denz 501 Posted September 9, 2017 Posted September 9, 2017 (edited) Even though I have deinterlace to Yes it is not deinterlacing properly. The mpvhdchannel log the video is not deinterlaced I made a one minute recording played the recording it is deinterlaced. mpvhdchannel.txt mpvhdrecording.txt Edited September 9, 2017 by denz
haraldov 10 Posted September 12, 2017 Posted September 12, 2017 My Emby server 3.2.30.0 on Ubuntu is transcoding the tvheadend livetv stream when I play the stream on ET 2.8.3. The transcoding is happing because the livetv stream has embedded dvbsub streams. This issue have started happing the last month. Initializing cec-client... { cecExePath: undefined, cecEmitter: EventEmitter { domain: null, _events: {}, _eventsCount: 0, _maxListeners: undefined } } ERROR: cec-client not installed, running without cec functionality. UDP Client listening on 0.0.0.0:47179 starting udp receive timer with timeout ms: 1000 Message from: 192.168.9.2:7359 ServerDiscovery message received Server discovery json: {"Address":"http://192.168.9.2:8096","Id":"17d8efa68ef342d48968e8eac77eb805","Name":"vdrsrv"} timer expired 1 servers received [ { Address: 'http://192.168.9.2:8096', Id: '17d8efa68ef342d48968e8eac77eb805', Name: 'vdrsrv', EndpointAddress: '192.168.9.2' } ] Play URL : http://192.168.9.2:8096/emby/videos/a8ceaad694c6e44e00f3e11a4c52fc78/master.m3u8?DeviceId=raspberrypi&MediaSourceId=d1d7f8fe03d542a4944d3b3beeb0780c_5223b1cdba30ad643aaa8fd1b0756195&VideoCodec=h264,mpeg2video&AudioCodec=ac3,mp3,aac&AudioStreamIndex=-1&VideoBitrate=139808000&AudioBitrate=192000&PlaySessionId=0b253181fdcc42dbaa2eba5ab488c8ad&api_key=8c3ac6b59c37471ea96843b5ba7fd1aa&LiveStreamId=a17c75760a04e99b68cf766e11316e1c_09efa0d56b934a82adec00a87b837fb0_d1d7f8fe03d542a4944d3b3beeb0780c_5223b1cdba30ad643aaa8fd1b0756195&CopyTimestamps=false&TranscodingMaxAudioChannels=6&EnableSubtitlesInManifest=false&RequireAvc=false&RequireNonAnamorphic=false&DeInterlace=false&SegmentContainer=mkv&SegmentLength=3&MinSegments=1&BreakOnNonKeyFrames=False&TranscodeReasons=UnknownVideoStreamInfo Error closing window. It may have already been closed. Error: Object has been destroyed ffmpeg-transcode-b1ad519b-424d-4254-a11b-8214c591e82a.txt
haraldov 10 Posted September 12, 2017 Posted September 12, 2017 (edited) No transcoding is happening when I downgrad ET to 2.8.1. ET is using the correct direct tvheadend stream URL. pi@raspberrypi:~/emby-theater-electron $ git checkout ad32a324949b0158c09763c07a03f2fca6d76776 M et.sh Previous HEAD position was d07e160... 2.8.1 HEAD is now at ad32a32... support seeking live streams # Emby server play URL Play URL : http://192.168.9.2:9981/stream/channelid/1573635056?ticket=7E41D54862CBC64B7D6387C36FC35B881DD61732&profile=pass # Tvheadend server play URL #EXTINF:-1 tvg-id="f0c3cb5d851465c29886e26abafc3df9",NRK1 HD http://192.168.9.2:9981/stream/channelid/1573635056?ticket=78B3D6C1231DDDDF0E07A3D51F382EEA0B342D4D&profile=pass When I downgrad to ET above 2.8.1 Emby server is transcoding the stream, but ET is not using direct URL stream. Play URL : http://192.168.9.2:8096/emby/videos/a8ceaad694c6e44e00f3e11a4c52fc78/master.m3u8 TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported et-ver-ad32ad32.log et-2.8.1.log Edited September 12, 2017 by haraldov
denz 501 Posted September 14, 2017 Posted September 14, 2017 I have compiled 0.27 but it is using software renderer when I use --hwdec=rpi it mentions requested hardware decoder not compiled I started following haraldov instructions from ./update as I have compiled 26 before and that one worked in ffmpeg options it has --enable-mmal. Do you have to delete mpv-build folder and start from step one.
