Spotta 6 Posted July 4, 2018 Posted July 4, 2018 I pushed some updates to the Pi repo yesterday just to bring this up to speed a little bit with other platforms. Thanks guys. Pardon my Ignorance, I ran apt-get update & upgrade but saw no mention of Emby getting updated, do we have to update it manually?
Luke 42239 Posted July 4, 2018 Author Posted July 4, 2018 We don't have an install package for this yet so apt get update won't do anything. You'll essentially need to repeat the install steps. 1
darkassassin07 674 Posted July 4, 2018 Posted July 4, 2018 (edited) Can anyone tell me how to change this so that Emby Theater starts at startup with CEC support?Once you have installed cec with: sudo apt-get install cec-utilsUse this line to start with cec: @/usr/local/bin/electron /home/pi/emby-theater-pi cec-client Not something I have actually used before, so someone correct me if im wrong pls Edited July 4, 2018 by darkassassin07
Luke 42239 Posted August 8, 2018 Author Posted August 8, 2018 I'm pleased to announce we finally have a one-click install for testing. Please see instructions here: https://emby.media/community/index.php?/topic/42868-emby-theater-for-linux/?p=606796 Thanks ! 1
Luke 42239 Posted August 9, 2018 Author Posted August 9, 2018 We now have arm and x64 Debian packages for emby theater on Linux:https://emby.media/community/index.php?/topic/42868-emby-theater-for-linuxThis is an easy one click install process. The arm package runs great on raspberry pi. Please try it out, thanks !
rechner123 12 Posted August 16, 2018 Posted August 16, 2018 I'm pleased to announce we finally have a one-click install for testing. Please see instructions here: https://emby.media/community/index.php?/topic/42868-emby-theater-for-linux/?p=606796 Thanks ! My videos stutters and then stops after awhile watching a movie with my raspberry pi 3. I have seen this if the ram is about 95% full. At 97% the video stops an raspi hang up. Does anyone know what i can do? Are there settings to do? How can i control the raspberry over hdmi-cec with the new version? Thanks
Luke 42239 Posted August 16, 2018 Author Posted August 16, 2018 Hi, try the rpi update instructions that are in the other topic. Thanks.
rechner123 12 Posted August 17, 2018 Posted August 17, 2018 Hi, try the rpi update instructions that are in the other topic. Thanks. I have made the installation like in the other topic described! Just wrote here because i am not sure if it is a problem with my raspberry or emby theater for linux.
rechner123 12 Posted August 17, 2018 Posted August 17, 2018 Yes i have rebooted and tried several things. I have reinstalled raspbian twice, done rpi update and installed emby theater. First i thought it is a temperature problem, but i took a fan to cool the raspberry. The temperature i have monitored over ssh with a android app, and there was also the ram usage to see. And over 90% is maybe too much. So thought this is maybe the problem?
Luke 42239 Posted August 17, 2018 Author Posted August 17, 2018 Did you enable hardware acceleration?
Luke 42239 Posted August 17, 2018 Author Posted August 17, 2018 I'm not quite sure what to say. In our testing it is playing back smoothly.
rechner123 12 Posted August 17, 2018 Posted August 17, 2018 Now i took a look again into playback settings and saw rpi copyback. Have not scrolled down and seen this. Is this specially for raspberry? Or what does RPI stand for?
Strudo76 7 Posted August 18, 2018 Posted August 18, 2018 My videos stutters and then stops after awhile watching a movie with my raspberry pi 3. I have seen this if the ram is about 95% full. At 97% the video stops an raspi hang up. Does anyone know what i can do? Are there settings to do? How can i control the raspberry over hdmi-cec with the new version? Thanks It should be noted that the RPi doesn't have hardward H265/HEVC decoding, so if you're trying to watch something in that format, you might have playback issues (unless that's running much better now as well, which would be amazing by the way )
Luke 42239 Posted August 18, 2018 Author Posted August 18, 2018 Yea we'd have to look at some examples. Thanks.
rechner123 12 Posted August 19, 2018 Posted August 19, 2018 (edited) Hi Yesterday i have started a video and the pi hang up after 20 minutes. Hardware acceleration was set to rpi copy back. Medieninformation Video Title1080P H264 CodecH264 AVCYes ProfilHigh Level41 Auflösung1920x800 Seitenverhältnis2.40:1 AnamorphNo InterlacedNo Bildrate23.9760246 Bitrate11836 kbps Bit-Tiefe8 bit Pixelformatyuv420p Ref Frames1 NAL4 Audio TitleGer DTS 5.1 Default Spracheger CodecDTS ProfilDTS Darstellung5.1 Kanäle6 ch Bitrate1536 kbps Sample-Rate48000 Hz VoreinstellungYes Audio TitleEng DTS 5.1 Spracheeng CodecDTS ProfilDTS Darstellung5.1 Kanäle6 ch Bitrate1536 kbps Sample-Rate48000 Hz At the beginning of the movie the cpu util was about 30% and ram about 90%. Later i did not look at these values. Edited August 19, 2018 by rechner123
rechner123 12 Posted August 19, 2018 Posted August 19, 2018 It should be noted that the RPi doesn't have hardward H265/HEVC decoding, so if you're trying to watch something in that format, you might have playback issues (unless that's running much better now as well, which would be amazing by the way ) I know that the pi has no x265 decoder. I have only x264 mkv files tried.
Luke 42239 Posted August 20, 2018 Author Posted August 20, 2018 Ok we've determined that the rpi-copy back option is not suitable for high bitrate content. For this you'll want to use the regular RPI gpu option, which will perform better. However, the copy back option is the only one that supports deinterlacing, so you may want to switch it for live tv and other interlaced content. We may need to add a smart option to make this easier so that you're not always having to toggle it prior to playback.
rechner123 12 Posted August 21, 2018 Posted August 21, 2018 Hi So the gpu is overcharged with rpi copy back, and not cpu or ram? I have tried again with RPI acceleration and it seems that it is working without hang up the pi. Thank you! Is there any chance to get hdmi-cec working as with the old release?
Luke 42239 Posted August 21, 2018 Author Posted August 21, 2018 Yes we'll be looking at hdmi-cec for a future update. thanks.
