SHSPVR
10 hours ago, softworkz said:
These will be deprecated without replacement.
So does that mean you're just discontinuing the Emby Theater client and replacing it was just Emby client if that's the case I don't see the problem here as having that package removed and replacing it with the new rebuild client will have to be reinstalled I'm fine with that and I'm sure many other people will be too.
PutzJimmy
We do have AppImage packages, but we're not sure yet about publishing them, because those do not have any update mechanism and this would end up many people using outdated versions.
At least for SteamOS, you can install just normally with our package installer, no need for AppImage.
For Bazzite, it can be installed directly as well - just search the Linux Beta forum for Bazzite.
Bazzite is unsupported and SteamOS just partially, please see here: https://support.emby.media/support/articles/apps/linux/Emby-Linux-Platform-Support.html
On SteamOS, MPV playback is working in desktop mode, but not in Game mode (only with -nompv there).  This is not expected to change, unfortunately.
I would love a flatpak but for now access to the appimage would be awesome, put a warning about "you the user is responsible for updates" or something but dont hold out on us wanting it please 😃
4 hours ago, mmhorda said:
Am i doing sometihng wrong? I can only install it if i remove read-only on the root partition, otherwise i cannot install it.
The problem with this approach (removing read-only) is that Emby will be remove with each new firmware update.
The universal installer supports an unattended mode, which means you can get everything - repo and latest app installed with a single command and no further interaction.
Please see here: Emby Universal Installer
The cool thing about it: This is not really an installer in the typical sense. It's a script which sets up our package repository (APT, RPM, PAC) in the exact same way like you would do it manually for other software, you just don't have to look up and type/copy all those commands to get it done.
I don't really know how one is supposed to deliver apps for SteamOS, because we have limited resources and the Linux audience (for apps, unlike server) is not really that big. It's more like a coincidence that it's even working, because we provide PacMan packages for Arch and SteamOS is based on Arch...
Yea, that's the plan. Snap is not much loved by people anyway. The main benefit is that you can have an app in the software catalog that people can find right away on a fresh OS install by just searching for "emby" in the software center. We probably won't give that up, but rather maybe transform it into something which loads the installer to install new app through the new package repo or similar, we'll see...
  • Thanks 1
The new app is very different from the old one: The legacy app always loads and executes its UI code (htmljs) from an online source, so it's more like when using a browser to app.emby.media - so it was always up-to-date in this regard, but also insecure and subject to a lot of caveats and issues.
The new app is fully self-contained, all code is included and it doesn't depend on any online connectivity. The consequence though, is that it needs to be continuously updateable in an easy way for users - that's the point which our AppImage package doesn't fulfil at the moment. It can be done - but it needs to be done first and it may take a while until we get to it.
Let me think about what we could do meanwhile....
yingste
Unless the Universal Installer has changed since I last used it you still need to disable read only mode in steamos before running the installer:
steamos-readonly disable
 After installing you can turn back on read only mode.
  • Agree 2
mmhorda
This is neat, but unfortunatelly with SteamOS it work untill next OS update. root fylesystem gets overwritten except of /home. so anything installed with pacman will be removed.
If you could detect steamos and install the package (maybe even the AppImage) to  /home/deck/Applications/Emby instead of /opt/Emby.
I can help with testing or even adjust the installer if needed
With  Steam Machine release around the corner it would be good to have Emby working on it too.
PutzJimmy
Yeah its a LOT different, this one WORKS like a charm lol
Saw this a few weeks ago for appimage https://docs.appimage.org/packaging-guide/optional/updates.html#making-appimages-self-updateable
Yes, that's what I meant: with a single command, you can get it back after a FW update. And your settings and caches won't even get lost, because tthey are stored under /home.
If you could detect steamos and install the package to  /home/deck/Applications/Emby instead of /opt/Emby.
An essential element of application security is that it gets installed to a place where the account of the user doesn't have permission to write to, otherwise you are opening an attack surface that one might call "a hacker's dream" 🙂
ZanderKeen
Yes This...
I was just coming here to report that as well. I also had to run the installer twice to get everything successfully installed on its own on both my steamdeck & steam mini-pc. Not sure why that happened...
If emby is only installable using terminal + disable the read-only system, it is going to make a lot of general users uncomfortable or just not do it all together. Don't get me wrong, the universal installer is great, but I think it would still be a turn-off for the average users. Especially after OS updates when they discover they have to run it again; it opens the door for a support ticket nightmare as well, with people thinking the emby app is broke (since average users don't understand why its happening)...
I believe a flatpak version would resolve this with app discoverability in the repository, the discover/software GUI installer (no terminal required), and no need to disable the read-only file system.
Would that be something considered in the future after a stable version is released? Otherwise, even for myself personally, Even though I know what I'm doing, I would just opt to use the browser version as I use SteamOS as my "smart-tv" media player nowadays.
Thanks. 😺
Edited by ZanderKeen
mmhorda
24 minutes ago, ZanderKeen said:
Yes This...
Thanks. 😺
I understand it is Beta, but with Steam Machine release (which is around the corner), and millions of Steam Decks on hands, what defenitelly wotks today and works well is PLEX HTPC. if Emby wants at least a sip on those users then Emby app should be easy installable on SteamOS. Preferably a flatpak.