haraldov 10 Posted September 14, 2017 Posted September 14, 2017 @@denz, the mpv developers have currently rewritten the OpenGL renderer, but the RPI code has not been updated https://github.com/mpv-player/mpv-build/issues/89. This has been now fixed in mpv git I think because I have no problem to use mpv with --hwdec=rpi with mpv 0.27.0-3-g2f41b834b3-dirty. For compiling mpv git you must follow these compiling steps https://gist.github.com/yangxuan8282/c5819e8c74848420739e45e19f66cce9 # You get this error when installing libgles2-mesa-dev. # This package is already installed in Raspbian Scratch so you do not need it pi@raspberrypi:/usr/local/src/mpv-build $ sudo apt-get install libgles2-mesa-dev Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: libgles2-mesa-dev : Depends: libgles2-mesa (= 13.0.6-1) but 13.0.6-1+rpi2 is to be installed E: Unable to correct problems, you have held broken packages. pi@raspberrypi:/usr/local/src/mpv-build $ 1
denz 501 Posted September 16, 2017 Posted September 16, 2017 Tried it and no luck I get audio but no video. The only reason why I am trying the newest version as 26 is not deinterlacing video. Subs --sid=1 --slang=eng (dvb_teletext) AO: [alsa] 48000Hz stereo 2ch s16 Using hardware decoding (rpi). VO: [opengl] 720x576 => 1024x576 mmal [vo/opengl] Using HW-overlay mode. No GL filtering is performed on the video! AV: 23:55:42 / 00:00:00 A-V: -0.000 Cache: 1s+0KB
denz 501 Posted September 19, 2017 Posted September 19, 2017 I posted a bug report in MPV github.com and one person replied that deinterlacing is not supported on the pi.
Luke 42239 Posted September 19, 2017 Posted September 19, 2017 I posted a bug report in MPV github.com and one person replied that deinterlacing is not supported on the pi. There's always transcoding.
Luke 42239 Posted September 23, 2017 Posted September 23, 2017 Some new features headed up: - The image uploader dialog is now available. Now if you use the image editor you'll also be able to use the uploader and will no longer be greeted with a prompt that says "coming soon to Emby Theater." - An expanded set of general playback settings. Specifically, some new settings are available for your enjoyment: Quality settings are now broken out into three - home network video quality, internet streaming quality, and internet streaming quality for music - The "enable next video info" setting is now exposed in Emby Theater. Have fun.
