ngc1975 0 Posted July 26, 2018 Posted July 26, 2018 So basically you're saying you need to force it to always be full screen? Yes, because the maximize button has no effect.
daldana 126 Posted August 1, 2018 Posted August 1, 2018 I was having a problem on my RPI with very low volume from either the HDMI or analog outputs and tried everything to get it louder. I initially thought the problem was with the OS use of alsamixer so I tried installing pulseaudio, but that didn't work no matter how many settings I changed, so I dumped it and went back to alsamixer. Tried all kinds of tweaks in there and still couldn't get it work. Then I tried the Emby web client and found that the audio was just fine, so the problem was in the mpv player settings. Long story, short, I added a line in the mpv.conf file that immediately fixed the problem on both outputs. The line is; --af=lavfi=[acompressor=6] You can play with the value (I've tried it at 12 and it increased even more), but I don't know where it will start distorting. Good luck!
Luke 42241 Posted August 1, 2018 Posted August 1, 2018 Interesting, thanks for the info. We'll have to get something for that into the settings UI. 1
ebike 13 Posted August 1, 2018 Posted August 1, 2018 (edited) Hi, @@ellnic I Agree a light-weight window manager like i3 is the way to go, though I prefer awesome, it is much more configurable .... (i.e you won't have any issues with bringing ET up full screen) @@Luke Is there any plans to put this build into a container, like FlatPak? Seems it would be much easier to get across to a lot of platforms that way .. I would suggest a minimal Archlinux build with Xorg/Awesome window manager, electron and the bare minimum dependencies to have it work .. My 2c. Edited August 1, 2018 by ebike 1
ellnic 26 Posted August 1, 2018 Posted August 1, 2018 (edited) That was the first time I’d ever used i3. I’m normally in favour of more pleasing GUIs.. Will check out awesome though as more configurability is always good [emoji106] I only chose i3 because it was pretty far up the list on the well known WM/DE memory use bar chart that’s been floating around for yonks (and wasn’t completely sucky). Obviously, that chart is years old so much may have changed. Sent from my iPhone using Tapatalk Edited August 1, 2018 by ellnic
Luke 42241 Posted August 2, 2018 Posted August 2, 2018 We are currently working on Pi packaging first, then we'll probably look at others. And yes, something that we could deploy universally would be very nice so that we don't have to go and build so many individually like we do with the server. 1
Luke 42241 Posted August 4, 2018 Posted August 4, 2018 We've pushed some improvements for Raspberry Pi, specific to opening the video OSD. please try it out. Thanks ! 1
daldana 126 Posted August 7, 2018 Posted August 7, 2018 Hi, I did an "git pull" to perform an update, restarted Pi, and tried Emby, but I don't see any changes in the OSD (other than the Blue Radiance backdrop). What was the update supposed to do? Thank you.
