EODCrafter 181 Posted November 2, 2018 Posted November 2, 2018 VLC Plays the Stream Flawlessly but I don't know how to set it in the External Players Section....
EODCrafter 181 Posted November 2, 2018 Posted November 2, 2018 (edited) Edit...Oh hell I figured it out...it was really that simple? lol. UREKA! If you set Mpv/VLC as the external player when you exit it it goes back to ET...Whew! Woo-Hoo with VLC Subtitles are now on Emby! Edited November 3, 2018 by EODCrafter
ellnic 26 Posted November 3, 2018 Posted November 3, 2018 Last time I reported it to Luke he said I was the only one with this issue....In fairness I just said "it didn't work" which is true but in a way (At the time I didn't realize the video was actually playing in the background but there was no way to navigate to it).... https://emby.media/community/index.php?/topic/42868-emby-theater-for-linux/page-23&do=findComment&comment=634409 Idk, I think it’s maybe crossed wires. Luke said the instructions are in the first post - he edited the post to include the new .deb packages in September, and there should be no need to manually do anything with npm or electron. Consider all other methods now defunct unless you’re using a non Debian based 64bit system. You were talking about NPM and electron in October and it was probably attributed to you not being able to get up and running because you were using an out of date process. Glad you seem to be having some more luck now though. @@Luke, these overlay issues do seem to be a bit of a gtk issue though and aren’t limited to a particular OS/Architecture/DE, are fixes in the pipeline? I’m going to have a play today if I get the time and see if I can get it to behave a bit differently. Sent from my iPhone using Tapatalk
EODCrafter 181 Posted November 3, 2018 Posted November 3, 2018 (edited) Idk, I think it’s maybe crossed wires. Luke said the instructions are in the first post - he edited the post to include the new .deb packages in September, and there should be no need to manually do anything with npm or electron. Consider all other methods now defunct unless you’re using a non Debian based 64bit system. You were talking about NPM and electron in October and it was probably attributed to you not being able to get up and running because you were using an out of date process. Glad you seem to be having some more luck now though. @@Luke, these overlay issues do seem to be a bit of a gtk issue though and aren’t limited to a particular OS/Architecture/DE, are fixes in the pipeline? I’m going to have a play today if I get the time and see if I can get it to behave a bit differently. Sent from my iPhone using Tapatalk Actually the Out of date process works fine with no overlay issues it's just a bit rough around the Edges and a bit quirky. I have the new ET working using an external player and I'm happy with that. It wouldn't be crossed wires cause I completely removed all the old build and the overlay issues still happen without use of external player. @@Luke .... Thanks really doesn't answer this question, unless it's of course the usual answer...Future release......I would of thought Ubuntu would be the "accepted" Platform but it seems that all the RPI folks have no issues at all....Oh well. @Luke, these overlay issues do seem to be a bit of a gtk issue though and aren’t limited to a particular OS/Architecture/DE, are fixes in the pipeline? Edited November 3, 2018 by EODCrafter
ellnic 26 Posted November 4, 2018 Posted November 4, 2018 Actually the Kirby photo I attached is on a Pi.... Sent from my iPhone using Tapatalk
EODCrafter 181 Posted November 4, 2018 Posted November 4, 2018 (edited) Actually the Kirby photo I attached is on a Pi.... Sent from my iPhone using Tapatalk So it doesn't work on any OS? (Linux) .....Not Important...I'll stick by Emby till we get all the Bugs worked out. It's just too good in other places to be ignored.... Edited November 4, 2018 by EODCrafter
EODCrafter 181 Posted November 4, 2018 Posted November 4, 2018 @@Luke ..... I tried sudo apt-get install libgtk-3-dev Didn't help Ubuntu 18.04 ET 3.0.4 AMD64
