latinumking 7 Posted January 15, 2018 Posted January 15, 2018 ok thank you, but i have installed this on december. so i there is no update for meI'm also interested, atm im running emby on an old notebook in order to have steady videostream, all former Android TV boxes running emby theater had playback issues. Raspi could be an alternative approach, please keep that Raspi project running. Gesendet von meinem MI MAX 2 mit Tapatalk
denz 501 Posted January 20, 2018 Posted January 20, 2018 @@Luke any chance you can have a look at this so we can use it on the pi. MPV does not support deinterlacing I have put a feature request in mpv issues. I have taken a screenshot but when you look at the screenshot it does not get shown. When you watch something the player controls autohide but the transparent overlay does not.
denz 501 Posted January 20, 2018 Posted January 20, 2018 (edited) if you remove this playbackhandler "--alpha", "100" then the screen displays correctly only downside the player controls do not appear but I can live with that. Edited January 20, 2018 by denz
denz 501 Posted January 20, 2018 Posted January 20, 2018 Live tv is now so much quicker than months ago when I tried it
sonicblue83 4 Posted January 22, 2018 Posted January 22, 2018 Hi, will there be an easy installable version of Emby (Theater) for the Raspberry Pi? One in the way Pley and Kodi are offering.
Luke 42239 Posted January 22, 2018 Author Posted January 22, 2018 It's something we'd like to do in the future, yes.
latinumking 7 Posted January 23, 2018 Posted January 23, 2018 It's something we'd like to do in the future, yes.Can you give us a rough estimate on the time axis? Are we talking about weeks or months?Your answer is highly appreciated. Kind regards, Lati Gesendet von meinem MI MAX 2 mit Tapatalk 1
blue-wizard 2 Posted February 10, 2018 Posted February 10, 2018 (edited) After a fresh raspbian install on a Pi3B, when I launch Emby Theater I just get a completely black screen. Any advice? EDIT: Found the main linux branch (https://emby.media/community/index.php?/topic/42868-emby-theater-for-linux/) Going to post on there. Edited February 10, 2018 by blue-wizard
tdiguy 99 Posted March 13, 2018 Posted March 13, 2018 Well, i am guessing something has changed a good deal. I am getting errors trying to install electron. pi@raspberrypi:~ $ sudo npm -g install electron npm ERR! 404 Not Found npm ERR! 404 npm ERR! 404 'types/node' is not in the npm registry. npm ERR! 404 You should bug the author to publish it npm ERR! 404 It was specified as a dependency of 'electron' npm ERR! 404 npm ERR! 404 Note that you can also install from a npm ERR! 404 tarball, folder, or http url, or git url. npm ERR! System Linux 4.9.59-v7+ npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "-g" "install" "electron" npm ERR! cwd /home/pi npm ERR! node -v v4.8.2 npm ERR! npm -v 1.4.21 npm ERR! code E404 npm ERR! npm ERR! Additional logging details can be found in: npm ERR! /home/pi/npm-debug.log npm ERR! not ok code 0 this is from the debug.log: pi@raspberrypi:~ $ cat /home/pi/npm-debug.log 0 info it worked if it ends with ok 1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', '-g', 'install', 'electron' ] 2 info using npm@1.4.21 3 info using node@v4.8.2 4 verbose cache add [ 'electron', null ] 5 verbose cache add name=undefined spec="electron" args=["electron",null] 6 verbose parsed url Url { 6 verbose parsed