mprasil 14 Posted August 30, 2020 Posted August 30, 2020 On 09/07/2020 at 03:58, Luke said: Hi, try running: ldd /usr/lib/emby-theater/libmpv.so.1 | grep "not found" I have the same issue on fresh Ubuntu 20.04 installation. Pretty much just fresh minimal install with: apt update && apt upgrade && apt install mpv && dpkg -i et.deb The playback just gets stuck on 00:00. ldd shows no missing libraries, just downgrading ET to 3.0.11 plays everything fine. I'm pretty confident with Linux systems, but quite new to ET, so any pointers how to troubleshoot this would be appreciated.
Luke 42241 Posted August 30, 2020 Posted August 30, 2020 1 hour ago, mprasil said: I have the same issue on fresh Ubuntu 20.04 installation. Pretty much just fresh minimal install with: apt update && apt upgrade && apt install mpv && dpkg -i et.deb The playback just gets stuck on 00:00. ldd shows no missing libraries, just downgrading ET to 3.0.11 plays everything fine. I'm pretty confident with Linux systems, but quite new to ET, so any pointers how to troubleshoot this would be appreciated. Try setting the hardware acceleration mode to auto copy back.
mprasil 14 Posted August 30, 2020 Posted August 30, 2020 (edited) 29 minutes ago, Luke said: Try setting the hardware acceleration mode to auto copy back. Still the same. One possibly interesting observation: I launched emby-theater from console, so I'm seeing its stdout. In older version every time I play anything it first fails to play that locally (which makes sense because the local file is not there) and then it logs the stream it's playing from. With the latest version I can only see the local playback error, but I don't see the stream URL that it would normally log afterwards. Edited August 30, 2020 by mprasil typo
Luke 42241 Posted August 30, 2020 Posted August 30, 2020 1 minute ago, mprasil said: Still the same. One possibly interesting observation: I launched emby-theater from console, so I'm seeing its stdout. In older version every time I play anything it first fails to play that locally (which makes sense because the local file is not there) and then it logs the stream it's playing from. With the latest version I can only see the local playback error, but I don't see the stream URL that it would normally log afterwards. Can you provide the console output? Thanks.
mprasil 14 Posted August 30, 2020 Posted August 30, 2020 10 minutes ago, Luke said: Can you provide the console output? Thanks. Sure (some details obscured, but otherwise as-is from start to playback and Exit): ==================== emby-theater 3.0.11: ==================== (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false". It will change to be "true" in Electron 9. For more information please check https://github.com/electron/electron/issues/18397 Initializing cec-client... { cecExePath: 'cec-client', cecEmitter: EventEmitter { _events: [Object: null prototype] {}, _eventsCount: 0, _maxListeners: undefined } } cec-client exited with code 1 UDP Client listening on 0.0.0.0:43573 starting udp receive timer with timeout ms: 1000 timer expired 0 servers received [] fs access result for path: Error: ENOENT: no such file or directory, access '/data/movies/XXX/XXX.avi' Play URL : https://xxx.xxx.eu:443/videos/52003/stream.avi?DeviceId=xxxxxx... (the movie plays at this stage, no more output until exit) ==================== emby-theater 3.0.12: ==================== (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false". It will change to be "true" in Electron 9. For more information please check https://github.com/electron/electron/issues/18397 Initializing cec-client... { cecExePath: 'cec-client', cecEmitter: EventEmitter { _events: [Object: null prototype] {}, _eventsCount: 0, _maxListeners: undefined }, cecHdmiPort: '' } UDP Client listening on 0.0.0.0:43495 starting udp receive timer with timeout ms: 1000 cec-client exited with code 1 timer expired 0 servers received [] fs access result for path: Error: ENOENT: no such file or directory, access '/data/movies/XXX/XXX.avi' (the movie does not play, stuck at 00:00, no more output until exit)
GregMo 24 Posted September 10, 2020 Posted September 10, 2020 I've just tried the image file and when my Pi boots it brings me to a desktop login dialog. I'm guessing this isn't the expected behavior but I can't find anything that states explicitly one way or another. I've search for what the username and password might be but can't seem to find a match.
mprasil 14 Posted September 10, 2020 Posted September 10, 2020 Was there any update on the 3.0.12 not playing anything? I've just hit it on another PC. Same story - just completely new minimal install of Ubuntu 20.04 and then: apt update && apt upgrade && apt install mpv && apt install ./emby-theater_3.0.12_amd64.deb Same issue - video stuck at 00:00, black screen. Downgrading to 3.0.11 works fine, but the controls don't properly overlay the video. (The screen is black while controls are visible)
Luke 42241 Posted September 12, 2020 Posted September 12, 2020 On 9/10/2020 at 3:35 PM, mprasil said: Was there any update on the 3.0.12 not playing anything? I've just hit it on another PC. Same story - just completely new minimal install of Ubuntu 20.04 and then: apt update && apt upgrade && apt install mpv && apt install ./emby-theater_3.0.12_amd64.deb Same issue - video stuck at 00:00, black screen. Downgrading to 3.0.11 works fine, but the controls don't properly overlay the video. (The screen is black while controls are visible) @mprasil can you please attach the mpv log? instructions are here: Thanks.