ellnic 26 Posted November 4, 2018 Posted November 4, 2018 So it doesn't work on any OS? (Linux) .....Not Important...I'll stick by Emby till we get all the Bugs worked out. It's just too good in other places to be ignored.... I agree, it’s second to none. The majority of the apps are too. I think we’re just in a bit of a transition period whereby some of the apps are being rebuilt from the ground up and there will be aches and pains. One thing I would maybe suggest (and I don’t mean to tell you how to run your brain child @@Luke and @ebr) is that the server receives regular and excellent updates but we really need more focus for the moment on the clients. I don’t mean to compare apples to oranges but if you look at Emby vs Plex right now, we see that Plex’s clients are fast and mostly bug free (despite being restrictive - like on OpenELEC for example) but their server sucks (metadata for example) and the whole direction they are moving in is bad (streaming service for other people’s media). Whereas if we look at Emby, the server is awesome. Totally awesome - and it gets better and better without fail every release. It’s feature set, metadata management, everything are on point and beyond. We just need that to be shelved for a second and some of the legendary Luke and ebr ‘midnight oil’ work to be done on the clients :-) hope these comments are taken as intended. Sent from my iPhone using Tapatalk
EODCrafter 181 Posted November 4, 2018 Posted November 4, 2018 (edited) I'm actually happy with using the External Player to solve the issue but if the fix is that simple it seems it can be added with a couple of keystrokes to the Main Java run file. It has something to do with the Window Maximizing then covering the player Window, although I know diddly about programming. (This is a edited version I use to work with External VLC) (function () { var electron = require('electron'); var app = electron.app; // Module to control application life. var BrowserWindow = electron.BrowserWindow; // Module to create native browser window. // Keep a global reference of the window object, if you don't, the window will // be closed automatically when the JavaScript object is garbage collected. var mainWindow = null; var playerWindow = null; var hasAppLoaded = false; var enableDevTools = false; var enableDevToolsOnStartup = false; var initialShowEventsComplete = false; var previousBounds; var cecProcess; // Quit when all windows are closed. app.on('window-all-closed', function () { // On OS X it is common for applications and their menu bar // to stay active until the user quits explicitly with Cmd + Q if (process.platform != 'darwin') { app.quit(); } }); function onWindowMoved() { mainWindow.webContents.executeJavaScript('window.dispatchEvent(new CustomEvent("move", {}));'); var winPosition = mainWindow.getPosition(); playerWindow.setPosition(winPosition[0], winPosition[1]); } function onWindowResize() { var winSize = mainWindow.getSize(); playerWindow.setSize(winSize[0], winSize[1]); } var currentWindowState = 'Maximized'; var restoreWindowState; function setWindowState(state) { restoreWindowState = null; var previousState = currentWindowState; if (state == 'Maximized') { state = 'Fullscreen'; } if (state == 'Minimized') { restoreWindowState = previousState; mainWindow.setAlwaysOnTop(false); mainWindow.minimize(); } else if (state == 'Maximized') { if (previousState == "Minimized") { mainWindow.restore(); } mainWindow.maximize(); mainWindow.setAlwaysOnTop(false); } else if (state == 'Fullscreen') { if (previousState == "Minimized") { mainWindow.restore(); } var bounds = mainWindow.getBounds(); previousBounds = bounds; mainWindow.setFullScreen(true); mainWindow.setAlwaysOnTop(true); // So far this is only needed for returning from external player playback mainWindow.focus(); } else { var setSize = false; if (previousState == "Minimized") { mainWindow.restore(); } else if (previousState == "Fullscreen") { setSize = true; mainWindow.setFullScreen(false); } else if (previousState == "Maximized") { mainWindow.unmaximize(); } if (setSize) { var bounds = previousBounds; if (bounds) { mainWindow.setBounds(bounds); } else { mainWindow.setSize(1280, 720); mainWindow.center(); } } mainWindow.setAlwaysOnTop(false); } } function onWindowStateChanged(state) { currentWindowState = state; mainWindow.webContents.executeJavaScript('document.windowState="' + state + '";document.dispatchEvent(new CustomEvent("windowstatechanged", {detail:{windowState:"' + state + '"}}));'); } function onMinimize() { playerWindow.minimize(); onWindowStateChanged('Normal'); } function