2 remote users transcoding is killing my system
This only started i would say a little over a month ago. I was on a stable build then, now on beta. Didn't have a problem with the 3 of us all using it at the same time. My memory usage at the time is fine but cpu usage is at almost 100%. I know transcoding takes cpu but like I said, it wan't a problem before. I have 6 cores. I am telling Docker to use only 5 of them.
I normally notice it on my pi2 first that direct plays. I start a video and have no audio. No matter what I do, I can't get audio. I switch to the ps4. It plays but stutters every few seconds. reboot that same problem. Switch to my Apple tv, and it sometimes plays sometimes doesn't.
I have some logs attached but its hard to get the right ones cause the Apple TV and ps4 logs are spitting out transcode logs every minutes. The pi2 doesnt produce on but you should find it in the server log. The pi2 started at 7:12.
The chrome log is from after I tried a reboot of the server, there wasn't a transcode log before that.
Oh , hardware acceleration turn off and transcoding thread count is set to 3
Archive.zip
Edited by mgworek