mprasil 14 Posted September 12, 2020 Posted September 12, 2020 (edited) 9 hours ago, Luke said: @mprasil can you please attach the mpv log? instructions are here: Thanks. Log file attached. Some stuff is obfuscated, but otherwise as is. I suppose this could be the issue: https protocol not found, recompile FFmpeg with openssl, gnutls or securetransport enabled. However I should have openssl support enabled (as I mentioned the previous version of ET plays the same file just fine) and when I grab the URL it's trying to open, and do this it plays the file just fine: # URL is the long URL from logs mpv "$URL" mpv.log Edited September 12, 2020 by mprasil typofix
mprasil 14 Posted September 12, 2020 Posted September 12, 2020 (edited) I've noticed 3.0.12 contains extra libraries like libmpv.so.1 and few others. I assume it's no longer using the system library, which would probably explain the difference? Perhaps it just needs to be recompiled with ssl support? Edited September 12, 2020 by mprasil typo
mprasil 14 Posted September 15, 2020 Posted September 15, 2020 @Luke Is there any way to compile this myself with the proper flags?
Luke 42241 Posted September 15, 2020 Posted September 15, 2020 1 hour ago, mprasil said: @Luke Is there any way to compile this myself with the proper flags? Yes: https://github.com/MediaBrowser/emby-theater-electron Although we don't have any documented build process that you can follow.
mprasil 14 Posted September 15, 2020 Posted September 15, 2020 40 minutes ago, Luke said: Yes: https://github.com/MediaBrowser/emby-theater-electron Although we don't have any documented build process that you can follow. I guess I should be more specific. I was aware of the repo, but I'm not that familiar with electron apps, so I was asking if there's any howto to compile it. (or any chance that you could release a version with proper https support)
Luke 42241 Posted September 15, 2020 Posted September 15, 2020 51 minutes ago, mprasil said: I guess I should be more specific. I was aware of the repo, but I'm not that familiar with electron apps, so I was asking if there's any howto to compile it. (or any chance that you could release a version with proper https support) The issue has been assigned to a developer and we're looking into it. Thanks. 1
Luke 42241 Posted September 18, 2020 Posted September 18, 2020 On 9/15/2020 at 12:30 PM, mprasil said: I guess I should be more specific. I was aware of the repo, but I'm not that familiar with electron apps, so I was asking if there's any howto to compile it. (or any chance that you could release a version with proper https support) @mprasil can you try downloading the .deb again and seeing how it compares? Thanks.
mprasil 14 Posted September 18, 2020 Posted September 18, 2020 7 hours ago, Luke said: @mprasil can you try downloading the .deb again and seeing how it compares? Thanks. I've tested this on all boxes that had the issue and can confirm it now works fine with 3.0.12-1. Thanks for that.
MediaMogal 19 Posted September 18, 2020 Posted September 18, 2020 Just installed the Electron version of Emby Theater and have to say I like it. I just wanted to ask unlike Plex Media Player is Theater still actively supported? Thanks
Luke 42241 Posted September 18, 2020 Posted September 18, 2020 2 hours ago, mprasil said: I've tested this on all boxes that had the issue and can confirm it now works fine with 3.0.12-1. Thanks for that. Thanks for the feedback !
Luke 42241 Posted September 18, 2020 Posted September 18, 2020 26 minutes ago, MediaMogal said: Just installed the Electron version of Emby Theater and have to say I like it. I just wanted to ask unlike Plex Media Player is Theater still actively supported? Thanks Yes it is. 1