url protocol: null, 6 verbose parsed url slashes: null, 6 verbose parsed url auth: null, 6 verbose parsed url host: null, 6 verbose parsed url port: null, 6 verbose parsed url hostname: null, 6 verbose parsed url hash: null, 6 verbose parsed url search: null, 6 verbose parsed url query: null, 6 verbose parsed url pathname: 'electron', 6 verbose parsed url path: 'electron', 6 verbose parsed url href: 'electron' } 7 silly lockFile da005969-electron electron 8 verbose lock electron /root/.npm/da005969-electron.lock 9 silly lockFile da005969-electron electron 10 silly lockFile da005969-electron electron 11 verbose addNamed [ 'electron', '' ] 12 verbose addNamed [ null, '*' ] 13 silly lockFile 89f56ea2-electron electron@ 14 verbose lock electron@ /root/.npm/89f56ea2-electron.lock 15 silly addNameRange { name: 'electron', range: '*', hasData: false } 16 verbose request where is /electron 17 verbose request registry https://registry.npmjs.org/ 18 verbose request id ac330c95090f366d 19 verbose url raw /electron 20 verbose url resolving [ 'https://registry.npmjs.org/', './electron' ] 21 verbose url resolved https://registry.npmjs.org/electron 22 verbose request where is https://registry.npmjs.org/electron 23 info trying registry request attempt 1 at 1:01:41 PM 24 http GET https://registry.npmjs.org/electron 25 http 200 https://registry.npmjs.org/electron 26 silly registry.get cb [ 200, 26 silly registry.get { 'content-type': 'application/json; charset=UTF-8', 26 silly registry.get server: 'UploadServer', 26 silly registry.get 'cache-control': 'max-age=300', 26 silly registry.get 'last-modified': 'Sat, 10 Mar 2018 22:25:42 GMT', 26 silly registry.get etag: '"5aa45b66-28126"', 26 silly registry.get 'x-npm-region': 'US-East', 26 silly registry.get 'content-encoding': 'gzip', 26 silly registry.get 'content-length': '14643', 26 silly registry.get 'accept-ranges': 'bytes', 26 silly registry.get date: 'Tue, 13 Mar 2018 13:01:41 GMT', 26 silly registry.get via: '1.1 varnish', 26 silly registry.get age: '7521', 26 silly registry.get connection: 'close', 26 silly registry.get 'x-served-by': 'cache-bos8223-BOS', 26 silly registry.get 'x-cache': 'HIT', 26 silly registry.get 'x-cache-hits': '2', 26 silly registry.get 'x-timer': 'S1520946102.819348,VS0,VE1', 26 silly registry.get vary: 'Accept-Encoding, Accept' } ] 27 silly addNameRange number 2 { name: 'electron', range: '*', hasData: true } 28 silly addNameRange versions [ 'electron', 28 silly addNameRange [ '0.1.0', 28 silly addNameRange '0.1.1', 28 silly addNameRange '0.1.2', 28 silly addNameRange '0.2.0', 28 silly addNameRange '0.2.1', 28 silly addNameRange '0.3.0', 28 silly addNameRange '0.4.0', 28 silly addNameRange '0.4.1', 28 silly addNameRange '1.3.1', 28 silly addNameRange '1.3.2', 28 silly addNameRange '1.3.3', 28 silly addNameRange '1.3.4', 28 silly addNameRange '1.3.5', 28 silly addNameRange '1.3.6', 28 silly addNameRange '1.4.0', 28 silly addNameRange '1.4.1', 28 silly addNameRange '1.3.7', 28 silly addNameRange '1.4.2', 28 silly addNameRange '1.4.3', 28 silly addNameRange '1.4.4', 28 silly addNameRange '1.3.8', 28 silly addNameRange '1.4.5', 28 silly addNameRange '1.4.6', 28 silly addNameRange '1.4.7', 28 silly addNameRange '1.3.9', 28 silly addNameRange '1.3.10', 28 silly addNameRange '1.4.8', 28 silly addNameRange '1.3.12', 28 silly addNameRange '1.4.10', 28 silly addNameRange '1.3.13', 28 silly addNameRange '1.4.11', 28 