them8os235 47 Posted May 8, 2024 Posted May 8, 2024 (edited) 2 hours ago, Luke said: OK yes the RPI image is on 3.0.16 as some elements of that need to be reworked, but the other builds are all up to date. Please forgive me if I'm being dense. But what is the reason someone should want to installed an older un-fixed v3.0.16 build with demonstrable problems just because it's built as ARM64 when the very stable build is 3.0.19 even tho it's ARMHF ? ...Addressable RAM? Okay... But I've never seen my RPi4 ET use more than about 700 or 800 Megs of RAM so I'm in the camp that it doesn't make sense to deploy ET on anything greater than a 2Gig version of the RPi4. Or is that because I am not someone who is viewing UHD video on my RPI4s? [TBD, I'll have to give that a try one day] If I can make a suggestion, perhaps it's time that someone on the Emby team revisit the 3.0.19 release repository. I imagine whatever it was that prevented the ARM64 build at the time is not longer a blocker [?], so that the ARM64 build of 3.0.19 can now be added to the list. I found the 3.0.19 build to be nothing but stable and snappy on the numerous RPi 4s I put it on and I was happy to use it. I've since redeployed those RPi4s for other uses. But this convo has just reminded and spurred me to pick a few more 2Gig versions up and put them back in service. Edited May 8, 2024 by them8os235
alucryd 318 Posted May 8, 2024 Posted May 8, 2024 New images are being worked on, that should hopefully cover RPi 3 all the way to 5, both armv7 (based on Bullseye) and armv8 (based on Bookworm). 1
acnp77 67 Posted May 9, 2024 Posted May 9, 2024 11 hours ago, them8os235 said: I found the 3.0.19 build to be nothing but stable and snappy on the numerous RPi 4s I put it on and I was happy to use it. I've since redeployed those RPi4s for other uses. But this convo has just reminded and spurred me to pick a few more 2Gig versions up and put them back in service. Hi. I am curious - Were there any special settings that needed to be made here? I am asking because I have extensively tried / tested emby-theater-rpi_3.0.19_armhf image with all possible combinations of settings on a rpi400 and I was not able to get it to a usable state. The gui was running smoothly, but video playback, even low bitrate h.264 1080p content did never play smoothly. There were audio/video sync issues and the playback was very choppy, despite all my efforts. Thanks,
them8os235 47 Posted May 9, 2024 Posted May 9, 2024 11 hours ago, acnp77 said: Hi. I am curious - Were there any special settings that needed to be made here? I am asking because I have extensively tried / tested emby-theater-rpi_3.0.19_armhf image with all possible combinations of settings on a rpi400 and I was not able to get it to a usable state. The gui was running smoothly, but video playback, even low bitrate h.264 1080p content did never play smoothly. There were audio/video sync issues and the playback was very choppy, despite all my efforts. Thanks, I don't have mine running anymore. I'll redeploy them after I finish building my new Emby Server and get back to you. BTW are you running via WiFi or LAN? I only ran mine via LAN.
acnp77 67 Posted May 10, 2024 Posted May 10, 2024 12 hours ago, them8os235 said: I don't have mine running anymore. I'll redeploy them after I finish building my new Emby Server and get back to you. BTW are you running via WiFi or LAN? I only ran mine via LAN. Hi. Great, thanks a lot. I always run the PI over LAN.