If it was up to me i would target that Linux audience as a priority.
This is nothing when you compare this with Windows gaming PC market shares..
If you would know figures and compare to Windows/Xbox app, you wouldn't say that. Reality doesn't match what you are thinking.
Just look at the Beta Forums - there's not much happening.
Of course, everything is possible - we are watching this closely and will adapt.
Thanks
Please note - again - the Emby Linux app is not a SteamOS app. It's not made for SteamOS and SteamOS is not  a  primary supported platform. While there's some hype around SteamDeck devices, this is still a small niche among Linux devices with GUI and Linux itself is a niche again. So we're talking about a niche inside a niche, and a platform where the app doesn't even run properly (only without mpv or not in GameMode), so there's not much to win, realistically, as that part cannot be changed.
Edited by softworkz
ZanderKeen
I don't get the issue here. If Emby doesn't want to deal with the differences in different distros then why is emby against flatpak? 🤷‍♂️
mmhorda
Thanks
I mean, of course. Windows, XBOX or apple are way bigger audience. Android and Android TV are HUGE as well.
but we are in Linux thread. I am comparing only linux vs linux here  :)  and HUGE thank you for supporting linux Desktop at all!
mmhorda
probably not enough recources or maybe even nobody to support it today.
This doesn't equalize out any of the relevant differences, unfortunately. Desktop environments, Window managers, Display server:  x11, Wayland - none of this goes away.
It's rather that flatpak and snap have their own specifics, so for each it's like developing for an additional platform - not to speak of supporting. We have those AppImage packages, but as said, it requires implementing an update mechanism. Package building for Snap is done by 70% btw, but there always comes a point where you need to draw a line and think about what you (we) will be able to support reasonably - especially for the initial release of an all-new application. The effort for development has been substantial already, and when the outcome would be that I'd have to respond to user issues on a daily basis - because I'm the only one who can answer certain questions, then that would be a self-built trap.
I think we have achieved a decent amount of platform coverage - which is more difficult than on any other OS (in case of desktop GUI apps) - something like 80%, and a good level in terms of quality - which is important - and much better than trying to go for 100% while ending up with a software having quirks and bugs everywhere and then running behind, trying to get everything fixed, yet failing to do so. On Linux, those 80% are served by a few players only (both, distros and DEs), for the remaining 20%, the variety is increasing exponentially, with hundreds of distros where you can only fail when trying to support everything.
Right to the point. There are other tasks that are really pressing and which people are waiting for.
The overarching achievement with this app is that it marks a milestone on a roadmap for the unification of client apps upon a common platform. After Window and Xbox, the Linux app is the third app on this new platform, which allows us to move faster in development, delivering innovations and also ensures continuity across platforms where apps for smaller platforms will directly benefit from work on other apps and features. In other words: it won't happen again that the Emby Linux app will become orphaned and outdated like it happened to the legacy ER app for Linux.
That's the outlook and the bright side, even when we cannot satisfy everybody's desire immediately.
Edited by softworkz
  • Like 2
  • Thanks 1
On 2/3/2026 at 8:10 AM, CrappyUserName said:
Figured it out.
Added an external player
/usr/bin/mpv
arguments:
--ontop
--no-border
{path}
Now I just need to reconfigure the ir remote to interact with mpv as well as emby which shouldn't be too hard.
Happy days!
A bit late perhaps - but as a massive fan of using mpv as external player: look into adding config file for MPV where you probably can add those options. MPV even allows for separate configs in the media folders themselves, allowing for finetuning any given videofile(s)/season folders. In fact, while Emby theater is nice enough, i am only it using because of the external player feature - all other clients I have tested, be it for Emby/Jellyfin etc. ALWAYS hijacks mpv(or other player), Emby theater is the only app that lets MPV rule on its own and doesn't interfere with my configs. :)
For good reasons. There can be just one captain on a boat, and when you want to achieve proper results, you can't let two entities control a single configuration (unless a player doesn't do much on its own, like the old ET.
Please note that you are talking about integrated players. The external player features is something different (just see the menu in ET legacy).
mmhorda
By the way do you plam to include external player feature to linux version? I'd say it is a necessity to have it on linux and android (maybe windows too) since there are so many distributions, kernles, drivers, hardware, so one never knows what will be broken at any point of time on some configurations.
Hi, yes we do.
  • Like 1
chesterseenes316
how the beta going
mmhorda
7 minutes ago, chesterseenes316 said:
how the beta going
It's alright. a bit long startup, otherwise OK.
I watched a video yesterday and it had frame drops but to be fair, plex client had frame drops  too. web emby player played it just perfectly fine.
TMCsw
6 hours ago, chesterseenes316 said:
how the beta going
Excellent for me (one of the previously closed beta testers)
Are you using the latest drivers for your GPU/iGPU? I had dropped frames with high-bitrate playback because the client relies on YOUR installed drivers (they aren't updated/included with the Emby client). After updating drivers, all is fine.
The Web player may be working fine because:
  1. It's forcing the server to transcode it down to something your client can play back smoothly. The bitrate can be lowered in the beta, too.
  2. The web browser is using its own HW accelerators.
  3. other?
So @chesterseenes316please give it a try, the only thing you have to lose is your time. (Report back any problems!)
  • Like 1