MediaMogal 19 Posted October 2, 2020 Posted October 2, 2020 Theater will not build and install. I have tried once through pamac and then using yay in Konsole and all I get is the below. Any idea on what might be going on? Thanks [alienprober@TheMotrhership ~]$ yay -S emby-theater-bin :: Checking for conflicts... :: Checking for inner conflicts... [Aur:1] emby-theater-bin-3.0.12-2 :: Downloaded PKGBUILD (1/1): emby-theater-bin 1 emby-theater-bin (Build Files Exist) ==> Diffs to show? ==> [N]one [A]ll [Ab]ort [I]nstalled [No]tInstalled or (1 2 3, 1-3, ^4) ==> 4 :: (1/1) Parsing SRCINFO: emby-theater-bin ==> Making package: emby-theater-bin 3.0.12-2 (Fri 02 Oct 2020 09:33:47 AM PDT) ==> Retrieving sources... -> Downloading emby-theater_3.0.12_amd64.deb... % Total % Received % Xferd Average Speed Time Time Time Cur rent Dload Upload Total Spent Left Spe ed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 100 653 100 653 0 0 1239 0 --:--:-- --:--:-- --:--:-- 1 236 0 58.7M 0 51775 0 0 43435 0 0:23:37 0:00:01 0:23:36 43 12 58.7M 12 7772k 0 0 3566k 0 0:00:16 0:00:02 0:00:14 78 26 58.7M 26 15.7M 0 0 5076k 0 0:00:11 0:00:03 0:00:08 80 38 58.7M 38 22.8M 0 0 5596k 0 0:00:10 0:00:04 0:00:06 78 49 58.7M 49 28.9M 0 0 5719k 0 0:00:10 0:00:05 0:00:05 74 60 58.7M 60 35.5M 0 0 5887k 0 0:00:10 0:00:06 0:00:04 72 71 58.7M 71 42.2M 0 0 6023k 0 0:00:09 0:00:07 0:00:02 70 83 58.7M 83 49.2M 0 0 6160k 0 0:00:09 0:00:08 0:00:01 68 95 58.7M 95 56.2M 0 0 6273k 0 0:00:09 0:00:09 --:--:-- 68 100 58.7M 100 58.7M 0 0 6280k 0 0:00:09 0:00:09 --:--:-- 69 42k -> Found emby-theater.install ==> Validating source files with sha512sums... emby-theater_3.0.12_amd64.deb ... FAILED emby-theater.install ... Passed ==> ERROR: One or more files did not pass the validity check! error downloading sources: emby-theater-bin [alienprober@TheMotrhership ~]$
Luke 42241 Posted October 2, 2020 Posted October 2, 2020 2 minutes ago, MediaMogal said: Theater will not build and install. I have tried once through pamac and then using yay in Konsole and all I get is the below. Any idea on what might be going on? Thanks [alienprober@TheMotrhership ~]$ yay -S emby-theater-bin :: Checking for conflicts... :: Checking for inner conflicts... [Aur:1] emby-theater-bin-3.0.12-2 :: Downloaded PKGBUILD (1/1): emby-theater-bin 1 emby-theater-bin (Build Files Exist) ==> Diffs to show? ==> [N]one [A]ll [Ab]ort [I]nstalled [No]tInstalled or (1 2 3, 1-3, ^4) ==> 4 :: (1/1) Parsing SRCINFO: emby-theater-bin ==> Making package: emby-theater-bin 3.0.12-2 (Fri 02 Oct 2020 09:33:47 AM PDT) ==> Retrieving sources... -> Downloading emby-theater_3.0.12_amd64.deb... % Total % Received % Xferd Average Speed Time Time Time Cur rent Dload Upload Total Spent Left Spe ed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 100 653 100 653 0 0 1239 0 --:--:-- --:--:-- --:--:-- 1 236 0 58.7M 0 51775 0 0 43435 0 0:23:37 0:00:01 0:23:36 43 12 58.7M 12 7772k 0 0 3566k 0 0:00:16 0:00:02 0:00:14 78 26 58.7M 26 15.7M 0 0 5076k 0 0:00:11 0:00:03 0:00:08 80 38 58.7M 38 22.8M 0 0 5596k 0 0:00:10 0:00:04 0:00:06 78 49 58.7M 49 28.9M 0 0 5719k 0 0:00:10 0:00:05 0:00:05 74 60 58.7M 60 35.5M 0 0 5887k 0 0:00:10 0:00:06 0:00:04 72 71 58.7M 71 42.2M 0 0 6023k 0 0:00:09 0:00:07 0:00:02 70 83 58.7M 83 49.2M 0 0 6160k 0 0:00:09 0:00:08 0:00:01 68 95 58.7M 95 56.2M 0 0 6273k 0 0:00:09 0:00:09 --:--:-- 68 100 58.7M 100 58.7M 0 0 6280k 0 0:00:09 0:00:09 --:--:-- 69 42k -> Found emby-theater.install ==> Validating source files with sha512sums... emby-theater_3.0.12_amd64.deb ... FAILED emby-theater.install ... Passed ==> ERROR: One or more files did not pass the validity check! error downloading sources: emby-theater-bin [alienprober@TheMotrhership ~]$ Why not just use the instructions in the first post?
MediaMogal 19 Posted October 2, 2020 Posted October 2, 2020 (edited) I've looked at that post twice there are no Arch instructions, I've even went through all the post on that page. Edited October 2, 2020 by MediaMogal
dedyms 2 Posted October 2, 2020 Posted October 2, 2020 36 minutes ago, MediaMogal said: I've looked at that post twice there are no Arch instructions, I've even went through all the post on that page. Download the pkg build, change validity check to the new downloaded packet. If it sha256 then $sha256 enby-xxxcx.deb
MediaMogal 19 Posted October 2, 2020 Posted October 2, 2020 I'm not much of a command line person. Can I get some instructions? Thanks
dedyms 2 Posted October 2, 2020 Posted October 2, 2020 (edited) 37 minutes ago, MediaMogal said: I'm not much of a command line person. Can I get some instructions? Thanks copy manually the PKGBUILD contents and the emby-install to your home/designed directory, then do $ makepkg -g it will download and get result some shasums, replace the shasums in PKGBUILD with the result. then do : $ makepkg To create the actual package Edited October 2, 2020 by dedyms easier way