silly addNameRange '1.4.12', 28 silly addNameRange '1.4.13', 28 silly addNameRange '1.4.14', 28 silly addNameRange '1.4.15', 28 silly addNameRange '1.5.0', 28 silly addNameRange '1.5.1', 28 silly addNameRange '1.6.0', 28 silly addNameRange '1.6.1', 28 silly addNameRange '1.6.2', 28 silly addNameRange '1.6.3', 28 silly addNameRange '1.3.14', 28 silly addNameRange '1.6.4', 28 silly addNameRange '1.6.5', 28 silly addNameRange '1.4.16', 28 silly addNameRange '1.6.6', 28 silly addNameRange '1.6.7', 28 silly addNameRange '1.3.15', 28 silly addNameRange '1.6.8', 28 silly addNameRange '1.6.9', 28 silly addNameRange '1.7.0', 28 silly addNameRange '1.6.10', 28 silly addNameRange '1.7.1', 28 silly addNameRange '1.6.11', 28 silly addNameRange '1.7.2', 28 silly addNameRange '1.7.3', 28 silly addNameRange '1.7.4', 28 silly addNameRange '1.7.5', 28 silly addNameRange '1.6.12', 28 silly addNameRange '1.7.6', 28 silly addNameRange '1.7.7', 28 silly addNameRange '1.6.13', 28 silly addNameRange '1.7.8', 28 silly addNameRange '1.6.14', 28 silly addNameRange '1.8.1', 28 silly addNameRange '1.7.9', 28 silly addNameRange '1.6.15', 28 silly addNameRange '1.8.2-beta.1', 28 silly addNameRange '1.8.2-beta.2', 28 silly addNameRange '1.8.2-beta.3', 28 silly addNameRange '1.7.10', 28 silly addNameRange '1.7.11', 28 silly addNameRange '1.6.16', 28 silly addNameRange '1.8.2-beta.4', 28 silly addNameRange '1.8.2-beta.5', 28 silly addNameRange '1.7.12', 28 silly addNameRange '1.6.17', 28 silly addNameRange '1.8.2', 28 silly addNameRange '2.0.0-beta.1', 28 silly addNameRange '2.0.0-beta.2', 28 silly addNameRange '1.8.3', 28 silly addNameRange '2.0.0-beta.3' ] ] 29 verbose addNamed [ 'electron', '1.8.3' ] 30 verbose addNamed [ '1.8.3', '1.8.3' ] 31 silly lockFile f2844cce-electron-1-8-3 electron@1.8.3 32 verbose lock electron@1.8.3 /root/.npm/f2844cce-electron-1-8-3.lock 33 silly lockFile 9effb0fe--org-electron-electron-1-8-3-tgz https://registry.npmjs.org/electron/-/electron-1.8.3.tgz 34 verbose lock https://registry.npmjs.org/electron/-/electron-1.8.3.tgz /root/.npm/9effb0fe--org-electron-electron-1-8-3-tgz.lock 35 verbose addRemoteTarball [ 'https://registry.npmjs.org/electron/-/electron-1.8.3.tgz', 35 verbose addRemoteTarball '001416ea3a25ce594e317cb5531bc41eadd22f7f' ] 36 info retry fetch attempt 1 at 1:01:41 PM 37 verbose fetch to= /tmp/npm-1144-dfd-ZV0u/registry.npmjs.org/electron/-/electron-1.8.3.tgz 38 http GET https://registry.npmjs.org/electron/-/electron-1.8.3.tgz 39 http 200 https://registry.npmjs.org/electron/-/electron-1.8.3.tgz 40 silly lockFile 9effb0fe--org-electron-electron-1-8-3-tgz https://registry.npmjs.org/electron/-/electron-1.8.3.tgz 41 silly lockFile 9effb0fe--org-electron-electron-1-8-3-tgz https://registry.npmjs.org/electron/-/electron-1.8.3.tgz 42 silly lockFile f2844cce-electron-1-8-3 electron@1.8.3 43 silly lockFile f2844cce-electron-1-8-3 electron@1.8.3 44 silly lockFile 89f56ea2-electron electron@ 45 silly lockFile 89f56ea2-electron electron@ 46 silly resolved [ { scripts: 46 silly resolved { 'cache-clean': 'rm -rf ~/.electron && rm -rf dist', 46 silly resolved postinstall: 'node install.js', 46 silly resolved pretest: 'npm run cache-clean', 46 silly resolved test: 'standard' }, 46 silly resolved bin: { electron: 'cli.js' }, 46 silly resolved main: 'index.js', 46 silly resolved types: 'electron.d.ts', 46 silly resolved dependencies: 46 silly resolved { '@types/node': '^8.0.24', 