smoothquark 5 Posted May 10, 2024 Posted May 10, 2024 On 01/08/2023 at 20:35, screamor said: Hi i am just setting up a Emby Theater on Debian. I got everything running, but there is no way the Emby-theater plays anything without ran in sudo. Error log without sudo /usr/bin/emby-theater: 10: ldconfig: not found readlink: fehlender Operand „readlink --help“ liefert weitere Informationen. /usr/bin/emby-theater: 10: [: -gt: unexpected operator libGL error: MESA-LOADER: failed to open iris: /opt/emby-theater/extra/lib/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/dri/iris_dri.so) (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) libGL error: failed to load driver: iris libGL error: MESA-LOADER: failed to open iris: /opt/emby-theater/extra/lib/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/dri/iris_dri.so) (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) libGL error: failed to load driver: iris libGL error: MESA-LOADER: failed to open swrast: /opt/emby-theater/extra/lib/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/dri/swrast_dri.so) (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) libGL error: failed to load driver: swrast Initializing cec-client... { cecExePath: 'cec-client', cecEmitter: EventEmitter { _events: [Object: null prototype] {}, _eventsCount: 0, _maxListeners: undefined }, cecHdmiPort: 'null' } cec-client exited with code 1 UDP Client listening on 0.0.0.0:39420 starting udp receive timer with timeout ms: 1000 Message from: xxxxxxxxxxx ServerDiscovery message received Server discovery json: {"Address":"http://xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"} ServerDiscovery message received cec-client exited with code 1 timer expired 2 servers received [ { Address: 'http://xxxxxxxxxxxxx Id: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx Name: 'xxxxxxxxx EndpointAddress: 'xxxxxxxxxxxx }, with sudo: Initializing cec-client... { cecExePath: 'cec-client', cecEmitter: EventEmitter { _events: [Object: null prototype] {}, _eventsCount: 0, _maxListeners: undefined }, cecHdmiPort: 'null' } UDP Client listening on 0.0.0.0:39420 starting udp receive timer with timeout ms: 1000 Message from: xxxxxxxxxxxxx ServerDiscovery message received Server discovery json: {"Address":"http://xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"} ServerDiscovery message received cec-client exited with code 1 timer expired 2 servers received [ { Address: 'http://xxxxxxxxxxxxx Id: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx Name: 'xxxxxxxxx EndpointAddress: 'xxxxxxxxxxxx }, Anybody an idea how to run this without sudo? A bit late to the party... I have only just started playing with Emby Theater for Linux. ldconfig is in /usr/sbin in Debian and not in the path for a normal user. I have simply changed the startup script in /usr/bin/emby-theater to add the necessary path. In any case, it did not make a difference in my system.
smoothquark 5 Posted May 10, 2024 Posted May 10, 2024 I have installed Emby Theatre for Linux on a minimal Debian 12 installation. Starts up fine and works in stereo as long as pulseaudio is installed. I just cannot seem to get passthrough to work even with playing with the passthrough settings in the Emby Electron app as well as via pavucontrol. Whenever passthrough is used, I just get the dreaded spinning blue wheel. Preamble... I went away from using a HTPC sometime ago due to poor video support in Linux, but this has now improved significantly, Video playback has been pretty good. My main intention, however, was to get bitperfect audio. My Nvidia Shield has been pretty good with bit pefect via HDMI to my Denon AVR (never mind the processing that happens within the AVR). Previously, my music system was in a different room but we have now moved and HT and music has to live in the same place, which has required some downsizing of my equipment. I have been trying to get my USB DAC to work with my NVidia Shield - this has involved getting the 9.1.2 update, but USB still does not support DSD and switching outputs has been convoluted. UAPP on the Shield does play back bitperfect to the USB DAC but the inteface is very clunky as it is not an Android TV native app. I have been a long term user of Emby and I do like the interface for music but the Shield does not support output to both HDMI and USB simultaneously. It would be nice if Emby will support TIDAL integration. I did try Plex for its TIDAL "support" - the less said, the better! Anyway, back to my HTPC - I have installed mpv separately and can get dual outputs working via Lua scripting as well as DSD output to my USB DAC, although mpv by itself cannot do so as ffmpeg does not. So, I have been trying to bypass pulseaudio on Emby Theater and it does not appear that I can do. These are my observations (I have made up an mpv.conf in ~/.config/mpv for testing) ... 