Luke 42239 Posted February 17, 2017 Author Posted February 17, 2017 It will generally only pull down new updates once every 24 hours, so it may take a day or so.
wawilmsn 0 Posted February 17, 2017 Posted February 17, 2017 Much of the UI is hosted on our servers. The app runs the content locally on your system in an offline manner, but when you have an active internet connection, it will automatically pull in new changes. So there is nothing you need to do, other than occasionally restart the app. That is why the actual rpi installation is updated so infrequently, we will only have to do that when there is a change specific to raspberry pi. Thanks. Great to know. Since I had to load each element individually, I was concerned that manual updates would be required. Really great news, and working very well.
Crestj 68 Posted February 17, 2017 Posted February 17, 2017 Has anyone tried with on a Pi Zero? Not sure whether it is too underpowered to run this properly?
Luke 42239 Posted February 17, 2017 Author Posted February 17, 2017 is that even lower on the totem pole than Pi 2?
Crestj 68 Posted February 17, 2017 Posted February 17, 2017 Yes slightly below Pi2 on the scale. I guess that's not going to cut it?
Luke 42239 Posted February 17, 2017 Author Posted February 17, 2017 Try it and report your experience.
denz 501 Posted February 18, 2017 Posted February 18, 2017 The live tv screen for some reason doesnt refresh like in win theatre.
Luke 42239 Posted February 18, 2017 Author Posted February 18, 2017 What do you mean? as in the guide periodically? or something else?
denz 501 Posted February 18, 2017 Posted February 18, 2017 (edited) I can't remember about the guide but the live tv screen now playing is the same today as it was last night it is only when I go to another tab and go back the screen updates. I will leave the guide open and see is it the same. Edit: Guide did auto update Edited February 18, 2017 by denz
barat 27 Posted February 22, 2017 Posted February 22, 2017 (edited) Hi, on my Pi2 I installed clean raspbian, then compiled LibCEC from source (for 4.0.x) and made Emby Theater to autostart. Most things seems to work - ET starts, I can browse movies, play them ... even Emby Server (installed on Synology DS916+) shows that I direct play ... Problem is, that DTS/AC3 passthrough seems to not work. On previous setup (OSMC+Kodi17+Emby plugin) when I played DTS/AC3 movie my soundbar displayed DTS/PCM when movie was started. On Raspbian+ET no mather which movie is started - there is no info on my bar (though sound is played). I don't think that in this case soundbar is receiving unprocessed stream ... In log file there is "The Girl With The Dragon Tattoo" which on OSMC/KODI was making my soundbar to display DTS after movie start ... What's wrong with my setup? Less important thing - mouse cursor is not disappearing, but I think that after I setup everything I'll find some tutorials to hide/disable it. Same is screensaver - if Raspbian one is activated - I cannot "wakeup" with CEC TV remote (keyboard/mouse can do this without problem) Log Edited February 22, 2017 by barat
denz 501 Posted February 23, 2017 Posted February 23, 2017 There is an application called unclutter. I am not infront of pi but from memory I think it is called that.