46 silly resolved 'electron-download': '^3.0.1', 46 silly resolved 'extract-zip': '^1.0.3' }, 46 silly resolved devDependencies: 46 silly resolved { 'home-path': '^0.1.1', 46 silly resolved 'path-exists': '^2.0.0', 46 silly resolved standard: '^5.4.1' }, 46 silly resolved directories: { test: 'test' }, 46 silly resolved name: 'electron', 46 silly resolved version: '1.8.3', 46 silly resolved repository: 46 silly resolved { type: 'git', 46 silly resolved url: 'git+https://github.com/electron/electron.git' }, 46 silly resolved description: 'Build cross platform desktop apps with JavaScript, HTML, and CSS', 46 silly resolved license: 'MIT', 46 silly resolved author: { name: 'Electron Community' }, 46 silly resolved keywords: [ 'electron' ], 46 silly resolved bugs: { url: 'https://github.com/electron/electron/issues' }, 46 silly resolved homepage: 'https://github.com/electron/electron#readme', 46 silly resolved _id: 'electron@1.8.3', 46 silly resolved _npmVersion: '5.6.0', 46 silly resolved _nodeVersion: '8.9.4', 46 silly resolved _npmUser: { name: 'electron', email: 'electron@github.com' }, 46 silly resolved dist: 46 silly resolved { integrity: 'sha512-ZZYSPB9tLh0m4uZOTcQllv/U8ts3GaMyEkBTooBr5rO+xl0WfQlecUcPuyw6aqtrZfNKsqLprorXKgsFmwcI5w==', 46 silly resolved shasum: '001416ea3a25ce594e317cb5531bc41eadd22f7f', 46 silly resolved tarball: 'https://registry.npmjs.org/electron/-/electron-1.8.3.tgz', 46 silly resolved fileCount: 7, 46 silly resolved unpackedSize: 364373 }, 46 silly resolved maintainers: [ [Object], [Object] ], 46 silly resolved _npmOperationalInternal: 46 silly resolved { host: 's3://npm-registry-packages', 46 silly resolved tmp: 'tmp/electron_1.8.3_1520300765788_0.3815120863908905' }, 46 silly resolved _shasum: '001416ea3a25ce594e317cb5531bc41eadd22f7f', 46 silly resolved _from: 'electron@', 46 silly resolved _resolved: 'https://registry.npmjs.org/electron/-/electron-1.8.3.tgz' } ] 47 info install electron@1.8.3 into /usr/local/lib 48 info installOne electron@1.8.3 49 verbose lib/node_modules/electron unbuild 50 verbose tar unpack /root/.npm/electron/1.8.3/package.tgz 51 silly lockFile 7046374e--local-lib-node-modules-electron tar:///usr/local/lib/node_modules/electron 52 verbose lock tar:///usr/local/lib/node_modules/electron /root/.npm/7046374e--local-lib-node-modules-electron.lock 53 silly lockFile 59e42d18-t-npm-electron-1-8-3-package-tgz tar:///root/.npm/electron/1.8.3/package.tgz 54 verbose lock tar:///root/.npm/electron/1.8.3/package.tgz /root/.npm/59e42d18-t-npm-electron-1-8-3-package-tgz.lock 55 silly gunzTarPerm modes [ '755', '644' ] 56 silly gunzTarPerm extractEntry package.json 57 silly gunzTarPerm extractEntry cli.js 58 silly gunzTarPerm extractEntry electron.d.ts 59 silly gunzTarPerm extractEntry index.js 60 silly gunzTarPerm extractEntry install.js 61 silly gunzTarPerm extractEntry LICENSE 62 silly gunzTarPerm extractEntry README.md 63 silly lockFile 7046374e--local-lib-node-modules-electron tar:///usr/local/lib/node_modules/electron 64 silly lockFile 7046374e--local-lib-node-modules-electron tar:///usr/local/lib/node_modules/electron 65 silly lockFile 59e42d18-t-npm-electron-1-8-3-package-tgz tar:///root/.npm/electron/1.8.3/package.tgz 66 silly lockFile 59e42d18-t-npm-electron-1-8-3-package-tgz tar:///root/.npm/electron/1.8.3/package.tgz 67 info preinstall electron@1.8.3 68 verbose readDependencies using package.json deps 69 