1. If pulseaudio is removed from the system, and audio playback results in the blue spinning wheel of death. In the mpv logs, I get the following: [ 0.091][v][ao] Trying audio driver 'alsa' [ 0.091][v][ao] Using preferred device 'plughw:CARD=SB,DEV=0' [ 0.091][v][ao/alsa] requested format: 44100 Hz, stereo channels, s16 [ 0.091][v][ao/alsa] using ALSA version: 1.2.4 [ 0.091][v][ao/alsa] opening device 'plughw:CARD=SB,DEV=0' [ 0.093][e][ao/alsa] Playback open error: Device or resource busy [ 0.094][e][ao] Failed to initialize audio driver 'alsa' [ 0.094][e][ao] This audio driver/device was forced with the --audio-device > [ 0.094][e][ao] Try unsetting it. [ 0.094][e][cplayer] Could not open/initialize audio device -> no sound. I am assuming that if pulseaudio is not installed, emby-theater then takes up the default audio device for the internal sound (internal sound when navigating still works), and therefore hogs it? However, running mpv separately in a separate terminal and using the same audio device works OK, so, Emby cannot be hogging it? 2. I can get the spinning wheel of death to go away and carry on playing without audio by using audio-fallback-to-null=yes in mpv.conf. I was then hoping to set up a separate mpv instance via lua scripting but it looks like lua is disabled in libmpv and the mpv version that ships with emby-theater. 3. I tried to use mpv as an external player. I either get a blank screen flashing or a playback error message (can't remember the actual message) when emby-theater boots up from start (openbox and user 'htpc'), with no logs being generated by mpv but the video plays (without audio as I have audio-fallback-to-null=yes in mpv.conf), when emby-theater is started via ssh also as user 'htpc'). So, I am wondering if somehow the external mpv is being started as a different user? Perhaps this may explain (1) too? 4. Is it possible to get the configs used for building the internal libmpv and mpv? I shall try to keep playing a bit more if I can figure this out, unless there is actually an idiot's guide to getting bitperfect and passthrough working? Perhaps I am missing something obvious? I might have to resort to setting up a standard Debian desktop on the HTPC and work backwards, perhaps? Thank you.
alucryd 318 Posted May 10, 2024 Posted May 10, 2024 I'm not super intimate with how electron interacts with mpv, and it's given me quite a few headaches already, but I don't think it's started as another user. As for the config, here are the enabled features for x64 and arm for the builds I am currently working on: x64: List of enabled features: alsa av-channel-layout avif-muxer cplugins dmabuf-interop-gl drm dvbin egl egl-drm egl-x11 ffmpeg gbm gl glibc-thread-name glob glob-posix gpl iconv jpegxl lavu-uuid lcms2 libass libavdevice libdl libplacebo linux-fstatfs posix ppoll pthread-condattr-setclock pulse vaapi vaapi-drm vector vk-khr-display vt.h vulkan x11 zlib arm: List of enabled features: alsa av-channel-layout avif-muxer cplugins dmabuf-interop-gl drm dvbin egl egl-drm egl-x11 ffmpeg gbm gl glibc-thread-name glob glob-posix gpl iconv jpegxl lavu-uuid lcms2 libass libavdevice libdl libplacebo linux-fstatfs posix ppoll pthread-condattr-setclock pulse vector vk-khr-display vt.h vulkan vulkan-interop x11 zlib Might throw wayland support in the mix later on, but as long as electron runs under xorg, or even xwayland, I'm not sure that's going to be very useful.
acnp77 67 Posted May 10, 2024 Posted May 10, 2024 @alucrydIt seems to me that I was never able to get HW decoding to work on the rpi400 with the emby-theater-rpi_3.0.19_armhf image or any other image. I know this is not a very detailed observation, but this seems to be the main issue. The pi4 as such would be more than capable.
