Luke 42237 Posted April 8, 2017 Posted April 8, 2017 I've added the same header slide effect from the web app so that when you scroll vertically, the header slides away so that you can see posters on the full height of the screen. Enjoy.
Luke 42237 Posted April 13, 2017 Posted April 13, 2017 I've updated the download instructions in the first post. Specifically, the git repo has changed so you'll need to install from scratch. There is a lot of new development here because we are looking at using MPV player for Windows as well. Please try it out. Thanks !
denz 501 Posted April 15, 2017 Posted April 15, 2017 I have followed the instructions but it doesn't work there is no folder emby-theater-linux created but there is emby-theater-electron but when you go into it doesn't start with ./et.sh
Luke 42237 Posted April 15, 2017 Posted April 15, 2017 My mistake. File was missing. please do a git pull again. thanks.
denz 501 Posted April 15, 2017 Posted April 15, 2017 (edited) Files are there but when I start it I get this error the pi and the prior linux theater work but not this version. pi@raspberrypihome:~/emby-theater-electron $ ./et.sh App threw an error during load Error: Path must be absolute at Error (native) at /home/pi/emby-theater-electron/main.js:638:13 at Object.<anonymous> (/home/pi/emby-theater-electron/main.js:809:3) at Module._compile (module.js:556:32) at Object.Module._extensions..js (module.js:565:10) at Module.load (module.js:473:32) at tryModuleLoad (module.js:432:12) at Function.Module._load (module.js:424:3) at loadApplicationPackage (/usr/local/lib/node_modules/electron/dist/resources/default_app.asar/main.js:280:12) at Object.<anonymous> (/usr/local/lib/node_modules/electron/dist/resources/default_app.asar/main.js:322:5) A JavaScript error occurred in the main process Uncaught Exception: Error: Path must be absolute at Error (native) at /home/pi/emby-theater-electron/main.js:638:13 at Object.<anonymous> (/home/pi/emby-theater-electron/main.js:809:3) at Module._compile (module.js:556:32) at Object.Module._extensions..js (module.js:565:10) at Module.load (module.js:473:32) at tryModuleLoad (module.js:432:12) at Function.Module._load (module.js:424:3) at loadApplicationPackage (/usr/local/lib/node_modules/electron/dist/resources/default_app.asar/main.js:280:12) at Object.<anonymous> (/usr/local/lib/node_modules/electron/dist/resources/default_app.asar/main.js:322:5) Edited April 15, 2017 by denz
aptalca 71 Posted April 15, 2017 Posted April 15, 2017 Have you guys considered an embedded linux build using LibreELEC as the base? LibreELEC (forked from OpenELEC) is a Just enough OS (JeOS) which was originally for Kodi, but now plex is using it to base their new Plex Media Player on. Lakka, (retroarch emulation) is also using it as their base. LibreELEC is available for x86_64, arm and aarch64. I know this sounds like an ad for LibreELEC, but I'm not actually a part of their team. I do collaborate with them on certain things (docker support) and they are all great people. 3
Luke 42237 Posted April 15, 2017 Posted April 15, 2017 Have you guys considered an embedded linux build using LibreELEC as the base? LibreELEC (forked from OpenELEC) is a Just enough OS (JeOS) which was originally for Kodi, but now plex is using it to base their new Plex Media Player on. Lakka, (retroarch emulation) is also using it as their base. LibreELEC is available for x86_64, arm and aarch64. I know this sounds like an ad for LibreELEC, but I'm not actually a part of their team. I do collaborate with them on certain things (docker support) and they are all great people. Yes I think that would be great, and it's something we could look at next after our development with the mpv player is complete. 3
denz 501 Posted April 16, 2017 Posted April 16, 2017 I did another git pull and when i try et.sh the error is still the same as post #57