verbose readDependencies using package.json deps 70 verbose cache add [ '@types/node@^8.0.24', null ] 71 verbose cache add name=undefined spec="@types/node@^8.0.24" args=["@types/node@^8.0.24",null] 72 verbose parsed url Url { 72 verbose parsed url protocol: null, 72 verbose parsed url slashes: null, 72 verbose parsed url auth: null, 72 verbose parsed url host: null, 72 verbose parsed url port: null, 72 verbose parsed url hostname: null, 72 verbose parsed url hash: null, 72 verbose parsed url search: null, 72 verbose parsed url query: null, 72 verbose parsed url pathname: '@types/node@%5E8.0.24', 72 verbose parsed url path: '@types/node@%5E8.0.24', 72 verbose parsed url href: '@types/node@%5E8.0.24' } 73 verbose cache add [ 'electron-download@^3.0.1', null ] 74 verbose cache add name=undefined spec="electron-download@^3.0.1" args=["electron-download@^3.0.1",null] 75 verbose parsed url Url { 75 verbose parsed url protocol: null, 75 verbose parsed url slashes: null, 75 verbose parsed url auth: null, 75 verbose parsed url host: null, 75 verbose parsed url port: null, 75 verbose parsed url hostname: null, 75 verbose parsed url hash: null, 75 verbose parsed url search: null, 75 verbose parsed url query: null, 75 verbose parsed url pathname: 'electron-download@%5E3.0.1', 75 verbose parsed url path: 'electron-download@%5E3.0.1', 75 verbose parsed url href: 'electron-download@%5E3.0.1' } 76 verbose cache add [ 'extract-zip@^1.0.3', null ] 77 verbose cache add name=undefined spec="extract-zip@^1.0.3" args=["extract-zip@^1.0.3",null] 78 verbose parsed url Url { 78 verbose parsed url protocol: null, 78 verbose parsed url slashes: null, 78 verbose parsed url auth: null, 78 verbose parsed url host: null, 78 verbose parsed url port: null, 78 verbose parsed url hostname: null, 78 verbose parsed url hash: null, 78 verbose parsed url search: null, 78 verbose parsed url query: null, 78 verbose parsed url pathname: 'extract-zip@%5E1.0.3', 78 verbose parsed url path: 'extract-zip@%5E1.0.3', 78 verbose parsed url href: 'extract-zip@%5E1.0.3' } 79 verbose cache add name="" spec="types/node@^8.0.24" args=["","types/node@^8.0.24"] 80 verbose parsed url Url { 80 verbose parsed url protocol: null, 80 verbose parsed url slashes: null, 80 verbose parsed url auth: null, 80 verbose parsed url host: null, 80 verbose parsed url port: null, 80 verbose parsed url hostname: null, 80 verbose parsed url hash: null, 80 verbose parsed url search: null, 80 verbose parsed url query: null, 80 verbose parsed url pathname: 'types/node@%5E8.0.24', 80 verbose parsed url path: 'types/node@%5E8.0.24', 80 verbose parsed url href: 'types/node@%5E8.0.24' } 81 verbose cache add name="electron-download" spec="^3.0.1" args=["electron-download","^3.0.1"] 82 verbose parsed url Url { 82 verbose parsed url protocol: null, 82 verbose parsed url slashes: null, 82 verbose parsed url auth: null, 82 verbose parsed url host: null, 82 verbose parsed url port: null, 82 verbose parsed url hostname: null, 82 verbose parsed url hash: null, 82 verbose parsed url search: null, 82 verbose parsed url query: null, 82 verbose parsed url pathname: '%5E3.0.1', 82 verbose parsed url path: '%5E3.0.1', 82 verbose parsed url href: '%5E3.0.1' } 83 verbose addNamed [ 'electron-download', '^3.0.1' ] 84 verbose addNamed [ null, '>=3.0.1 <4.0.0' ] 85 silly lockFile 8d1cab67-electron-download-3-0-1 electron-download@^3.0.1 86 verbose lock