smoothquark 5 Posted May 10, 2024 Posted May 10, 2024 3 hours ago, alucryd said: I'm not super intimate with how electron interacts with mpv, and it's given me quite a few headaches already, but I don't think it's started as another user. As for the config, here are the enabled features for x64 and arm for the builds I am currently working on: x64: List of enabled features: alsa av-channel-layout avif-muxer cplugins dmabuf-interop-gl drm dvbin egl egl-drm egl-x11 ffmpeg gbm gl glibc-thread-name glob glob-posix gpl iconv jpegxl lavu-uuid lcms2 libass libavdevice libdl libplacebo linux-fstatfs posix ppoll pthread-condattr-setclock pulse vaapi vaapi-drm vector vk-khr-display vt.h vulkan x11 zlib arm: List of enabled features: alsa av-channel-layout avif-muxer cplugins dmabuf-interop-gl drm dvbin egl egl-drm egl-x11 ffmpeg gbm gl glibc-thread-name glob glob-posix gpl iconv jpegxl lavu-uuid lcms2 libass libavdevice libdl libplacebo linux-fstatfs posix ppoll pthread-condattr-setclock pulse vector vk-khr-display vt.h vulkan vulkan-interop x11 zlib Might throw wayland support in the mix later on, but as long as electron runs under xorg, or even xwayland, I'm not sure that's going to be very useful. Thanks. Looking forward to your build. I think it is electron that somehow uses pulseaudio for everything. I seem to recall reading that somewhere sometime ago but it might just be my imagination. I am finding the same thing with installation on my main desktop (Debian Buster) too, but just with a stereo line out. Strange that I can't get passthrough working on the HTPC connected to my AVR via HDMI, even with pulseaudio. I shall wait for your build to be available first, in case it actually fixes these issues. Thank you for your hard work!
smoothquark 5 Posted May 11, 2024 Posted May 11, 2024 A bit more playing around with Emby Theater in Debian Bookworm. No pulseaudio or pipewire. Trying to play a 16/44.1 flac. Both result in the blue spinning wheel of death without an audio output device specified in ~/.config/mpv/mpv.conf [ 0.269][v][ao] Trying audio driver 'pulse' [ 0.269][v][ao/pulse] requested format: 44100 Hz, stereo channels, s16 [ 0.270][v][ao/pulse] Library version: 16.1.0 [ 0.270][v][ao/pulse] Proto: 35 [ 0.270][v][ao/pulse] Server proto: 4294967295 [ 0.270][v][ao] Trying audio driver 'alsa' [ 0.270][v][ao/alsa] requested format: 44100 Hz, stereo channels, s16 [ 0.270][v][ao/alsa] using ALSA version: 1.2.8 [ 0.270][v][ao/alsa] opening device 'default' [ 0.272][e][ao/alsa] Playback open error: Device or resource busy [ 0.272][e][ao] Failed to initialize audio driver 'alsa' [ 0.272][e][cplayer] Could not open/initialize audio device -> no sound. without an audio output device specified in ~/.config/mpv/mpv.conf [ 0.052][v][ao] Trying audio driver 'alsa' [ 0.052][v][ao] Using preferred device 'hdmi:CARD=NVidia,DEV=0' [ 0.052][v][ao/alsa] requested format: 44100 Hz, stereo channels, s16 [ 0.052][v][ao/alsa] using ALSA version: 1.2.8 [ 0.052][v][ao/alsa] opening device 'hdmi:CARD=NVidia,DEV=0' [ 0.054][d][lavf] stream 0: resize index to 128 [ 0.065][d][ao/alsa] PCM