Luke 42239 Posted September 18, 2018 Posted September 18, 2018 Haven't tested external players. I would try it and report your experience.
sectune 9 Posted September 19, 2018 Posted September 19, 2018 Dear Luke, do you mind posting the build instructions for other *nix systems in the github/readme or pointing me in the right direction? I am running on arch linux and would love to try out the electron emby client. Thanks! 1
denz 501 Posted September 19, 2018 Posted September 19, 2018 (edited) Have a look at post #68 page 4 of this thread and try those instructions it should be the same. Edited September 19, 2018 by denz 1
Luke 42239 Posted September 19, 2018 Posted September 19, 2018 At some point we'll look at getting a package together for other distros. Thanks. 1
marcelhehle 1 Posted September 20, 2018 Posted September 20, 2018 A package for Fedora would be great! That would be a dream come true ...
bric 34 Posted September 24, 2018 Posted September 24, 2018 Using Ubuntu 18.04. I had version 2.9.6 installed (which started up using "electron main.js"). I just installed the deb package for 3.0.3 and it is not going fullscreen like the earlier version would. Is there some sort of configuration inside or outside emby-theatre that I could play with to get full screen working? more details: I unsuccessfully tried the little square maximize button on the main window and the 'fullscreen' icon in the playback window. If I set the side dock to autohide, then the fullscreen icon in playback *did* expand the window to cover the place where the dock was, but not the "status bar" at the top of the ubuntu window. So full screen sort of worked but it wasn't 'on top'... though it does stay 'on top' of all other open windows (if any).
Luke 42239 Posted September 24, 2018 Posted September 24, 2018 That may require some new development. We'll have to look at that. We'll also be updating to the recently released electron 3.0 soon. That may impact the full screen features. Thanks.
Luke 42239 Posted September 26, 2018 Posted September 26, 2018 Iv'e posted .debs for 3.0.4. Thanks guys. 1
bric 34 Posted September 26, 2018 Posted September 26, 2018 Iv'e posted .debs for 3.0.4. Thanks guys. The link is still for the deb for 3.0.3 (though the text reads 3.0.4)
Luke 42239 Posted September 26, 2018 Posted September 26, 2018 My mistake, sorry. I've corrected them. Thanks for pointing it out.
daldana 126 Posted September 28, 2018 Posted September 28, 2018 I've installed this version on a Pi and it worked fine, no more spinning circle and no having to install separate libs, with the instructions provided. One thing I found interesting was that the dist-upgrade command doesn't find anything to upgrade now. So I'm going to start over with a clean install of Raspbian and try installing without the rpi-update and dist-upgrade commands and see what happens. Maybe this version doesn't require the extra steps...
Luke 42239 Posted September 29, 2018 Posted September 29, 2018 Even if it doesn't, i think we will leave it as part of the steps anyway as it's a good thing to do. Thanks for the feedback !
daldana 126 Posted October 1, 2018 Posted October 1, 2018 FYI, it still needed both commands to work properly.
ellnic 26 Posted October 6, 2018 Posted October 6, 2018 This may have already been answered but: does the Pi image in the first post work on the 512MB Model B? Apologies if this has already been answered, I’ve not been as active as I would like of late. Sent from my iPhone using Tapatalk
Luke 42239 Posted October 6, 2018 Posted October 6, 2018 I am not entirely positive but please try it. We have been testing on RPI3.
ellnic 26 Posted October 6, 2018 Posted October 6, 2018 Will do. Will report back later. :-) Sent from my iPhone using Tapatalk
filewalker 0 Posted October 6, 2018 Posted October 6, 2018 Tested an RPI3, working very good out of the box. First had some troubles with Networking, but seems to be a bad sd card, flashing the image to another one does the trick. Now everything ist working. First option i set was Hardware acceleration from NONE to Auto. Works much better. With NONE, all cores at 100% load an some times a bit laggy. With set to AUTO, all cores around 15% no glitches. I like the app und the theme very well, but the overall performance is a bit laggy. Searching around in the Database for example. When i close Emby Theater and use the raspbian Desktop, evrything works like a charm and is very fast responding. Starting videos takes also a bit longer than on my firetv with emby or kodi. And i do not think it has much more power. Are there any Settings i have to adjust? Thanks!
Luke 42239 Posted October 6, 2018 Posted October 6, 2018 Thanks for the feedback. We'll make auto the default for hardware support. The app will perform better following the next release of emby server.
filewalker 0 Posted October 6, 2018 Posted October 6, 2018 okay, sounds interesting. i thought it has something to do with the app/implementation and the performance of the pi. i am excited to the new release - could you give a little explanation or is this to complicated
Luke 42239 Posted October 6, 2018 Posted October 6, 2018 https://emby.media/community/index.php?/topic/61079-3603-db-changes/
filewalker 0 Posted October 7, 2018 Posted October 7, 2018 Thank you @@Luke! This sound promising. But i think this will only have to do with every querry from the app to the server - the emby theater itself is a bit laggy an mir RPi3 eg browsing throu settings, etc
ellnic 26 Posted October 8, 2018 Posted October 8, 2018 It’s a no go on the 512MB model B. Image doesn’t boot at all. It will boot on a Pi 2, but the performance isn’t great, even when overclocked. It’s ok in the menus but video is choppy with no audio. Got a couple of 3+’s on the way :-) Sent from my iPhone using Tapatalk
benze 1 Posted October 9, 2018 Posted October 9, 2018 I've tried reading through this 23 page thread, but am having trouble seeing if anyone has an official way to get Emby streaming on a Fedora box. For that matter, I would like to get it streaming on my PC, and am willing to move Ubuntu if required, although with Fedora my remote worked out of the box, and Ubuntu seemed like it would take a lot more efforts to get that working. Is there anything I can use to get Emby working in Fedora? I haven't found any package for Emby Theatre for Fedora (or CentOS). Should I start looking into getting Kodi running only to add the Emby plugin? At the end of the day, I'm trying to repurpose an old PC as an Emby client to stream to my TV. What is the easiest way to get this work? I don't need a full Linux disto; just something that can boot straight into Emby Theatre even. Is there a LiveCD of EmbyTheatre? Thanks, Eric