darkassassin07 674 Posted September 29, 2017 Posted September 29, 2017 (edited) I decided to have a play with this too see if i could get my rpi3-b setup as an easily movable emby player. Took some screwing around but I managed to get all the requirements installed, then ran emby. This version (emby-theater-electron) the menus are smooth, navigation around the library is great, however when attempting to play video I get the error others have posted (spawn main.js ENOENT at exports._errnoException (util.js:1050:11)) I then tried the depreciated emby-theater-pi, Now navigation is pretty slow, menus are clunky, scrolling is like watching paint dry, but video playback is seamless. I don't notice any difference in video quality compared to anything else I stream on.(though im largely streaming ~720p 1080/60max) That is v/a quality alone though, the video players controls are just as clunky as the rest of the menus. Oddly it will not play a second video without being restarted. Watch something, then either let autoplay try to play the next one, or select something else yourself and its just loading forever. Raspbian 9 (Stretch) mpv -v (built from source using @@haraldov instructions pg4) ... [cplayer] mpv 0.23.0 © 2000-2016 mpv/MPlayer/mplayer2 projects [cplayer] built on UNKNOWN [cplayer] ffmpeg library versions: [cplayer] libavutil 55.34.101 [cplayer] libavcodec 57.64.101 [cplayer] libavformat 57.56.101 [cplayer] libswscale 4.2.100 [cplayer] libavfilter 6.65.100 [cplayer] libswresample 2.3.100 [cplayer] ffmpeg version: 3.2.5-1 ... electron -v v1.7.8 npm -v v5.3.0 node -v v8.6.0 Figured id post my results and see if anyone has any tips for getting video playback running with the electron version. Edited September 29, 2017 by darkassassin07
darkassassin07 674 Posted September 29, 2017 Posted September 29, 2017 (edited) After removing --disable-gpu from et.sh emby-theater-electron will now start the video player, then after loading longer than most of my other devices (including emby-theater-pi on the same device) begins playback. The sound begins to play and the player controls come up over the background image for whichever media it is. The video itself however either does not play at all, or is displayed behind the background image so is not visible. Edited September 29, 2017 by darkassassin07
Qballjos 0 Posted October 9, 2017 Posted October 9, 2017 for mpeg you need a license on the raspberry pi, if i'm not mistaking the video signal you recieve is mpeg2. http://www.raspberrypi.com/mpeg-2-license-key/
adrianwi 279 Posted October 23, 2017 Posted October 23, 2017 emby-theater-linux is obsolete now, fyi. make sure to refer to the first post for installation instructions, which includes installing mpv. The instructions on the first page still make reference to emby-theater-linux 1
Luke 42239 Posted October 23, 2017 Posted October 23, 2017 Instructions in the first post have been updated for launching the app. Instead of the et.sh script, it's electron main.js Thanks.
adrianwi 279 Posted October 23, 2017 Posted October 23, 2017 (edited) Instructions in the first post have been updated for launching the app. Instead of the et.sh script, it's electron main.js Thanks. It still says cd emby-theater-linux though in the 2nd to last line Edited October 23, 2017 by adrianwi 1
adam.niescierowicz 6 Posted October 27, 2017 Posted October 27, 2017 (edited) Installation works on debian Sid The only problems I noticed: npm from debian is to old, after apt-get install npm you need to update npm npm install -g npm for eletron you need to run command: /usr/local/bin/npm install -g electron --unsafe-perm=true --allow-root emby theater can't conntect to https server using self-signed certyficate using default port 8920 emby theater can't play TV using TVH backend Edited October 28, 2017 by adam.niescierowicz 1
Luke 42239 Posted October 28, 2017 Posted October 28, 2017 Installation works on debian Sid The only problems I noticed: emby theater can't conntect to https server using default port 8920 Hi, yes it can, but you need a trusted certificate.
Luke 42239 Posted October 30, 2017 Posted October 30, 2017 To @@denz and our other international friends, there's a new display setting that will allow you to have a separate datetime format setting from the display language. Enjoy.
DFergFLA 0 Posted November 2, 2017 Posted November 2, 2017 (edited) I really like Emby Server, even though I have only played with it for a few hours. But, I really need a this Linux app. I tried to do it myself but I can't get it to work. Any chance on a .deb or a snap or flatpack install anytime soon? Edited November 2, 2017 by DFergFLA
Luke 42239 Posted November 2, 2017 Posted November 2, 2017 Yes some kind of downloadable package is in our plans, thanks.
Guest Econaut Posted November 3, 2017 Posted November 3, 2017 (edited) I have 2 monitors on my system and Emby Theater renders in the middle of both (split between the two). It's immovable, and doesn't register in the window manager at all. (Ubuntu GNOME 17.10) Edited November 4, 2017 by Xen0sys
adam.niescierowicz 6 Posted November 4, 2017 Posted November 4, 2017 (edited) After run from kdm display manager ET run in full screen mode but left top corner is moved 200-300px to the center. Fix: I manualy edited file .config/Electron/windowstate.json and changed value of "x", "y" to 0. Before editing file remember to stop emby. Edited November 5, 2017 by adam.niescierowicz