setup: [ 0.065][d][ao/alsa] --- [ 0.065][d][ao/alsa] Hooks PCM [ 0.065][d][ao/alsa] Slave: Hardware PCM card 1 'HDA NVidia' device 3 subdevice 0 [ 0.065][d][ao/alsa] --- [ 0.065][d][ao/alsa] Start HW params: [ 0.065][d][ao/alsa] --- [ 0.065][d][ao/alsa] ACCESS: MMAP_INTERLEAVED RW_INTERLEAVED [ 0.065][d][ao/alsa] FORMAT: S16_LE S32_LE [ 0.065][d][ao/alsa] SUBFORMAT: STD [ 0.065][d][ao/alsa] SAMPLE_BITS: [16 32] [ 0.065][d][ao/alsa] FRAME_BITS: [32 256] [ 0.065][d][ao/alsa] CHANNELS: [2 8] [ 0.065][d][ao/alsa] RATE: [32000 192000] [ 0.065][d][ao/alsa] PERIOD_TIME: (20 16384000] [ 0.065][d][ao/alsa] PERIOD_SIZE: [4 524288] [ 0.065][d][ao/alsa] PERIOD_BYTES: [128 2097152] [ 0.065][d][ao/alsa] PERIODS: [2 32] [ 0.065][d][ao/alsa] BUFFER_TIME: (41 32768000] [ 0.065][d][ao/alsa] BUFFER_SIZE: [8 1048576] [ 0.065][d][ao/alsa] BUFFER_BYTES: [128 4194304] [ 0.065][d][ao/alsa] TICK_TIME: ALL [ 0.065][d][ao/alsa] --- [ 0.065][d][ao/alsa] HW params after rate: [ 0.065][d][ao/alsa] --- [ 0.065][d][ao/alsa] ACCESS: MMAP_INTERLEAVED RW_INTERLEAVED [ 0.065][d][ao/alsa] FORMAT: S16_LE S32_LE [ 0.065][d][ao/alsa] SUBFORMAT: STD [ 0.065][d][ao/alsa] SAMPLE_BITS: [16 32] [ 0.065][d][ao/alsa] FRAME_BITS: [32 256] [ 0.065][d][ao/alsa] CHANNELS: [2 8] [ 0.065][d][ao/alsa] RATE: [32000 192000] [ 0.065][d][ao/alsa] PERIOD_TIME: (20 16384000] [ 0.065][d][ao/alsa] PERIOD_SIZE: [4 524288] [ 0.065][d][ao/alsa] PERIOD_BYTES: [128 2097152] [ 0.065][d][ao/alsa] PERIODS: [2 32] [ 0.065][d][ao/alsa] BUFFER_TIME: (41 32768000] [ 0.065][d][ao/alsa] BUFFER_SIZE: [8 1048576] [ 0.065][d][ao/alsa] BUFFER_BYTES: [128 4194304] [ 0.065][d][ao/alsa] TICK_TIME: ALL [ 0.065][d][ao/alsa] --- [ 0.065][d][ao/alsa] HW params after access: [ 0.065][d][ao/alsa] --- [ 0.065][d][ao/alsa] ACCESS: RW_INTERLEAVED [ 0.065][d][ao/alsa] FORMAT: S16_LE S32_LE [ 0.065][d][ao/alsa] SUBFORMAT: STD [ 0.065][d][ao/alsa] SAMPLE_BITS: [16 32] [ 0.065][d][ao/alsa] FRAME_BITS: [32 256] [ 0.065][d][ao/alsa] CHANNELS: [2 8] [ 0.065][d][ao/alsa] RATE: [32000 192000] [ 0.065][d][ao/alsa] PERIOD_TIME: (20 16384000] [ 0.065][d][ao/alsa] PERIOD_SIZE: [4 524288] [ 0.065][d][ao/alsa] PERIOD_BYTES: [128 2097152] [ 0.065][d][ao/alsa] PERIODS: [2 32] [ 0.065][d][ao/alsa] BUFFER_TIME: (41 32768000] [ 0.065][d][ao/alsa] BUFFER_SIZE: [8 1048576] [ 0.065][d][ao/alsa] BUFFER_BYTES: [128 4194304] [ 0.065][d][ao/alsa] TICK_TIME: ALL [ 0.065][d][ao/alsa] --- [ 0.065][v][ao/alsa] trying format s16/2 [ 0.065][d][ao/alsa] HW params after format: [ 0.065][d][ao/alsa] --- [ 0.065][d][ao/alsa] ACCESS: RW_INTERLEAVED [ 0.065][d][ao/alsa] FORMAT: S16_LE [ 0.065][d][ao/alsa] SUBFORMAT: STD [ 0.065][d][ao/alsa] SAMPLE_BITS: 16 [ 0.065][d][ao/alsa] FRAME_BITS: [32 128] [ 0.065][d][ao/alsa] CHANNELS: [2 8] [ 0.065][d][ao/alsa] RATE: [32000 192000] [ 0.065][d][ao/alsa] PERIOD_TIME: (41 16384000] [ 0.065][d][ao/alsa] PERIOD_SIZE: [8 524288] [ 0.065][d][ao/alsa] PERIOD_BYTES: [128 2097152] [ 0.065][d][ao/alsa] PERIODS: [2 32] [ 0.065][d][ao/alsa] BUFFER_TIME: (83 32768000] [ 0.065][d][ao/alsa] BUFFER_SIZE: [16 1048576] [ 0.065][d][ao/alsa] BUFFER_BYTES: [128 4194304] [ 0.065][d][ao/alsa] TICK_TIME: ALL [ 0.065][d][ao/alsa] --- [ 0.065][d][ao/alsa] HW params after channels: [ 0.065][d][ao/alsa] --- [ 0.065][d][ao/alsa] ACCESS: RW_INTERLEAVED [ 0.065][d][ao/alsa] FORMAT: S16_LE [ 0.065][d][ao/alsa] SUBFORMAT: STD [ 0.065][d][ao/alsa] SAMPLE_BITS: 16 [ 0.065][d][ao/alsa] FRAME_BITS: 128 [ 0.065][d][ao/alsa] CHANNELS: 8 [ 0.065][d][ao/alsa] RATE: [32000 192000] [ 0.065][d][ao/alsa] PERIOD_TIME: (41 4096000] [ 0.065][d][ao/alsa] PERIOD_SIZE: [8 131072] [ 0.065][d][ao/alsa] PERIOD_BYTES: [128 2097152] [ 0.065][d][ao/alsa] PERIODS: [2 32] [ 0.065][d][ao/alsa] BUFFER_TIME: (83 8192000] [ 0.065][d][ao/alsa] BUFFER_SIZE: [16 262144] [ 0.065][d][ao/alsa] BUFFER_BYTES: [256 4194304] [ 0.065][d][ao/alsa] TICK_TIME: ALL [ 0.065][d][ao/alsa] --- [ 0.065][d][ao/alsa] HW params after rate-2: [ 0.065][d][ao/alsa] --- [ 0.066][d][ao/alsa] ACCESS: RW_INTERLEAVED [ 0.066][d][ao/alsa] FORMAT: S16_LE [ 0.066][d][ao/alsa] SUBFORMAT: STD [ 0.066][d][ao/alsa] SAMPLE_BITS: 16 [ 0.066][d][ao/alsa] FRAME_BITS: 128 [ 0.066][d][ao/alsa] CHANNELS: 8 [ 0.066][d][ao/alsa] RATE: 192000 [ 0.066][d][ao/alsa] PERIOD_TIME: (41 682667) [ 0.066][d][ao/alsa] PERIOD_SIZE: [8 131072] [ 0.066][d][ao/alsa] PERIOD_BYTES: [128 2097152] [ 0.066][d][ao/alsa] PERIODS: [2 32] [ 0.066][d][ao/alsa] BUFFER_TIME: (83 1365334) [ 0.066][d][ao/alsa] BUFFER_SIZE: [16 262144] [ 0.066][d][ao/alsa] BUFFER_BYTES: [256 4194304] [ 0.066][d][ao/alsa] TICK_TIME: ALL [ 0.066][d][ao/alsa] --- [ 0.066][d][ao/alsa] Going to set final HW params: [ 0.066][d][ao/alsa] --- [ 0.066][d][ao/alsa] ACCESS: RW_INTERLEAVED [ 0.066][d][ao/alsa] FORMAT: S16_LE [ 0.066][d][ao/alsa] SUBFORMAT: STD [ 0.066][d][ao/alsa] SAMPLE_BITS: 16 [ 0.066][d][ao/alsa] FRAME_BITS: 128 [ 0.066][d][ao/alsa] CHANNELS: 8 [ 0.066][d][ao/alsa] RATE: 192000 [ 0.066][d][ao/alsa] PERIOD_TIME: (42666 42667) [ 0.066][d][ao/alsa] PERIOD_SIZE: 8192 [ 0.066][d][ao/alsa] PERIOD_BYTES: 131072 [ 0.066][d][ao/alsa] PERIODS: 32 [ 0.066][d][ao/alsa] BUFFER_TIME: (1365333 1365334) [ 0.066][d][ao/alsa] BUFFER_SIZE: 262144 [ 0.066][d][ao/alsa] BUFFER_BYTES: 4194304 [ 0.066][d][ao/alsa] TICK_TIME: ALL [ 0.066][d][ao/alsa] --- [ 0.078][d][ao/alsa] Final HW params: [ 0.078][d][ao/alsa] --- [ 0.078][d][ao/alsa] ACCESS: RW_INTERLEAVED [ 0.078][d][ao/alsa] FORMAT: S16_LE [ 0.078][d][ao/alsa] SUBFORMAT: STD [ 0.078][d][ao/alsa] SAMPLE_BITS: 16 [ 0.078][d][ao/alsa] FRAME_BITS: 128 [ 0.078][d][ao/alsa] CHANNELS: 8 [ 0.078][d][ao/alsa] RATE: 192000 [ 0.078][d][ao/alsa] PERIOD_TIME: (42666 42667) [ 0.078][d][ao/alsa] PERIOD_SIZE: 8192 [ 0.078][d][ao/alsa] PERIOD_BYTES: 131072 [ 0.078][d][ao/alsa] PERIODS: 32 [ 0.078][d][ao/alsa] BUFFER_TIME: (1365333 1365334) [ 0.078][d][ao/alsa] BUFFER_SIZE: 262144 [ 0.078][d][ao/alsa] BUFFER_BYTES: 4194304 [ 0.078][d][ao/alsa] TICK_TIME: 0 [ 0.078][d][ao/alsa] --- [ 0.078][v][ao/alsa] channel map reported by ALSA: FL FR RLC RRC FC LFE RL RR [ 0.078][v][ao/alsa] which we understand as: 7.1(alsa) [ 0.078][w][ao/alsa] ALSA channel map conflicts with channel count! [ 0.078][v][ao/alsa] hw pausing supported: yes [ 0.078][v][ao/alsa] buffersize: 0 samples [ 0.078][v][ao/alsa] period size: 0 samples [ 0.080][e][ao/alsa] Device buffer size not set. [ 0.081][e][ao] Failed to initialize audio driver 'alsa' [ 0.081][e][ao] This audio driver/device was forced with the --audio-device option. [ 0.081][e][ao] Try unsetting it. [ 0.081][e][cplayer] Could not open/initialize audio device -> no sound. I think either (or both) emby and electron cannot access an alsa device directly. I can avoid the blue spinning wheel and get playback to proceed with sound by having audio-fallback-to-null=yes in the mpv.conf. I also think I may be able to get around this by starting another instance of mpv, but this requires libmpv to support lua which has not been compiled in. Is it possible to try a version with lua support, or alternatively, can I compile my own? I think emby-theater uses its own version of ffmpeg though?
alucryd 318 Posted May 11, 2024 Posted May 11, 2024 @smoothquarkYeah on x64 we're using a custom ffmpeg version, you can find the sources here: https://mediabrowser.github.io/embytools/ffmpeg-2023_06_25-u1.tar.gz On ARM, we're using this fork: https://github.com/jc-kynesim/rpi-ffmpeg. Feel free to try building mpv yourself. Hopefully I can get something out myself sometime next week.
alucryd 318 Posted May 23, 2024 Posted May 23, 2024 Sorry about the wait, electron is giving me some headaches. Here's a test image, based on armbian this time: https://www.dropbox.com/scl/fi/qtuh8hk980mcdsrf4ajq3/emby-theater_3.0.19_rpi4b.img.xz?rlkey=gaw058vsw1re1arn35qsg6h0i&st=op9ztk5m&dl=0. Mpv has been bumped to the latest version, as well as the ffmpeg rpi fork we're using, it comes with improved h264 hardware decoding via v4l2 and drmprime, and this is new, with h265 as well via the v4l2-request api. Leaving hwdec to auto should select the right decoder, and you may experiment with either gpu or gpu-next, both should be working fine. It's also possible to make use of vulkan too now, it's not exposed in theater but you can add `gpu-api=vulkan` in ~/.config/mpv/mpv.conf. Installation instructions are a bit different from the rpi os image, the first boot will let you choose a root password (for ssh), set up networking, and this is important, create a new user. You need to call the user `emby` and not set up any password for autologin to work. By default it will launch an openbox session, but xfce is also available, this can be changed in `/etc/lightdm/lightdm.conf.d/12-autologin.conf`. Note that I might rename this to `99-emby.conf` later though. The image works on both rpi 3 and 4 (and 400) despite the name, it's just how armbian calls this configuration. Rpi 5 images are in the works, but our current electron doesn't run on it, and newer versions are not compatible with our mpv plugin so we're in a bind for now. 2
smoothquark 5 Posted June 17, 2024 Posted June 17, 2024 Electron does seem to cause a lot of issues! My recompile with mpv and ffmpeg did not help, and I am pretty sure Electron hogs the audio outputs. Unfortunately, I can't try your test image as I run Debian on a PC.