electron-download@^3.0.1 /root/.npm/8d1cab67-electron-download-3-0-1.lock 87 verbose cache add name="extract-zip" spec="^1.0.3" args=["extract-zip","^1.0.3"] 88 verbose parsed url Url { 88 verbose parsed url protocol: null, 88 verbose parsed url slashes: null, 88 verbose parsed url auth: null, 88 verbose parsed url host: null, 88 verbose parsed url port: null, 88 verbose parsed url hostname: null, 88 verbose parsed url hash: null, 88 verbose parsed url search: null, 88 verbose parsed url query: null, 88 verbose parsed url pathname: '%5E1.0.3', 88 verbose parsed url path: '%5E1.0.3', 88 verbose parsed url href: '%5E1.0.3' } 89 verbose addNamed [ 'extract-zip', '^1.0.3' ] 90 verbose addNamed [ null, '>=1.0.3 <2.0.0' ] 91 silly lockFile 9879f4ae-extract-zip-1-0-3 extract-zip@^1.0.3 92 verbose lock extract-zip@^1.0.3 /root/.npm/9879f4ae-extract-zip-1-0-3.lock 93 verbose cache add name="types/node" spec="^8.0.24" args=["types/node","^8.0.24"] 94 verbose parsed url Url { 94 verbose parsed url protocol: null, 94 verbose parsed url slashes: null, 94 verbose parsed url auth: null, 94 verbose parsed url host: null, 94 verbose parsed url port: null, 94 verbose parsed url hostname: null, 94 verbose parsed url hash: null, 94 verbose parsed url search: null, 94 verbose parsed url query: null, 94 verbose parsed url pathname: '%5E8.0.24', 94 verbose parsed url path: '%5E8.0.24', 94 verbose parsed url href: '%5E8.0.24' } 95 verbose addNamed [ 'types/node', '^8.0.24' ] 96 verbose addNamed [ null, '>=8.0.24 <9.0.0' ] 97 silly lockFile f348eb0d-types-node-8-0-24 types/node@^8.0.24 98 verbose lock types/node@^8.0.24 /root/.npm/f348eb0d-types-node-8-0-24.lock 99 silly addNameRange { name: 'electron-download', 99 silly addNameRange range: '>=3.0.1 <4.0.0', 99 silly addNameRange hasData: false } 100 silly addNameRange { name: 'extract-zip', range: '>=1.0.3 <2.0.0', hasData: false } 101 verbose request where is /electron-download 102 verbose request registry https://registry.npmjs.org/ 103 verbose url raw /electron-download 104 verbose url resolving [ 'https://registry.npmjs.org/', './electron-download' ] 105 verbose url resolved https://registry.npmjs.org/electron-download 106 verbose request where is https://registry.npmjs.org/electron-download 107 info trying registry request attempt 1 at 1:01:42 PM 108 http GET https://registry.npmjs.org/electron-download 109 silly addNameRange { name: 'types/node', range: '>=8.0.24 <9.0.0', hasData: false } 110 verbose request where is /extract-zip 111 verbose request registry https://registry.npmjs.org/ 112 verbose url raw /extract-zip 113 verbose url resolving [ 'https://registry.npmjs.org/', './extract-zip' ] 114 verbose url resolved https://registry.npmjs.org/extract-zip 115 verbose request where is https://registry.npmjs.org/extract-zip 116 info trying registry request attempt 1 at 1:01:42 PM 117 http GET https://registry.npmjs.org/extract-zip 118 verbose request where is /types/node 119 verbose request registry https://registry.npmjs.org/ 120 verbose url raw /types/node 121 verbose url resolving [ 'https://registry.npmjs.org/', './types/node' ] 122 verbose url resolved https://registry.npmjs.org/types/node 123 verbose request where is https://registry.npmjs.org/types/node 124 info trying registry request attempt 1 at 1:01:42 PM 125 http GET https://registry.npmjs.org/types/node 126 http 200 https://registry.npmjs.org/extract-zip 127 silly registry.get cb [ 