onRestore() { var restoreState = restoreWindowState; restoreWindowState = null; if (restoreState && restoreState != 'Normal' && restoreState != 'Minimized') { setWindowState(restoreState); } else { onWindowStateChanged('Normal'); } playerWindow.restore(); } function onMaximize() { onWindowStateChanged('Maximized'); } function onEnterFullscreen() { onWindowStateChanged('Fullscreen'); if (initialShowEventsComplete) { //playerWindow.setFullScreen(true); mainWindow.setMovable(false); } } function onLeaveFullscreen() { onWindowStateChanged('Normal'); if (initialShowEventsComplete) { playerWindow.setFullScreen(false); mainWindow.setMovable(true); } } function onUnMaximize() { onWindowStateChanged('Normal'); } var customFileProtocol = 'electronfile'; function addPathIntercepts() { var protocol = electron.protocol; var path = require('path'); protocol.registerFileProtocol(customFileProtocol, function (request, callback) { // Add 3 to account for :// var url = request.url.substr(customFileProtocol.length + 3); url = __dirname + '/' + url; url = url.split('?')[0]; callback({ path: path.normalize(url) }); }); //protocol.interceptHttpProtocol('https', function (request, callback) { // alert(request.url); // callback({ 'url': request.url, 'referrer': request.referrer, session: null }); //}); } function sleepSystem() { var sleepMode = require('sleep-mode'); sleepMode(function (err, stderr, stdout) { }); } function restartSystem() { } function shutdownSystem() { var powerOff = require('power-off'); powerOff(function (err, stderr, stdout) { }); } function setMainWindowResizable(resizable) { try { mainWindow.setResizable(resizable); } catch (err) { console.log('Error in setResizable:' + err); } } var isTransparencyRequired = false; var windowStateOnLoad; function registerAppHost() { var protocol = electron.protocol; var customProtocol = 'electronapphost'; protocol.registerStringProtocol(customProtocol, function (request, callback) { // Add 3 to account for :// var url = request.url.substr(customProtocol.length + 3); var parts = url.split('?'); var command = parts[0]; switch (command) { case 'windowstate-Normal': setMainWindowResizable(!isTransparencyRequired); setWindowState('Normal'); break; case 'windowstate-Maximized': setMainWindowResizable(false); setWindowState('Maximized'); break; case 'windowstate-Fullscreen': setMainWindowResizable(false); setWindowState('Fullscreen'); break; case 'windowstate-Minimized': setWindowState('Minimized'); break; case 'exit': closeWindow(mainWindow); break; case 'sleep': sleepSystem(); break; case 'shutdown': shutdownSystem(); break; case 'restart': restartSystem(); break; case 'openurl': electron.shell.openExternal(url.substring(url.indexOf('url=') + 4)); break; case 'shellstart': var options = require('querystring').parse(parts[1]); startProcess(options, callback); return; case 'shellclose': closeProcess(require('querystring').parse(parts[1]).id, callback); return; case 'video-on': isTransparencyRequired = true; setMainWindowResizable(false); break; case 'video-off': isTransparencyRequired = false; setMainWindowResizable(true); break; case 'loaded': if (windowStateOnLoad) { setWindowState(windowStateOnLoad); } mainWindow.focus(); hasAppLoaded = true; onLoaded(); break; } callback(""); }); } function onLoaded() { //var globalShortcut = electron.globalShortcut; //globalShortcut.register('mediastop', function () { // sendCommand('stop'); //}); //globalShortcut.register('mediaplaypause', function () { //}); sendJavascript('window.PlayerWindowId="' + getWindowId(playerWindow) + '";'); } var processes = {}; function startProcess(options, callback) { var pid; var args = (options.arguments || '').split('|||'); try { var process = require('child_process').execFile(options.path, args, {}, function (error, stdout, stderr) { if (error) { console.log('Process closed with error: ' + error); } processes[pid] = null; var script = 'onChildProcessClosed("' + pid + '", ' + (error ? 'true' : 'false') + ');'; sendJavascript(script); }); pid = process.pid.toString(); processes[pid] = process; callback(pid); } catch (err) { alert('Error launching process: ' + err); } } function closeProcess(id, callback) { var process = processes[id]; if (process) { process.kill(); } callback(""); } function registerFileSystem() { var protocol = electron.protocol; var customProtocol = 'electronfs'; protocol.registerStringProtocol(customProtocol, function (request, callback) { // Add 3 to account for :// var url = request.url.substr(customProtocol.length + 3).split('?')