Luke 42241 Posted August 8, 2018 Posted August 8, 2018 Ok guys, we finally have a one-click install for this. I'll post the builds here in the community during early testing stages. Please see the instructions in the first post. The video player is mpv with support for hardware acceleration and de-interlacing. Enjoy ! 2
haraldov 10 Posted August 8, 2018 Posted August 8, 2018 The video player is mpv with support for hardware acceleration and de-interlacing. Enjoy ! I have installed the deb package in post 1 but I do not find the mpv binary file included in the deb package. Should it be? pi@raspberrypi:~/Downloads $ whereis mpv mpv: The deb package complain about some missing packages. pi@raspberrypi:~/Downloads $ sudo dpkg -i emby-theater_3.0.1_armhf.deb Selecting previously unselected package emby-theater. (Leser database ... 115937 filer og kataloger er for øyeblikket installerte.) Preparing to unpack emby-theater_3.0.1_armhf.deb ... Unpacking emby-theater (3.0.1-1) ... dpkg: dependency problems prevent configuration of emby-theater: emby-theater krever libgconf2-4. Men: Pakken libgconf2-4 er ikke installert. emby-theater krever liblua5.2-0. Men: Pakken liblua5.2-0 er ikke installert. emby-theater krever libsdl2-2.0-0. Men: Pakken libsdl2-2.0-0 er ikke installert. dpkg: error processing package emby-theater (--install): kravproblem - setter ikke opp pakken Processing triggers for gnome-menus (3.13.3-9) ... Processing triggers for desktop-file-utils (0.23-1) ... Processing triggers for mime-support (3.60) ... Det oppsto feil ved behandling av: emby-theater pi@raspberrypi:~/Downloads $ You can install these packages like this: i@raspberrypi:~/Downloads $ sudo apt --fix-broken install
ellnic 26 Posted August 8, 2018 Posted August 8, 2018 What models are supported? I get Illegal Instruction when executing. Sent from my iPhone using Tapatalk
ellnic 26 Posted August 8, 2018 Posted August 8, 2018 Ok, I don’t get the error on a Pi2. So I think that’s probably the minimum requirement. Very easy to get up and running now. Nice :-D Sent from my iPhone using Tapatalk
haraldov 10 Posted August 8, 2018 Posted August 8, 2018 (edited) I want to share how to compile mpv master from git running on rpi3 with the last (June 18) Raspbian Stretch. # On recent Raspbian Stretch, you have to run RPi-update # to obtain /opt/vc/lib/pkgconfig Source: https://github.com/mpv-player/mpv-build/issues/84 sudo apt install rpi-update && sudo rpi-update && sudo reboot # Add PKG_CONFIG_PATH and LIBRARY_PATH before running mpv-build # Source: https://github.com/mpv-player/mpv-build/issues/84, https://github.com/mpv-player/mpv-build/issues/83 # and https://github.com/mpv-player/mpv-build/issues/98 export PKG_CONFIG_PATH=/opt/vc/lib/pkgconfig export LIBRARY_PATH=/opt/vc/lib export LDFLAGS=-L/opt/vc/lib export CPATH=/opt/vc/include # Prepare Ubuntu build packages Source: https://help.ubuntu.com/community/CompilingEasyHowTo sudo apt-get install build-essential sudo apt-get install cvs subversion git-core mercurial # Use mpv-build helper scripts to compile mpv on Raspbian. Source: https://github.com/mpv-player/mpv-build sudo apt-get install git devscripts equivs git clone https://github.com/mpv-player/mpv-build.git cd mpv-build echo --enable-mmal >> ffmpeg_options ./use-mpv-master ./update rm -f mpv-build-deps_*_*.deb mk-build-deps -s sudo -i dpkg-buildpackage -uc -us -b -j4 # Install deb package: sudo dpkg -i ../mpv_<version>_<architecture>.deb sudo dpkg -i ../mpv_2018.08.05.cfecbac863_armhf.deb # Mpv need 256 Mb on rpi2 and 3 echo "gpu_mem=256" >> /boot/config.txt Check available video outputs where you need the gpu video option pi@raspberrypi:~ $ mpv --vo=help Available video outputs: libmpv render API for libmpv rpi Raspberry Pi (MMAL) gpu Shader-based GPU Renderer vdpau VDPAU with X11 xv X11/Xv vaapi VA API with X11 x11 X11 (slow, old crap) null Null video output image Write video frames to image files tct true-color terminals caca libcaca drm Direct Rendering Manager With the master mpv version in ET choose under setting-->hardware accellaration Auto instead of Rpi option. #Source: https://mpv.io/manual/master/#video-output-drivers The RPI option is deprecated. Use --vo=gpu instead, which is the default and provides the same functionality. The rpi VO will be removed in mpv 0.23.0. Edited August 8, 2018 by haraldov 1
