clarkss12 304 Posted March 22, 2019 Posted March 22, 2019 I can't find a single video of Emby Theater running on a Pi or other Linux devices......... Anyone have a link to a video?? Thanks.
ellnic 26 Posted March 22, 2019 Posted March 22, 2019 @@clarkss12 you mean an install guide or just a video showing it works? You probably won’t find either because of its current state. It’s still very much WIP. I’d certainly forget the Pi for now. It’s a sub-par experience in my testing. Sent from my iPhone using Tapatalk
clarkss12 304 Posted March 22, 2019 Posted March 22, 2019 @@clarkss12 you mean an install guide or just a video showing it works? You probably won’t find either because of its current state. It’s still very much WIP. I’d certainly forget the Pi for now. It’s a sub-par experience in my testing. Sent from my iPhone using Tapatalk I am looking for a video that shows it in operation, what it looks like, etc. How to install it, would be the next question, AFTER I see what it looks like running on a very low powered hardware running Linux as the sub OS. I would like something similar to this, running on a $30 Amlogic stick, with a Linux based OS. Basically a stand alone device that only uses Emby as the interface. https://www.youtube.com/watch?v=6AuuSgCORLg
Luke 42240 Posted March 22, 2019 Posted March 22, 2019 You can preview the UI using the web version at http://tv.emby.media
ellnic 26 Posted March 22, 2019 Posted March 22, 2019 (edited) For Amlogic Linux check out Armbian and CoreELEC. But IMHO, you would be WAY better off getting something like ATVXperience on that stick if they support it. I have several Amlogic boxes and they work far better with a decent ROM than any of the Linux offerings right now. I run ATVX on all of them and the Emby app for Android TV is great. I had an issue a while back but it turned out to be a faulty PSU, so nothing to do with Emby. I too would love an OpenELEC style ROM for the Pi and other ARM chips, but we aren’t there yet. Sent from my iPhone using Tapatalk Edited March 22, 2019 by ellnic
clarkss12 304 Posted March 22, 2019 Posted March 22, 2019 You can preview the UI using the web version at http://tv.emby.media Ok, thanks.
clarkss12 304 Posted March 22, 2019 Posted March 22, 2019 For Amlogic Linux check out Armbian and CoreELEC. But IMHO, you would be WAY better off getting something like ATVXperience on that stick if they support it. I have several Amlogic boxes and they work far better with a decent ROM than any of the Linux offerings right now. I run ATVX on all of them and the Emby app for Android TV is great. I had an issue a while back but it turned out to be a faulty PSU, so nothing to do with Emby. I too would love an OpenELEC style ROM for the Pi and other ARM chips, but we aren’t there yet. Sent from my iPhone using Tapatalk Yes, I also have an abundance of those Android boxes, running Armbian version of Ubuntu, CoreELEC and LibreELEC. One of my Amlogic S905 boxes is running OpenPHT, but like to be able to have the Emby Theater running on one of these low powered boxes. So, the box boots directly into EHT, like the OpenPHT. I have tried a couple of times, running it on one of my boxes running Linux, but was not successful... I would like to see EHT running on the Pi..
ellnic 26 Posted March 22, 2019 Posted March 22, 2019 (edited) You could just autostart the Emby app under Android? Would this not have the same functionality? These Amlogic boxes work a lot better under Android anyway. Sent from my iPhone using Tapatalk Edited March 22, 2019 by ellnic
clarkss12 304 Posted March 23, 2019 Posted March 23, 2019 You could just autostart the Emby app under Android? Would this not have the same functionality? These Amlogic boxes work a lot better under Android anyway. Sent from my iPhone using Tapatalk None of these cheap Chinese Android boxes, support HD audio or automatic frame rate change. Unless they are running CoreELEC, then they play everything. Also, these cheap Chinese amlogic boxes will not play videos encoded in VC-1, without stuttering, under Android. That's why I was looking for a solution, that is based on libreELEC, like they Plex Home Theater. 1
doffactory 3 Posted April 3, 2019 Posted April 3, 2019 The Emby Theater Electron in Post #454 works fantastic for Ubuntu 18.04. Here's the install sequence.... Uninstall the .deb Version..... sudo apt-get remove --purge emby-theater_3.0.4_amd64.deb sudo apt-get install cec-utils sudo apt-get install npm git clone https://github.com/electron/electron-quick-start cd electron-quick-start/ npm install cd ~ git clone https://github.com/MediaBrowser/emby-theater-electron cd emby-theater-electron/ npm install npm start Only bad thing is I don't think this is supported anymore...Kinda confused on this........ Here's a desktop Icon if you like..... gedit ~/Desktop/EmbyTheater.desktop #!/usr/bin/env xdg-open [Desktop Entry] Version=1.0 Type=Application Terminal=true Exec=/home/steve/exec.sh Name=EmbyTheater Comment=ET Icon=/home/steve/et.png exec.sh cd /home/steve/emby-theater-electron env XDG_CURRENT_DESKTOP=Ubuntu npm start Not sure whether this was reported, but I was successful in installing it this way. The only problem is that on ubuntu 18.04 I have a black screen until the controls are visible. As soon as the controls automatically disappear, the video appears. Quite annoying ... 1
Luke 42240 Posted April 3, 2019 Posted April 3, 2019 The next update to the app will hopefully resolve that, thanks.