[0]; var fs = require('fs'); switch (url) { case 'fileexists': case 'directoryexists': var path = request.url.split('=')[1]; fs.access(path, (err) => { if (err) { console.error('fs access result for path: ' + err); callback('false'); } else { callback('true'); } }); break; default: callback(""); break; } }); } function registerServerdiscovery() { var protocol = electron.protocol; var customProtocol = 'electronserverdiscovery'; var serverdiscovery = require('./serverdiscovery/serverdiscovery-native'); protocol.registerStringProtocol(customProtocol, function (request, callback) { // Add 3 to account for :// var url = request.url.substr(customProtocol.length + 3).split('?')[0]; switch (url) { case 'findservers': var timeoutMs = request.url.split('=')[1]; serverdiscovery.findServers(timeoutMs, callback); break; default: callback(""); break; } }); } function registerWakeOnLan() { var protocol = electron.protocol; var customProtocol = 'electronwakeonlan'; var wakeonlan = require('./wakeonlan/wakeonlan-native'); protocol.registerStringProtocol(customProtocol, function (request, callback) { // Add 3 to account for :// var url = request.url.substr(customProtocol.length + 3).split('?')[0]; switch (url) { case 'wakeserver': var mac = request.url.split('=')[1].split('&')[0]; var options = {port: request.url.split('=')[2]}; wakeonlan.wake(mac, options, callback); break; default: callback(""); break; } }); } function alert(text) { electron.dialog.showMessageBox(mainWindow, { message: text.toString(), buttons: ['ok'] }); } function replaceAll(str, find, replace) { return str.split(find).join(replace); } function getAppBaseUrl() { var url = 'https://tv.emby.media'; //url = 'http://localhost:8088'; return url; } function getAppUrl() { var url = getAppBaseUrl() + '/index.html?autostart=false'; //url += '?v=' + new Date().getTime(); return url; } var startInfoJson; function loadStartInfo() { return new Promise(function (resolve, reject) { var os = require("os"); var path = require('path'); var fs = require('fs'); var topDirectory = path.normalize(__dirname); var pluginDirectory = path.normalize(__dirname + '/plugins'); var scriptsDirectory = path.normalize(__dirname + '/scripts'); fs.readdir(pluginDirectory, function (err, pluginFiles) { fs.readdir(scriptsDirectory, function (err, scriptFiles) { pluginFiles = pluginFiles || []; scriptFiles = scriptFiles || []; var startInfo = { paths: { apphost: customFileProtocol + '://apphost', shell: customFileProtocol + '://shell', wakeonlan: customFileProtocol + '://wakeonlan/wakeonlan', serverdiscovery: customFileProtocol + '://serverdiscovery/serverdiscovery', fullscreenmanager: 'file://' + replaceAll(path.normalize(topDirectory + '/fullscreenmanager.js'), '\\', '/'), filesystem: customFileProtocol + '://filesystem' }, name: app.getName(), version: app.getVersion(), deviceName: os.hostname(), deviceId: os.hostname(), supportsTransparentWindow: supportsTransparentWindow(), plugins: pluginFiles.filter(function (f) { return f.indexOf('.js') != -1; }).map(function (f) { return 'file://' + replaceAll(path.normalize(pluginDirectory + '/' + f), '\\', '/'); }), scripts: scriptFiles.map(function (f) { return 'file://' + replaceAll(path.normalize(scriptsDirectory + '/' + f), '\\', '/'); }) }; startInfoJson = JSON.stringify(startInfo); resolve(); }); }); }); } function setStartInfo() { var script = 'function startWhenReady(){if (self.Emby && self.Emby.App){self.appStartInfo=' + startInfoJson + ';Emby.App.start(appStartInfo);} else {setTimeout(startWhenReady, 50);}} startWhenReady();'; sendJavascript(script); //sendJavascript('var appStartInfo=' + startInfoJson + ';'); } function sendCommand(cmd) { var script = "require(['inputmanager'], function(inputmanager){inputmanager.trigger('" + cmd + "');});"; sendJavascript(script); } function sendJavascript(script) { // Add some null checks to handle attempts to send JS when the process is closing or has closed var win = mainWindow; if (win) { var web = win.webContents; if (web) { web.executeJavaScript(script); } } } function onAppCommand(e, cmd) { //switch (command_id) { // case APPCOMMAND_BROWSER_BACKWARD : return "browser-backward"; // case APPCOMMAND_BROWSER_FORWARD : return "browser-forward"; // case APPCOMMAND_BROWSER_REFRESH : return "browser-refresh"; // case APPCOMMAND_BROWSER_STOP : return "browser-stop"; // case APPCOMMAND_BROWSER_SEARCH : return "browser-search"; // case APPCOMMAND_BROWSER_FAVORITES : return "browser-favorites"; // case APPCOMMAND_BROWSER_HOME : return "browser-home"; // case APPCOMMAND_VOLUME_MUTE : return "volume-mute"; // case APPCOMMAND_VOLUME_DOWN : return "volume-down"; // case APPCOMMAND_VOLUME_UP : return "volume-up"; // case APPCOMMAND_MEDIA_NEXTTRACK : return "media-nexttrack"; // case APPCOMMAND_MEDIA_PREVIOUSTRACK : return "media-previoustrack"; // case APPCOMMAND_MEDIA_STOP : return "media-stop"; // case APPCOMMAND_MEDIA_PLAY_PAUSE : return "media-play-pause"; // case APPCOMMAND_LAUNCH_MAIL : return "launch-mail"; // case APPCOMMAND_LAUNCH_MEDIA_SELECT : return "launch-media-select"; // case APPCOMMAND_LAUNCH_APP1 : return "launch-app1"; // case APPCOMMAND_LAUNCH_APP2 : return "launch-app2"; // case APPCOMMAND_BASS_DOWN : return "bass-down"; // case APPCOMMAND_BASS_BOOST : return "bass-boost"; // case APPCOMMAND_BASS_UP : return "bass-up"; // case APPCOMMAND_TREBLE_DOWN : return "treble-down"; // case APPCOMMAND_TREBLE_UP : return "treble-up"; // case APPCOMMAND_MICROPHONE_VOLUME_MUTE : return "microphone-volume-mute"; // case APPCOMMAND_MICROPHONE_VOLUME_DOWN : return "microphone-volume-down"; // case APPCOMMAND_MICROPHONE_VOLUME_UP : return "microphone-volume-up"; // case APPCOMMAND_HELP : return "help"; // case APPCOMMAND_FIND : return "find"; // case APPCOMMAND_NEW : return "new"; // case APPCOMMAND_OPEN : return "open"; // case APPCOMMAND_CLOSE : return "close"; // case APPCOMMAND_SAVE : return "save"; // case APPCOMMAND_PRINT : return "print"; // case APPCOMMAND_UNDO : return "undo"; // case APPCOMMAND_REDO : return "redo"; // case APPCOMMAND_COPY : return "copy"; // case APPCOMMAND_CUT : return "cut"; // case APPCOMMAND_PASTE : return "paste"; // case APPCOMMAND_REPLY_TO_MAIL : return "reply-to-mail"; // case APPCOMMAND_FORWARD_MAIL : return "forward-mail"; // case APPCOMMAND_SEND_MAIL : return "send-mail"; // case APPCOMMAND_SPELL_CHECK : return "spell-check"; // case APPCOMMAND_MIC_ON_OFF_TOGGLE : return "mic-on-off-toggle"; // case APPCOMMAND_CORRECTION_LIST : return "correction-list"; // case APPCOMMAND_MEDIA_PLAY : return "media-play"; // case APPCOMMAND_MEDIA_PAUSE : return "media-pause"; // case APPCOMMAND_MEDIA_RECORD : return "media-record"; // case APPCOMMAND_MEDIA_FAST_FORWARD : return "media-fast-forward"; // case APPCOMMAND_MEDIA_REWIND : return "media-rewind"; // case APPCOMMAND_MEDIA_CHANNEL_UP : return "media-channel-up"; // case APPCOMMAND_MEDIA_CHANNEL_DOWN : return "media-channel-down"; // case APPCOMMAND_DELETE : return "delete"; // case APPCOMMAND_DICTATE_OR_COMMAND_CONTROL_TOGGLE: // return "dictate-or-command-control-toggle"; // default: // return "unknown"; if (cmd != 'Unknown') { //alert(cmd); } switch (cmd) { case 'browser-backward': if (mainWindow.webContents.canGoBack()) { mainWindow.webContents.goBack(); } break; case 'browser-forward': if (mainWindow.webContents.canGoForward()) { mainWindow.webContents.goForward(); } break; case 'browser-stop': sendCommand("stop"); break; case 'browser-search': sendCommand("search"); break; case 'browser-favorites': sendCommand("favorites"); break; case 'browser-home': sendCommand("home"); break; case 'browser-refresh': sendCommand("refresh"); break; case 'find': sendCommand("search"); break; case 'volume-mute': sendCommand("togglemute"); break; case 'volume-down': sendCommand("volumedown"); break; case 'volume-up': sendCommand("volumeup"); break; case 'media-nexttrack': sendCommand("next"); break; case 'media-previoustrack': sendCommand("previous"); break; case 'media-stop': sendCommand("stop"); break; case 'media-play': sendCommand("play"); break; case 'media-pause': sendCommand("pause"); break; case 'media-record': sendCommand("record"); break; case 'media-fast-forward': sendCommand("fastforward"); break; case 'media-rewind': sendCommand("rewind"); break; case 'media-play-pause': sendCommand("playpause"); break; case 'media-channel-up': sendCommand("channelup"); break; case 'media-channel-down': sendCommand("channeldown"); break; case 'menu': sendCommand("menu"); break; case 