haraldov 10 Posted August 8, 2018 Posted August 8, 2018 (edited) I have installed the deb package in post 1 but I do not find the mpv binary file included in the deb package. Should it be? @@Luke, sorry if I have misunderstood something here. I needed to install mpv after I have installed the ET deb package. In the orginal post #68 (page 4) I made an howto compile mpv, which I updated for the master mpv and posted above. Have the Emby developers made a mpv deb package for raspbian we can use? With the master mpv version in ET choose under setting-->hardware accellaration Auto instead of Rpi option. When I choose the RPI option in ET recorded ts videos play choppy. When I choose Auto the video plays fine because I think mpv choose the gpu video option. I am going to check this more. Edited August 8, 2018 by haraldov
haraldov 10 Posted August 8, 2018 Posted August 8, 2018 (edited) With the master mpv version in ET choose under setting-->hardware accellaration Auto instead of Rpi option. When I play the recorded video with the RPI option setting in ET streamed from the Emby server the video plays slow and the video and sound is not in sync. When I play it with the Auto option setting in ET the video plays perfect. Is RPI and Auto the same option? If so you can forget the post above. When I play the same video from local disk everythink i fine with the mpv video option rpi. pi@raspberrypi:~/Videos/Michael Mosley - blodets magiske egenskaper $ mpv --vo=rpi "Michael Mosley - blodets magiske egenskaper 2018_08_05_12_45_00.ts" Playing: Michael Mosley - blodets magiske egenskaper 2018_08_05_12_45_00.ts [ffmpeg/demuxer] mpegts: PES packet size mismatch [ffmpeg/video] h264: SPS unavailable in decode_picture_timing [ffmpeg/video] h264: non-existing PPS 0 referenced [ffmpeg/video] h264: SPS unavailable in decode_picture_timing [ffmpeg/video] h264: non-existing PPS 0 referenced [ffmpeg/video] h264: decode_slice_header error [ffmpeg/video] h264: no frame! [ffmpeg/video] h264: SPS unavailable in decode_picture_timing [ffmpeg/video] h264: non-existing PPS 0 referenced [ffmpeg/video] h264: SPS unavailable in decode_picture_timing [ffmpeg/video] h264: non-existing PPS 0 referenced [ffmpeg/video] h264: decode_slice_header error [ffmpeg/video] h264: no frame! [ffmpeg/video] h264: SPS unavailable in decode_picture_timing [ffmpeg/video] h264: non-existing PPS 0 referenced [ffmpeg/video] h264: SPS unavailable in decode_picture_timing [ffmpeg/video] h264: non-existing PPS 0 referenced [ffmpeg/video] h264: decode_slice_header error [ffmpeg/video] h264: no frame! [ffmpeg/demuxer] mpegts: start time for stream 4 is not set in estimate_timings_from_pts [ffmpeg/demuxer] mpegts: start time for stream 5 is not set in estimate_timings_from_pts [ffmpeg/demuxer] mpegts: PES packet size mismatch [ffmpeg/demuxer] mpegts: PES packet size mismatch [ffmpeg/demuxer] mpegts: PES packet size mismatch (+) Video --vid=1 (h264 1280x720 50.000fps) (+) Audio --aid=1 --alang=nor (ac3 2ch 48000Hz) Audio --aid=2 --alang=nor (aac_latm 2ch 48000Hz) Subs --sid=1 --slang=nor (dvb_teletext) Subs --sid=2 --slang=nor (dvb_subtitle) Subs --sid=3 --slang=nor 'hearing impaired' (dvb_subtitle) Using hardware decoding (mmal). AO: [alsa] 48000Hz stereo 2ch float VO: [rpi] 1280x720 mmal AV: 00:00:12 / 01:04:59 (0%) A-V: 0.000 [input] No key binding found for key '0x16'. AV: 00:00:13 / 01:04:59 (0%) A-V: 0.000 Exiting... (Quit) ^C When I play the video with the mpv video option gpu I do not get any video only sound. pi@raspberrypi:~/Videos/Michael Mosley - blodets magiske egenskaper $ mpv --vo=gpu "Michael Mosley - blodets magiske egenskaper 2018_08_05_12_45_00.ts" Playing: Michael Mosley - blodets magiske egenskaper 2018_08_05_12_45_00.ts [ffmpeg/demuxer] mpegts: PES packet size mismatch [ffmpeg/video] h264: SPS unavailable in decode_picture_timing [ffmpeg/video] h264: non-existing PPS 0 referenced [ffmpeg/video] h264: SPS unavailable in decode_picture_timing [ffmpeg/video] h264: non-existing PPS 0 referenced [ffmpeg/video] h264: decode_slice_header error [ffmpeg/video] h264: no frame! [ffmpeg/video] h264: SPS unavailable in decode_picture_timing [ffmpeg/video] h264: non-existing PPS 0 referenced [ffmpeg/video] h264: SPS unavailable in decode_picture_timing [ffmpeg/video] h264: non-existing PPS 0 referenced [ffmpeg/video] h264: decode_slice_header error [ffmpeg/video] h264: no frame! [ffmpeg/video] h264: SPS unavailable in decode_picture_timing [ffmpeg/video] h264: non-existing PPS 0 referenced [ffmpeg/video] h264: SPS unavailable in decode_picture_timing [ffmpeg/video] h264: non-existing PPS 0 referenced [ffmpeg/video] h264: decode_slice_header error [ffmpeg/video] h264: no frame! [ffmpeg/demuxer] mpegts: start time for stream 4 is not set in estimate_timings_from_pts [ffmpeg/demuxer] mpegts: start time for stream 5 is not set in estimate_timings_from_pts [ffmpeg/demuxer] mpegts: PES packet size mismatch [ffmpeg/demuxer] mpegts: PES packet size mismatch [ffmpeg/demuxer] mpegts: PES packet size mismatch (+) Video --vid=1 (h264 1280x720 50.000fps) (+) Audio --aid=1 --alang=nor (ac3 2ch 48000Hz) Audio --aid=2 --alang=nor (aac_latm 2ch 48000Hz) Subs --sid=1 --slang=nor (dvb_teletext) Subs --sid=2 --slang=nor (dvb_subtitle) Subs --sid=3 --slang=nor 'hearing impaired' (dvb_subtitle) Using hardware decoding (mmal). AO: [alsa] 48000Hz stereo 2ch float VO: [gpu] 1280x720 mmal [vo/gpu] Using HW-overlay mode. No GL filtering is performed on the video! AV: 00:00:11 / 01:04:59 (0%) A-V: -0.000 Exiting... (Quit) Edited August 8, 2018 by haraldov
Luke 42241 Posted August 9, 2018 Posted August 9, 2018 @@haraldov i think the issue is you didn't follow the instructions in the first post. dpkg -i" does not install dependencies. "sudo apt install *.deb" does install dependencies. this is what you should have done, and what the instructions tell you to do. Is this correct?
Luke 42241 Posted August 9, 2018 Posted August 9, 2018 The first post has been updated. We now have an X64 version! Have fun. 1
Luke 42241 Posted August 9, 2018 Posted August 9, 2018 FYI to those testing, I just updated both the ARM and X64 .debs. They are just packaging updates. Thanks.
ebike 13 Posted August 9, 2018 Posted August 9, 2018 (edited) Thanks Luke .. great job. I tried installing on Archlinux with debtap from AUR. All was good apart from video playing, just a blank screen, but sound ok ... everything else looked great. Any chance of an Arch package? Edited August 9, 2018 by ebike 1
Luke 42241 Posted August 9, 2018 Posted August 9, 2018 I'd love to do lots of packages just like we have with the server. Hopefully we will get there. 1
ebike 13 Posted August 9, 2018 Posted August 9, 2018 I'd love to do lots of packages just like we have with the server. Hopefully we will get there. Any idea's with the blank screen for video?
Luke 42241 Posted August 9, 2018 Posted August 9, 2018 Since we haven't tested on Archlinux i'm really not sure at this point, sorry.
haraldov 10 Posted August 9, 2018 Posted August 9, 2018 "sudo apt install *.deb" does install dependencies. this is what you should have done, and what the instructions tell you to do. Post 363. @@Luke, this is confirmed and is correct.