doffactory 3 Posted April 3, 2019 Posted April 3, 2019 The next update to the app will hopefully resolve that, thanks. ETA maybe?
Luke 42240 Posted April 3, 2019 Posted April 3, 2019 Very soon. I've been trying to hold out for the Electron 5.0 release. 3
ellnic 26 Posted April 4, 2019 Posted April 4, 2019 (edited) None of these cheap Chinese Android boxes, support HD audio or automatic frame rate change.That’s why I suggested ATVX. It has frame rate switching and high def audio. Unless they are running CoreELEC, then they play everything. Also, these cheap Chinese amlogic boxes will not play videos encoded in VC-1, without stuttering, under Android.Sounds like a cheap Chinese Android box is not what you need ;-) If it only works with coreELEC, and has no VC1, you should have checked the status of Emby theatre for Linux first to see if someone else had any luck. That's why I was looking for a solution, that is based on libreELEC, like they Plex Home Theater.Maybe you wanted something like a NUC? Sent from my iPhone using Tapatalk Edited April 4, 2019 by ellnic
Guest Econaut Posted April 21, 2019 Posted April 21, 2019 Does anyone know how this works for the Pi 3 B+ ?
Luke 42240 Posted April 21, 2019 Posted April 21, 2019 Does anyone know how this works for the Pi 3 B+ ? Hi, did you try following the install instructions in the first post?
EODCrafter 181 Posted April 22, 2019 Posted April 22, 2019 Hi, did you try following the install instructions in the first post? @@Luke , Still Very Very Buggy in Ubuntu, don't see how this would be much better in Pi, TBH.
denz 501 Posted April 22, 2019 Posted April 22, 2019 If you have interlaced content and want direct play there is no point at all installing it. So far the best app for emby on tv is Android TV follow by roku and long way down is emby theatre which you get when installing on pi.
EODCrafter 181 Posted April 22, 2019 Posted April 22, 2019 (edited) If you have interlaced content and want direct play there is no point at all installing it. So far the best app for emby on tv is Android TV follow by roku and long way down is emby theatre which you get when installing on pi. I always end up using the Server Interface for my Ubuntu, I really wish there was a Better App to View TV on a PC.....One that will make Remote Control Functions Possible. Edited April 22, 2019 by EODCrafter
echoxxzz 22 Posted April 29, 2019 Posted April 29, 2019 I tried the 3.08 update on Ubunut 18.04.2 and I have the same issue as 3.06. I can hear the video but just get a black display. I've updated to the latest MPV (Ubuntu by default is an old release) and same problem.
Luke 42240 Posted April 29, 2019 Posted April 29, 2019 We have not yet packaged the 3.0.8 release for download. Please wait until we have done that and then try again. thanks.
Luke 42240 Posted April 30, 2019 Posted April 30, 2019 The first post has been updated with the 3.0.8 release. Please try it out. Thanks guys.
laufferb 0 Posted April 30, 2019 Posted April 30, 2019 (edited) The first post has been updated with the 3.0.8 release. Please try it out. Thanks guys. Test 3.0.8. (Ubuntu 19.04) When I move the mouse it gets a black screen, you can see only the control panel. When the panel disappears, film returns. Edited April 30, 2019 by laufferb
Luke 42240 Posted April 30, 2019 Posted April 30, 2019 That's because the transparency features we need to display the OSD on top of the video are not supported on this platform. We'll look for a better way in the future.
