FlsPrpht 0 Posted December 29, 2016 Author Posted December 29, 2016 No parental controls. I did check my media files and they play via Windows just fine.
FlsPrpht 0 Posted December 30, 2016 Author Posted December 30, 2016 Update: I moved my "The Dark Knight" folder up one level to "F:\Actions\The Dark Knight" and the system immediately found them. Very odd.
Happy2Play 9814 Posted December 30, 2016 Posted December 30, 2016 That is odd since there shouldn't have been a problem before.
FlsPrpht 0 Posted December 30, 2016 Author Posted December 30, 2016 Happy2Play: The mind boggles. I had a thought that the length of the path might be causing problems, but your screenshot shows that's not the case.Luke: it was in F:\Actions\Comic Books\The Dark Knight\ The other odd thing is there are other movies in subfolders under "Comic Books" which it still finds just fine. Thanks to everyone for their suggestions and trying to help.
CharleyVarrick 284 Posted December 30, 2016 Posted December 30, 2016 (edited) If I look back to post#3, F:\Actions\Comic Book\The Dark Knight Wonder what would happen if you'd now put it back down 1 level, maybe the scraper doesn't "like" the Comic Book folder (?) A very long time ago, I was using similar "complex" paths, but eventually moved to something more succinct, like: F:\The Dark Knight\The Dark Knight.mp4 Main reason: Multi-genres movies, ie: comedy-drama, if you choose to put it in drama, you might later look for it in vain in comedy... Emby and Kodi are very capable of tagging your movies per genres, even multi-ones. Edited December 30, 2016 by jlr19
FlsPrpht 0 Posted December 30, 2016 Author Posted December 30, 2016 Sorry, it is still "Comic Book" and not "Comic Books"
FlsPrpht 0 Posted December 30, 2016 Author Posted December 30, 2016 Thanks jlr19 I'll keep that in mind. I may reorganize my media collection like that at some point. I've already struggled in trying to categorize genres.
Happy2Play 9814 Posted December 30, 2016 Posted December 30, 2016 I've already struggled in trying to categorize genres. Emby already does it via metadata so structure really makes no difference.
FlsPrpht 0 Posted December 30, 2016 Author Posted December 30, 2016 Understood. I started my library before migrating to Emby. I've got some inertia going.