'info': sendCommand("info"); break; } } function setCommandLineSwitches() { var isLinux = require('is-linux'); if (isLinux()) { app.commandLine.appendSwitch('enable-transparent-visuals'); app.disableHardwareAcceleration(); } else if (process.platform === 'win32') { //app.disableHardwareAcceleration(); app.commandLine.appendSwitch('high-dpi-support', 'true'); app.commandLine.appendSwitch('force-device-scale-factor', '1'); } } function supportsTransparentWindow() { return true; } function getWindowStateDataPath() { var path = require("path"); return path.join(app.getPath('userData'), "windowstate.json"); } function closeWindow(win) { try { win.close(); } catch (err) { console.log('Error closing window. It may have already been closed. ' + err); } } function onWindowClose() { if (hasAppLoaded) { var data = mainWindow.getBounds(); data.state = currentWindowState; var windowStatePath = getWindowStateDataPath(); require("fs").writeFileSync(windowStatePath, JSON.stringify(data)); } mainWindow.webContents.executeJavaScript('AppCloseHelper.onClosing();'); // Unregister all shortcuts. electron.globalShortcut.unregisterAll(); closeWindow(playerWindow); if (cecProcess) { cecProcess.kill(); } app.quit(); } function parseCommandLine() { var isWindows = require('is-windows'); var result = {}; var commandLineArguments = process.argv.slice(2); var index = 0; if (isWindows()) { result.userDataPath = commandLineArguments[index]; index++; } result.cecExePath = commandLineArguments[index] || 'cec-client'; index++; result.mpvPath = commandLineArguments[index]; index++; return result; } var commandLineOptions = parseCommandLine(); var userDataPath = commandLineOptions.userDataPath; if (userDataPath) { app.setPath('userData', userDataPath); } function onCecCommand(cmd) { console.log("Command received: " + cmd); sendCommand(cmd); } /* CEC Module */ function initCec() { try { const cec = require('./cec/cec'); var cecExePath = commandLineOptions.cecExePath; // create the cec event const EventEmitter = require("events").EventEmitter; var cecEmitter = new EventEmitter(); var cecOpts = { cecExePath: cecExePath, cecEmitter: cecEmitter }; cecProcess = cec.init(cecOpts); cecEmitter.on("receive-cmd", onCecCommand); } catch (err) { console.log('error initializing cec: ' + err); } } function getWindowId(win) { var Long = require("long"); var os = require("os"); var handle = win.getNativeWindowHandle(); if (os.endianness() == "LE") { if (handle.length == 4) { handle.swap32(); } else if (handle.length == 8) { handle.swap64(); } else { console.log("Unknown Native Window Handle Format."); } } var longVal = Long.fromString(handle.toString('hex'), unsigned = true, radix = 16); return longVal.toString(); } function initPlaybackHandler(mpvPath) { var playbackhandler = require('./playbackhandler/playbackhandler'); playbackhandler.initialize(getWindowId(playerWindow), mpvPath); playbackhandler.registerMediaPlayerProtocol(electron.protocol, mainWindow); } setCommandLineSwitches(); var fullscreenOnShow = false; var windowShowCount = 0; function onWindowShow() { windowShowCount++; if (windowShowCount == 2) { mainWindow.setFullScreen(true); if (!fullscreenOnShow) { // hack alert. in electron 1.4 under windows, the app starts up black. changing window state seems to resolve it. mainWindow.setFullScreen(false); } fullscreenOnShow = false; mainWindow.center(); mainWindow.focus(); initialShowEventsComplete = true; } } app.on('quit', function () { closeWindow(mainWindow); }); function onPlayerWindowRestore() { mainWindow.focus(); } // This method will be called when Electron has finished // initialization and is ready to create browser windows. app.on('ready', function () { var isWindows = require('is-windows'); var windowStatePath = getWindowStateDataPath(); var previousWindowInfo; try { previousWindowInfo = JSON.parse(require("fs").readFileSync(windowStatePath, 'utf8')); } catch (e) { previousWindowInfo = {}; } var windowOptions = { transparent: false, //supportsTransparency, frame: false, resizable: false, title: 'Emby Theater', minWidth: 720, minHeight: 480, //alwaysOnTop: true, skipTaskbar: isWindows() ? false : true, //show: false, backgroundColor: '#00000000', center: true, show: false, webPreferences: { webSecurity: false, webgl: false, nodeIntegration: false, plugins: false, webaudio: true, java: false, allowDisplayingInsecureContent: true, allowRunningInsecureContent: true, experimentalFeatures: false, devTools: enableDevTools }, icon: __dirname + '/icon.ico' }; windowOptions.width = previousWindowInfo.width || 1280; windowOptions.height = previousWindowInfo.height || 720; if (previousWindowInfo.x != null && previousWindowInfo.y != null) { windowOptions.x = previousWindowInfo.x; windowOptions.y = previousWindowInfo.y; } playerWindow = new BrowserWindow(windowOptions); windowOptions.backgroundColor = '#00000000'; windowOptions.parent = playerWindow; windowOptions.transparent = true; windowOptions.resizable = true; windowOptions.skipTaskbar = false; // Create the browser window. loadStartInfo().then(function () { mainWindow = new BrowserWindow(windowOptions); if (enableDevToolsOnStartup) { mainWindow.openDevTools(); } mainWindow.webContents.on('dom-ready', setStartInfo); var url = getAppUrl(); windowStateOnLoad = previousWindowInfo.state; addPathIntercepts(); registerAppHost(); registerFileSystem(); registerServerdiscovery(); registerWakeOnLan(); // and load the index.html of the app. mainWindow.loadURL(url); mainWindow.setMenu(null); mainWindow.on('move', onWindowMoved); mainWindow.on('app-command', onAppCommand); mainWindow.on("close", onWindowClose); mainWindow.on("minimize", onMinimize); mainWindow.on("maximize", onMaximize); mainWindow.on("enter-full-screen", onEnterFullscreen); mainWindow.on("leave-full-screen", onLeaveFullscreen); mainWindow.on("restore", onRestore); mainWindow.on("unmaximize", onUnMaximize); mainWindow.on("resize", onWindowResize); playerWindow.on("restore", onPlayerWindowRestore); playerWindow.on("enter-full-screen", onPlayerWindowRestore); playerWindow.on("maximize", onPlayerWindowRestore); playerWindow.on("focus", onPlayerWindowRestore); playerWindow.on("show", onWindowShow); mainWindow.on("show", onWindowShow); // Only the main window should be set to full screen. // This is done after the window is shown because the // player window otherwise is shown behind the task bar. if (previousWindowInfo.state == 'Fullscreen') { fullscreenOnShow = true; } playerWindow.show(); mainWindow.show(); initCec(); initPlaybackHandler(commandLineOptions.mpvPath); var isRpi = require('detect-rpi'); if(isRpi()){ mainWindow.setFullScreen(true); mainWindow.setAlwaysOnTop(true); } }); }); })(); Edited November 4, 2018 by EODCrafter 1
ellnic 26 Posted November 4, 2018 Posted November 4, 2018 I haven’t tried using VLC yet. Will have to give it a go. I think it might be especially pertinent to use VLC in the Android TV version as I am having issues with Exo player. Sent from my iPhone using Tapatalk
EODCrafter 181 Posted November 4, 2018 Posted November 4, 2018 I've discovered 1 command line switch for VLC {--sub-track=0} turns on closed captioning. Let me know if you discover other nice switches. 1
ellnic 26 Posted November 4, 2018 Posted November 4, 2018 Will do, thanks for the pointer. :-) Sent from my iPhone using Tapatalk 1
negas 1 Posted November 11, 2018 Posted November 11, 2018 it's not unique. I'm suffering the same. Well I finally found a fix to my Unique issue...I switched Desktop from Ubuntu to Unity and ET for Linux works Perfect.... Whoops...Spoke too soon..... Unless you can't tell...This is the Emby Theater Interface actually blocking the video playing in the background and there is no way to move it out of the way......
negas 1 Posted November 11, 2018 Posted November 11, 2018 I can not use on fullscreen on ubuntu 18 with gnome... DO I have to change to unity?
ellnic 26 Posted November 11, 2018 Posted November 11, 2018 It’s not specific to a desktop environment or window manager. It’s something to do with GTK. Unity is a warthog. You definitely don’t have to move to it. Sent from my iPhone using Tapatalk 1
Luke 42240 Posted November 19, 2018 Posted November 19, 2018 Slightly unrelated, but Emby Server for Arm64 is now available ! https://emby.media/community/index.php?/topic/65476-emby-server-for-arm64-now-available/ Thanks. 1
ellnic 26 Posted November 19, 2018 Posted November 19, 2018 This is awesome Luke. Well done. [emoji3531] Sent from my iPhone using Tapatalk
BurntTech 6 Posted November 20, 2018 Posted November 20, 2018 Small bug for Ubuntu 18.04 when you minimize you can't bring it back up while it continues to play. I think its gnome from the details and not unity.