barat 27 Posted February 23, 2017 Posted February 23, 2017 (edited) There is an application called unclutter. I am not infront of pi but from memory I think it is called that. Thanks for the tip with unclutter - no cursor anymore I managed to disable screenserver as well. About audio passthrough ... I had to make my hands dirty and just pushed "--passthrough" flag to args in playbackhandler/playbackhandler.js Need to remember when there will be an update. So far on my Pi2b overclocked to 1000/500/500 gpumem 256MB it works ok ... When I scroll video list I need to wait 1-2s for thumbnails, but it's not that bad. What is nice is that video starts faster then with kodi emby addon. Now I have two different problems: my subs are not displayed (external, because embedded in mkv works). ET sees it (are even picked/enabled). When I open same movie on windows chrome from tv.emby.media subtitles are displayed when I try to play movie with AAC sound, then it's distorted. I suppose that it's because it's passed through as well and my soundbar doesn't like it ? EDIT: About subtitles ... weird thing. When I play video, then subtitles are selected but are not displayed. Then I turn them Off, then again On, screen blinks for 1-2s and ... subtitles are displayed. After stopping the video and playing it again I have to redo this procedure to see subtitles again ... I would love to attach ET log from this, but after changing a line in my autostart logs are not created: Exec=/usr/local/bin/electron /home/pi/emby-theater-pi cec-client > /tmp/et.log EDIT2: I need to disable/enable even embedded subtitles (if default was selected). Next thing is that tv.emby.media on windows displays subtitles with proper font and respect subtitle position (I have Dragon Ball Super tv series which subtitle are placed in different parts of the screen - depends on situation) ... maybe this is omxplayer limitation with Advanced SSA? Edited February 23, 2017 by barat
haraldov 10 Posted February 24, 2017 Posted February 24, 2017 (edited) 1. my subs are not displayed (external, because embedded in mkv works). ET sees it (are even picked/enabled). When I open same movie on windows chrome from tv.emby.media subtitles are displayed Omxplayer have limited support for embedded subtitles. Support for SSA and ASS subtitles is implemented https://github.com/popcornmix/omxplayer/issues/402. The latest omxplayer code have support for displaying subtitle with correct subtitle position I believe https://github.com/popcornmix/omxplayer/commit/862d94a41e1fdf8599282b8b8a902ca3086ff100 Who can compile omxplayer like this: # Prep your system for building packages https://help.ubuntu.com/community/CompilingEasyHowTo sudo apt-get install build-essential sudo apt-get install cvs subversion git-core mercurial # Clone the latest git source git clone https://github.com/popcornmix/omxplayer.git cd omxplayer ./prepare-native-raspbian.sh # Install the necessary package make ffmpeg make sudo make install Edited February 24, 2017 by haraldov
denz 501 Posted March 4, 2017 Posted March 4, 2017 Want to report that the home screen doesnt refresh, guide does refresh i left it on the tv guide before going to sleep and when i clicked back the now playing was the same as it was when i went to the guide. Overall it is working great on the pi live tv channel change is respectable still slow but it is usable for sd it is around 3 seconds hd little longer about 5. So far no issues to report blank screen has disappeared. There still issue with remote but it doesnt stop me watching anything. I am impressed how fast the video starts from the network.
Luke 42239 Posted March 5, 2017 Author Posted March 5, 2017 Updates are rolling out and you'll soon be able to use MB2-style alpha-numeric shortcuts. Enjoy.