200, 127 silly registry.get { 'content-type': 'application/json; charset=UTF-8', 127 silly registry.get server: 'UploadServer', 127 silly registry.get 'cache-control': 'max-age=300', 127 silly registry.get 'last-modified': 'Tue, 16 Jan 2018 17:55:43 GMT', 127 silly registry.get etag: '"5a5e3c9f-6938"', 127 silly registry.get 'x-npm-region': 'US-East', 127 silly registry.get 'content-encoding': 'gzip', 127 silly registry.get 'content-length': '3775', 127 silly registry.get 'accept-ranges': 'bytes', 127 silly registry.get date: 'Tue, 13 Mar 2018 13:01:42 GMT', 127 silly registry.get via: '1.1 varnish', 127 silly registry.get age: '5214', 127 silly registry.get connection: 'close', 127 silly registry.get 'x-served-by': 'cache-bos8230-BOS', 127 silly registry.get 'x-cache': 'HIT', 127 silly registry.get 'x-cache-hits': '1', 127 silly registry.get 'x-timer': 'S1520946103.671870,VS0,VE1', 127 silly registry.get vary: 'Accept-Encoding, Accept' } ] 128 http 200 https://registry.npmjs.org/electron-download 129 silly registry.get cb [ 200, 129 silly registry.get { 'content-type': 'application/json; charset=UTF-8', 129 silly registry.get server: 'UploadServer', 129 silly registry.get 'cache-control': 'max-age=300', 129 silly registry.get 'last-modified': 'Tue, 27 Feb 2018 23:12:56 GMT', 129 silly registry.get etag: '"5a95e5f8-c0fb"', 129 silly registry.get 'x-npm-region': 'US-East', 129 silly registry.get 'content-encoding': 'gzip', 129 silly registry.get 'content-length': '6301', 129 silly registry.get 'accept-ranges': 'bytes', 129 silly registry.get date: 'Tue, 13 Mar 2018 13:01:42 GMT', 129 silly registry.get via: '1.1 varnish', 129 silly registry.get age: '7479', 129 silly registry.get connection: 'close', 129 silly registry.get 'x-served-by': 'cache-bos8233-BOS', 129 silly registry.get 'x-cache': 'HIT', 129 silly registry.get 'x-cache-hits': '1', 129 silly registry.get 'x-timer': 'S1520946103.665601,VS0,VE1', 129 silly registry.get vary: 'Accept-Encoding, Accept' } ] 130 silly addNameRange number 2 { name: 'extract-zip', range: '>=1.0.3 <2.0.0', hasData: true } 131 silly addNameRange versions [ 'extract-zip', 131 silly addNameRange [ '1.0.0', 131 silly addNameRange '1.0.1', 131 silly addNameRange '1.0.2', 131 silly addNameRange '1.0.3', 131 silly addNameRange '1.1.0', 131 silly addNameRange '1.1.1', 131 silly addNameRange '1.1.2', 131 silly addNameRange '1.2.0', 131 silly addNameRange '1.3.0', 131 silly addNameRange '1.4.0', 131 silly addNameRange '1.4.1', 131 silly addNameRange '1.5.0', 131 silly addNameRange '1.6.0', 131 silly addNameRange '1.6.1', 131 silly addNameRange '1.6.2', 131 silly addNameRange '1.6.3', 131 silly addNameRange '1.6.4', 131 silly addNameRange '1.6.5', 131 silly addNameRange '1.6.6' ] ] 132 verbose addNamed [ 'extract-zip', '1.6.6' ] 133 verbose addNamed [ '1.6.6', '1.6.6' ] 134 silly lockFile 93baf6d1-extract-zip-1-6-6 extract-zip@1.6.6 135 verbose lock extract-zip@1.6.6 /root/.npm/93baf6d1-extract-zip-1-6-6.lock 136 silly addNameRange number 2 { name: 'electron-download', 136 silly addNameRange range: '>=3.0.1 <4.0.0', 136 silly addNameRange hasData: true } 137 silly addNameRange versions [ 'electron-download', 137 silly addNameRange [ '1.0.0', 137 silly addNameRange '1.0.1', 137 silly addNameRange '1.0.2', 137 silly addNameRange '1.0.3', 137 silly addNameRange '1.0.4', 137 silly addNameRange '1.0.5', 137 silly addNameRange '1.0.6', 137 silly