frabe8378910 3 Posted April 16, 2017 Posted April 16, 2017 Hi, just comment line 638 in main.js like below. if (commandLineArguments.length > 0) { // app.setPath('userData', commandLineArguments[0]);} I did a "console.log" for that commandLineArgument[0] and get "--disable-gpu" as the printout, which seem a bit strange to me. Anyway, works fine without the call to app.setPath. I'm running emby-theater on Debian testing and on this latest repo I need to install some more modules by "npm: node-mpv, meow, long". Additional I have to uninstall first "is-windows and power-off" and then install them again via "npm" to fix version dependencies. A "npm list" will show you the missing or wrong versioned modules and give a clean list after the above steps. Then emby-theater-electron works fine. Hope this helps. BTW: I'm fighting still with fullscreen mode on my zotacID80 box (a LG TV attached via HDMI to it). Only sometimes it really switches to fullscreen (no minimize, maximize or close button on the upper left) and only then, the movie will make it's way to the TV and played fine. If these buttons are there after the start of emby-theater, then the playback will not show up. You will here sound, but just some distortion at the border of the emby-theater main window. If this is fixed, I can get rid of Kodi as my TV player... ;-) 1
denz 501 Posted April 17, 2017 Posted April 17, 2017 (edited) It certainly did I had to follow your post exactly to get it to load but when it finally loaded nothing plays video or audio all I get is spinning circle. There is nothing in console to indicate that is is starting to play something it is the same as it was when emby loaded, when i look at the emby dashboard it is showing that music is playing also the et.sh needs the execute bit set. Log (1).txt Edited April 17, 2017 by denz
frabe8378910 3 Posted April 18, 2017 Posted April 18, 2017 It certainly did I had to follow your post exactly to get it to load but when it finally loaded nothing plays video or audio all I get is spinning circle. There is nothing in console to indicate that is is starting to play something it is the same as it was when emby loaded, when i look at the emby dashboard it is showing that music is playing also the et.sh needs the execute bit set. I did some further "digging" yesterday and found the following statement as the root cause for not playing. It will prevent the "real fullscreen" on my zotac box (you'll always have the minimize, maximize and close button on upper right corner). Commented the line "mainWindow webContents ..." will give me a full function emby-theater. And sure, et.sh needs a "chmod 755" ... ;-) //mainWindow.openDevTools(); mainWindow.webContents.on('dom-ready', setStartInfo); BTW. The last pull seems to fix the "app.setPath('userData', commandLineArguments[0]);" error .... 1
Luke 42237 Posted April 19, 2017 Posted April 19, 2017 Thanks, give it another shot. we are re-working quite a bit so a lot is currently being torn apart, but in the coming days it will come together very nicely. Thanks. 1
denz 501 Posted April 19, 2017 Posted April 19, 2017 Still no luck same error but in the console it has an url now.
frabe8378910 3 Posted April 19, 2017 Posted April 19, 2017 Thanks, give it another shot. we are re-working quite a bit so a lot is currently being torn apart, but in the coming days it will come together very nicely. Thanks. On my latest pull 2 days ago I recognized that I can move "node-mpv" and the "mpv" binary away and emby-theater-electron ist still playing my movies .... @Luke: Who is playing it? Did we have an intrinsic player now?
haraldov 10 Posted April 19, 2017 Posted April 19, 2017 (edited) I want to share how to compile mpv from git running on rpi3 with the last (April 17) Raspbian jessie. If you do not want to compile you can download an older version of mpv with mmal support from here https://nwgat.ninja/quick-easy-compiling-mpv-for-raspberry-pi/ # On recent Raspbian jessie, you have to run RPi-update # to obtain /opt/vc/lib/pkgconfig Source: https://github.com/mpv-player/mpv-build/issues/84 sudo apt install rpi-update && sudo rpi-update && sudo reboot # Add PKG_CONFIG_PATH and LIBRARY_PATH before running mpv-build # Source: https://github.com/mpv-player/mpv-build/issues/84, https://github.com/mpv-player/mpv-build/issues/83 # and https://github.com/mpv-player/mpv-build/issues/98 export PKG_CONFIG_PATH=/opt/vc/lib/pkgconfig export LIBRARY_PATH=/opt/vc/lib export LDFLAGS=-L/opt/vc/lib export CPATH=/opt/vc/include # Prepare Ubuntu build packages Source: https://help.ubuntu.com/community/CompilingEasyHowTo sudo apt-get install build-essential checkinstall sudo apt-get install cvs subversion git-core mercurial # Use mpv-build helper scripts to compile mpv on Raspbian. Source: https://github.com/mpv-player/mpv-build sudo apt-get install git devscripts equivs git clone https://github.com/mpv-player/mpv-build.git cd mpv-build echo --enable-mmal >> ffmpeg_options ./use-mpv-release ./update rm -f mpv-build-deps_*_*.deb mk-build-deps -s sudo -i dpkg-buildpackage -uc -us -b -j4 # Install deb package: sudo dpkg -i ../mpv_<version>_<architecture>.deb sudo dpkg -i ../mpv_2017.04.20.4b4dee0_armhf.deb # Mpv need 256 Mb on rpi2 and 3 echo "gpu_mem=256" >> /boot/config.txt # Make mpv config file mkdir -p $HOME/.config/mpv nano $HOME/.config/mpv/mpv.conf # And paste this text in for mpv > version 0.22.0 # Source: https://mpv.io/manual/master/#video-output-drivers # Use rpi video output by default. vo=opengl # Use rpi hardware acceleration hwdec=rpi Edited December 31, 2017 by haraldov
denz 501 Posted April 20, 2017 Posted April 20, 2017 Since others don't have the issues I am having is that because I use rpi or I am not doing something right. The Linux theatre that is hit and miss so I will remove MPV and compile it using Haraldov instructions.
Luke 42237 Posted April 20, 2017 Posted April 20, 2017 On my latest pull 2 days ago I recognized that I can move "node-mpv" and the "mpv" binary away and emby-theater-electron ist still playing my movies .... @Luke: Who is playing it? Did we have an intrinsic player now? Mpv is playing it. 1
denz 501 Posted April 20, 2017 Posted April 20, 2017 Still the same error and noticed that you cannot maximise if you press the maximise it just puts the window in top left corner.
denz 501 Posted April 20, 2017 Posted April 20, 2017 (edited) I tried to build the mpv but it is not working it requires so many dependencies and when I tried to download them it can't find some of them. It is not important since the mpv I found on the internet works it just doesn't work very well with emby theater linux it is not smooth like it is not using hardware decoding. When I run the command from shell it is all smooth but only if I remove vo=opengl from mpv.conf Edited April 20, 2017 by denz
haraldov 10 Posted April 20, 2017 Posted April 20, 2017 (edited) @@denz I have updated my mpv howto with the required package dependency and missing LIBRARY_PATH. Can you try to compile mpv again? It works for me. When I run the command from shell it is all smooth but only if I remove vo=opengl from mpv.conf Video output documentation for mpv version 0.24 rpi (Raspberry Pi) Native video output on the Raspberry Pi using the MMAL API. This is deprecated. Use --vo=opengl instead, which is the default and provides the same functionality. The rpi VO will be removed in mpv 0.23.0. Its functionality was folded into --vo=opengl, which now uses RPI hardware decoding by treating it as a hardware overlay (without applying GL filtering). Also to be changed in 0.23.0: the --fs flag will be reset to "no" by default (like on the other platforms). Edited April 20, 2017 by haraldov 1
frabe8378910 3 Posted April 20, 2017 Posted April 20, 2017 (edited) Mpv is playing it. Not possible, expect emby-theater-electron has a mpv player which will be install when I do a "git clone ...". When playing a recorded movie with emby-theater-linux I have "/usr/bin/mpv" in the process list, I also see the socket "/tmp/node-mpv". After switching to emby-theater-electron there are only "electron" processes running while playing a movie and NO socket. So I'm trying to figure out, which executable is playing the movie. For testing I temporary uninstalled "/usr/bin/mpv" and also "node-mpv" (npm uninstall node-mpv), but emby-theater-electron is STILL playing the movie. And sure, I did a reboot after the uninstall, to ensure that NO "mpv" remaining in memory. ;-) The reason I need to know which executable is the player, is to be able to configure stuff like video output or HW encoding. For example "/usr/bin/mpv" reads $HOME/.config/mpv/mvp.conf, but electron (or its build-in player) does not read that. Thank's a lot for enlighting me ... Edited April 20, 2017 by frabe8378910