denz 501 Posted March 12, 2017 Posted March 12, 2017 Last week emby on pi was performing great but now recorded tv takes as much as starting live hd 5 to 6 seconds. Not sure what is happening but I am noticing slow http response but nothing has been changed on the network. 2017-03-12 12:12:19.3843 Info HttpServer: HTTP Response 500 to 192.168.1.28. Time: 4200ms (slow). http://192.168.1.2:8096/emby/Videos/a660f0bc0cc33e6160ced3a4dcc3bd35/stream.ts?Static=true&mediaSourceId=a660f0bc0cc33e6160ced3a4dcc3bd35&deviceId=raspberrypihome&Tag=e6ea19f329ad00c9872875b0f550a2dc2017-03-12 12:12:19.3943 Info HttpServer: HTTP Response 206 to 192.168.1.28. Time: 60ms. http://192.168.1.2:8096/emby/Videos/a660f0bc0cc33e6160ced3a4dcc3bd35/stream.ts?Static=true&mediaSourceId=a660f0bc0cc33e6160ced3a4dcc3bd35&deviceId=raspberrypihome&Tag=e6ea19f329ad00c9872875b0f550a2dc2017-03-12 12:12:19.4043 Info HttpServer: HTTP GET http://192.168.1.2:8096/emby/Videos/a660f0bc0cc33e6160ced3a4dcc3bd35/stream.ts?Static=true&mediaSourceId=a660f0bc0cc33e6160ced3a4dcc3bd35&deviceId=raspberrypihome&Tag=e6ea19f329ad00c9872875b0f550a2dc. UserAgent: Lavf/57.41.100 2017-03-12 12:12:21.2043 Info HttpServer: HTTP GET http://192.168.1.2:8096/dlna/367a0758c34c4955a68fb730a865eede/description.xml. UserAgent: Allegro-Software-WebClient/5.40b1 DLNADOC/1.50 2017-03-12 12:12:21.2043 Info Dlna: No matching device profile found. The default will need to be used. Host: 192.168.1.2:8096 Connection: close User-Agent: Allegro-Software-WebClient/5.40b1 DLNADOC/1.50 Accept: */*2017-03-12 12:12:21.2043 Info HttpServer: HTTP Response 200 to 192.168.1.17. Time: 0ms. http://192.168.1.2:8096/dlna/367a0758c34c4955a68fb730a865eede/description.xml2017-03-12 12:12:23.7153 Info HttpServer: HTTP POST http://192.168.1.2:8096/emby/Sessions/Playing/Stopped. UserAgent: Mozilla/5.0 (X11; Linux armv7l) AppleWebKit/537.36 (KHTML, like Gecko) EmbyTheaterPi/2.5.32 Chrome/53.0.2785.143 Electron/1.4.14 Safari/537.36 2017-03-12 12:12:23.7153 Info SessionManager: Playback stopped reported by app Emby Theater Pi 2.5.32 playing 2017 - NSW Mell And Cyn 05/03/2017. Stopped at 2933 ms2017-03-12 12:12:23.7153 Info HttpServer: HTTP Response 204 to 192.168.1.28. Time: 0ms. http://192.168.1.2:8096/emby/Sessions/Playing/Stopped2017-03-12 12:12:24.0953 Error HttpResultFactory: Error streaming data
Luke 42239 Posted March 12, 2017 Author Posted March 12, 2017 I've pushed an update to the electron app. It's mostly an update to internal changes, so you'll want to grab the latest. Thanks !
barat 27 Posted March 13, 2017 Posted March 13, 2017 Just "git pull" on Pi or something needs to be rebuilt?
barat 27 Posted March 13, 2017 Posted March 13, 2017 Ok - so firstly need to commit my passthrough enable edit
haraldov 10 Posted March 13, 2017 Posted March 13, 2017 I has been nice if "ET on raspberry" could support burning in subtitles into the video as "ET for Windows" can. When I use Emby Theater 2.5.40 for windows the dvbsub are burned into the video when Emby server 3.2.7.0 on Ubuntu 16.04 transcode the video. The ffmpeg-transcode log tells me that ffmpeg use this options for burning in the subtitle, which is correct option from the ffmpeg wiki documentation to burn hardsubs into the video. -filter_complex "[0:1]scale=1280:720[sub] ; [0:0] [sub] overlay" When I try to use ET for raspberry (latest from git) to play the same recording no transcoding happens (no ffmpeg-transcode log are generated) .Without the transcoding the subtitles do not show on the video because omxplayer do not support dvbsub. Attaching ffmpeg-transcode log and server log. server-63624991565.txt ffmpeg-transcode-3c515fd6-4970-490d-affb-2cfa88d40d23.txt
bluemonkey07 590 Posted April 1, 2017 Posted April 1, 2017 (edited) Trying this out on an original RPI I had laying around but no joy. I install the full UI version of rasbian and followed the instructions in the original post but still getting warnings when installing electron Edited April 2, 2017 by Vidman
Luke 42239 Posted April 8, 2017 Author Posted April 8, 2017 I've added the same header slide effect from the web app so that when you scroll vertically, the header slides away so that you can see posters on the full height of the screen. Enjoy.