EODCrafter 181 Posted November 21, 2018 Posted November 21, 2018 Small bug for Ubuntu 18.04 when you minimize you can't bring it back up while it continues to play. I think its gnome from the details and not unity. Does it on Gnome Flashback, Unity and Ubuntu, 18.04.
widget100 8 Posted November 21, 2018 Posted November 21, 2018 I just want to say... You guys %^&*ing rock!!!!! I've been using Emby since giving up on Plex in August, had problems with stability on the PI, but Luke has been so responsive to my other posts. In the past few beta releases Emby server on the PI has become indistructable as far as crash/hang events go, and the DLNA issues/log flooding are a thing of the past. Also added the TVH plugin back and it's rock solid. I've added an SSD to the PI to take some of the workload off the SD card and I think that might have helped in some way, but how the heck Emby manages to transcode .TS files from TVHeadend live on a PI at 30FPS baffles me. I have 2 £6 DVB-T tuners and Emby on the PI, can record 2 channels and stream from Emby simultaneously and it works perfectly. Anyway.. back to topic - Just threw the 3.0.4 Pi image on my spare Pi 3B, added an old MCE IR receiver with MCE remote that was kicking around and in 5 mins I have Theater with full remote control (one tiny button mapping issue but who cares). It's flawless... did I mention you guys rock!!! P.S... Any chance you can make Theater work on the Pi Zero W? I know that's a big ask because of electron etc
kincaidj001 0 Posted November 22, 2018 Posted November 22, 2018 (edited) For someone who is relatively new with emby but has a newish running emby server on windows as well as raspberry pi's running Home Assistant and Pi Hole, can the distro for raspberry pi 3+ just stream to one tv via hdmi? I'm looking for ways to use emby for my motorhome to stream to two samsung 4k tv's and a couple of Ipads. Or, would I be better off buying an android box or Intel Nuc? Currently, I have a HDHomeRun Quatro for local channels and Premium TV from Silicon Dust.I just realized this is for Emby Theater which I haven't even looked at yet. Is plain old Emby Server an option? Edited November 22, 2018 by kincaidj001
widget100 8 Posted November 25, 2018 Posted November 25, 2018 For someone who is relatively new with emby but has a newish running emby server on windows as well as raspberry pi's running Home Assistant and Pi Hole, can the distro for raspberry pi 3+ just stream to one tv via hdmi? I'm looking for ways to use emby for my motorhome to stream to two samsung 4k tv's and a couple of Ipads. Or, would I be better off buying an android box or Intel Nuc? Currently, I have a HDHomeRun Quatro for local channels and Premium TV from Silicon Dust.I just realized this is for Emby Theater which I haven't even looked at yet. Is plain old Emby Server an option? I'm not sure whether you realise (it's not clear in your post) but Emby is a server and client system. So when you're running the Emby Server part under Windows, you need one of the many clients. You can use any of the Theater clients if you subscribe to Emby Premiere, and apart from those there are Android and Apple and other clients (including just the Web client that is built into Emby server. You dont say if your Windows server will be at home and you'll stream from it on the road, or you'll take it with in your motorhome, but it doesn't matter too much. You can use the Emby Web client or the Apple one on the Ipads to talk back to the server. As far as the TV is concerned, you can use any client to push to it via DLNA, Chromecast, an HDMI cable connected to the tablets. Or you can even download the Emby app from Samsung app store and connect directly back to your Windows server. Tons of options, it's so flexible.
morpheus1 2 Posted December 11, 2018 Posted December 11, 2018 (edited) I'm not sure whether you realise (it's not clear in your post) but Emby is a server and client system. So when you're running the Emby Server part under Windows, you need one of the many clients. You can use any of the Theater clients if you subscribe to Emby Premiere, and apart from those there are Android and Apple and other clients (including just the Web client that is built into Emby server. You dont say if your Windows server will be at home and you'll stream from it on the road, or you'll take it with in your motorhome, but it doesn't matter too much. You can use the Emby Web client or the Apple one on the Ipads to talk back to the server. As far as the TV is concerned, you can use any client to push to it via DLNA, Chromecast, an HDMI cable connected to the tablets. Or you can even download the Emby app from Samsung app store and connect directly back to your Windows server. Tons of options, it's so flexible. This last statement is only true, if you're connected to the Internet. This needs to be made clear. Except, of course, if this has changed. But as far as I know, you cannot use the Samsung app on a local network. It only works if you're connected to the internet, including after connecting to the internet to download and install it, which you'd need to do. If you then disconnect from the internet and want to use it on your local network, it won't work. Edited December 11, 2018 by morpheus1
