gene-desktop ~/emby-theater-electron $ ./et.shbash: ./et.sh: Permission denied
denz 501 Posted August 27, 2017 Posted August 27, 2017 (edited) you need to go to emby-theater-electron folder and then run sudo npm install node-mpv for the et.sh you need to right click on it and in permissions execute select anyone. Anyone else has issues with mpv running on rpi I still cannot get it to run on pi it is frustrating. I copied mpv file to all bin folders and still nothing. The /tmp/emby.sock file is never created Warning: loadFile() is deprecated. Use load() instead { Error: spawn "main.js" ENOENT at exports._errnoException (util.js:1026:11) at Process.ChildProcess._handle.onexit (internal/child_process.js:193:32) at onErrorNT (internal/child_process.js:359:16) at _combinedTickCallback (internal/process/next_tick.js:74:11) at process._tickCallback (internal/process/next_tick.js:98:9) code: 'ENOENT', errno: 'ENOENT', syscall: 'spawn "main.js"', path: '"main.js"', spawnargs: [ '--input-unix-socket=/tmp/emby.sock', '--idle', '--really-quiet', '--hwdec=no', '--deinterlace=auto', '--video-output-levels=auto', '--audio-channels=auto-safe', '--ad-lavc-ac3drc=0', '--wid=35651585', '--no-osc' ] } { Error: connect ENOENT /tmp/emby.sock at Object.exports._errnoException (util.js:1026:11) at exports._exceptionWithHostPort (util.js:1049:20) at PipeConnectWrap.afterConnect [as oncomplete] (net.js:1081:14) code: 'ENOENT', errno: 'ENOENT', syscall: 'connect', address: '/tmp/emby.sock' } MPV Player seems to have died. Restarting... Edited August 27, 2017 by denz
denz 501 Posted August 29, 2017 Posted August 29, 2017 (edited) I think I am getting somewhere now for some unkown reason when i type npm install node-mpv it downloads the one from the internet and replaces the version that is there and when I type install npm install node-mpv@1.0.3 that again downloads the one from internet it does not install the one that is already there and it produces the mpv error. I tried typing npm ls that gave me what is missing then i went inside node-mpv and run the command to install dependency but again no error in theater only a spinning circle and i can see that no sock file has been created. If I overwrite the node-mpv folder with the custom node-mpv all I get is a spinning circle. Edited August 29, 2017 by denz
denz 501 Posted August 31, 2017 Posted August 31, 2017 I just noticed upon reading haraldov instructions once I remove this --enable-transparent-visuals from et.sh I dont get the error any more. I am compiling mpv from source as the version with stretch is only using software how rubbish is that what is point of including it without rpi support.
haraldov 10 Posted August 31, 2017 Posted August 31, 2017 No HDMI CEC work has been done (I don't have a device to debug with) When trying to run Emby Theater on Raspbian Strech with HDMI-CEC I get an error: # Install HDMI CEC Support sudo apt-get install cec-utils # Run Emby Theater with HDMI-CEC: electron main.js cec-client I have tracked it down to line 110 in cec.js which checks for initialization of the cec-client. // check for initialization if (!initialized) { var dataAsString = data.toString().replace(/\s+/g, ""); var indexOfAdapter = dataAsString.includes("CECclientregistered"); if (indexOfAdapter) { console.log("\nCEC Client successfully registered.\n"); var initVals = dataAsString.split(","); var cecAdapterVals = initVals[4].split("("); var cecBaseVals = initVals[5].split("("); CEC_ADAPTER.device = cecAdapterVals[1].substr(4); CEC_ADAPTER.lAddr = cecAdapterVals[2][0]; console.log("CEC Adapter Device:\t" + JSON.stringify(CEC_ADAPTER, null, " ")); initialized = true; The ET startup log says the CEC Client is successfully registered: Initializing cec-client... { cecExePath: 'cec-client', cecEmitter: EventEmitter { domain: null, _events: {}, _eventsCount: 0, _maxListeners: undefined } } CEC Client successfully registered. cec-client.log et-31082017.log
denz 501 Posted September 2, 2017 Posted September 2, 2017 (edited) To work on rpi stretch you need electron@1.4.16 and also when installing node-mpv you need to type sudo npm install node-mpv@1.0.3 and lastly adjust et.sh to remove the extra commands and have only electron main.js and that is what I missed from the detailed instructions given by @@haraldov Edited September 2, 2017 by denz
haraldov 10 Posted September 2, 2017 Posted September 2, 2017 (edited) Thanks @@denz for feedback. I have updated my instruction https://emby.media/community/index.php?/topic/42868-emby-theater-for-linux/?p=455189 to adjust et.sh to remove the extra commands and use sudo to install the local node-modules. Make sure you install the local node-mpv package and not the package from the npm nodesource because ET is using a customized version https://emby.media/community/index.php?/topic/42868-emby-theater-for-linux/?p=455028 This is specified in package.json and npm install these packages if you are in the directory /home/pi/emby-theater-electron Edited September 2, 2017 by haraldov
Smaky 131 Posted September 2, 2017 Posted September 2, 2017 Just wondering if this version is the one that should be installed on a Raspberry Pi. Should I follow the instructions here or... should I better stick with the old thread on Raspi?