Luke 42242 Posted June 20, 2024 Posted June 20, 2024 Hi, can you please try our new Emby Theater 3.0.21 package? https://emby.media/download Please let us know how this compares. Thanks !
Der R 5 Posted June 20, 2024 Posted June 20, 2024 Apparently I haven't been keeping up the way I should, so I only just found out about the 3.0.21 version. But just so you're aware: There is no flatpak version, only a tar.xz version. And this goes for both the github and the flathub sites. Could you please prepare a flatpak package?
CharlesJ 0 Posted June 21, 2024 Posted June 21, 2024 9 hours ago, Luke said: Hi, can you please try our new Emby Theater 3.0.21 package? https://emby.media/download Please let us know how this compares. Thanks ! I was having issues with the 3.0.19 on my Debian Linux, Login worked, and my server displayed my videos/music, but when I attempted to play media it would just spring the "cursor". I downloaded and installed the 3.0.21 package and can now watch/listen to media, but there are no controls. I couldn't pause a video or skip forward or backward while playing the video I using for testing. I could exit the video using the esc button on my keyboard.
Arcau 11 Posted August 3, 2024 Posted August 3, 2024 On 6/21/2024 at 3:12 PM, CharlesJ said: I was having issues with the 3.0.19 on my Debian Linux, Login worked, and my server displayed my videos/music, but when I attempted to play media it would just spring the "cursor". I downloaded and installed the 3.0.21 package and can now watch/listen to media, but there are no controls. I couldn't pause a video or skip forward or backward while playing the video I using for testing. I could exit the video using the esc button on my keyboard. Was having issues with Fullscreen emby theatre blocking the use of anything else on the other screen - like web browsers etc - updated the flatpack version i had installed 3.0.19 to direct install of the 3.0.21 and having the same issue - not getting any interface once play back starts unable to pause or adjust volume etc etc. Nobara Linux version 40
Arcau 11 Posted August 4, 2024 Posted August 4, 2024 I have reverted back to the .19 flatpack version for now - its still blocking all other input when maximized or full screen - working around with just having a manually sized not quite full screen window for now.
sn0pzer 2 Posted August 18, 2024 Posted August 18, 2024 I'm also having issues with the new 3.0.21 version. I'm running on Fedora 40 and using the RPM package from Github. Videos will play fine, but all media controls are missing, so I can't control the video using my mouse or even close the window. Keyboard shortcuts seem to work fine though. 1
Luke 42242 Posted August 18, 2024 Posted August 18, 2024 5 hours ago, sn0pzer said: I'm also having issues with the new 3.0.21 version. I'm running on Fedora 40 and using the RPM package from Github. Videos will play fine, but all media controls are missing, so I can't control the video using my mouse or even close the window. Keyboard shortcuts seem to work fine though. HI, we are looking into this. Thanks. 1
Nestar 15 Posted August 19, 2024 Posted August 19, 2024 Experiencing this as well, came here searching for it. Mouse is visible for a few seconds after disappears shortly, clicking the mouse does not pause it and it doesn't seem to accept any input from it. Escape simply backs out to the library. This happens in both full screen and on a smaller window. Doesn't appear to have any impact on hardware encoding or playback support, the video itself does play fine.
Skuld 2 Posted August 20, 2024 Posted August 20, 2024 Hi everyone, i just installed Emby Theater on my Steam Deck via Discover. Unfortunatly whenever i try to play a video it keeps loading forever. Has anyone a idea how to fix this ?
alucryd 318 Posted August 20, 2024 Posted August 20, 2024 @SkuldThere seems to be some issues between newer flatpak runtimes and our builds, not limited to the steam deck. We are currently working on a complete overhaul, hopefully we can put something out soon.