addNameRange '1.0.7', 137 silly addNameRange '1.0.8', 137 silly addNameRange '1.1.0', 137 silly addNameRange '1.2.0', 137 silly addNameRange '1.3.0', 137 silly addNameRange '1.4.0', 137 silly addNameRange '1.4.1', 137 silly addNameRange '2.0.0', 137 silly addNameRange '2.1.0', 137 silly addNameRange '2.1.1', 137 silly addNameRange '2.1.2', 137 silly addNameRange '2.2.0', 137 silly addNameRange '2.2.1', 137 silly addNameRange '3.0.0', 137 silly addNameRange '3.0.1', 137 silly addNameRange '3.0.2', 137 silly addNameRange '3.1.0', 137 silly addNameRange '3.2.0', 137 silly addNameRange '3.3.0', 137 silly addNameRange '4.0.0', 137 silly addNameRange '4.1.0' ] ] 138 verbose addNamed [ 'electron-download', '3.3.0' ] 139 verbose addNamed [ '3.3.0', '3.3.0' ] 140 silly lockFile 176a5c80-electron-download-3-3-0 electron-download@3.3.0 141 verbose lock electron-download@3.3.0 /root/.npm/176a5c80-electron-download-3-3-0.lock 142 silly lockFile 4d1fa3ea-xtract-zip-extract-zip-1-6-6-tgz https://registry.npmjs.org/extract-zip/-/extract-zip-1.6.6.tgz 143 verbose lock https://registry.npmjs.org/extract-zip/-/extract-zip-1.6.6.tgz /root/.npm/4d1fa3ea-xtract-zip-extract-zip-1-6-6-tgz.lock 144 verbose addRemoteTarball [ 'https://registry.npmjs.org/extract-zip/-/extract-zip-1.6.6.tgz', 144 verbose addRemoteTarball '1290ede8d20d0872b429fd3f351ca128ec5ef85c' ] 145 silly lockFile cbafc6af-load-electron-download-3-3-0-tgz https://registry.npmjs.org/electron-download/-/electron-download-3.3.0.tgz 146 verbose lock https://registry.npmjs.org/electron-download/-/electron-download-3.3.0.tgz /root/.npm/cbafc6af-load-electron-download-3-3-0-tgz.lock 147 verbose addRemoteTarball [ 'https://registry.npmjs.org/electron-download/-/electron-download-3.3.0.tgz', 147 verbose addRemoteTarball '2cfd54d6966c019c4d49ad65fbe65cc9cdef68c8' ] 148 info retry fetch attempt 1 at 1:01:42 PM 149 verbose fetch to= /tmp/npm-1144-dfd-ZV0u/registry.npmjs.org/extract-zip/-/extract-zip-1.6.6.tgz 150 info retry fetch attempt 1 at 1:01:42 PM 151 verbose fetch to= /tmp/npm-1144-dfd-ZV0u/registry.npmjs.org/electron-download/-/electron-download-3.3.0.tgz 152 http GET https://registry.npmjs.org/extract-zip/-/extract-zip-1.6.6.tgz 153 http GET https://registry.npmjs.org/electron-download/-/electron-download-3.3.0.tgz 154 http 200 https://registry.npmjs.org/electron-download/-/electron-download-3.3.0.tgz 155 silly lockFile cbafc6af-load-electron-download-3-3-0-tgz https://registry.npmjs.org/electron-download/-/electron-download-3.3.0.tgz 156 silly lockFile cbafc6af-load-electron-download-3-3-0-tgz https://registry.npmjs.org/electron-download/-/electron-download-3.3.0.tgz 157 silly lockFile 176a5c80-electron-download-3-3-0 electron-download@3.3.0 158 silly lockFile 176a5c80-electron-download-3-3-0 electron-download@3.3.0 159 silly lockFile 8d1cab67-electron-download-3-0-1 electron-download@^3.0.1 160 silly lockFile 8d1cab67-electron-download-3-0-1 electron-download@^3.0.1 161 http 404 https://registry.npmjs.org/types/node 162 silly registry.get cb [ 404, 162 silly registry.get { 'content-type': 'application/json', 162 silly registry.get 'cache-control': 'max-age=0', 162 silly registry.get 'content-length': '2', 162 silly registry.get 'accept-ranges': 'bytes', 162 silly registry.get date: 'Tue, 13 Mar 2018 13:01:42 GMT', 162 silly registry.get via: '1.1 varnish', 162 silly registry.get age: '0', 162 silly registry.get connection: 'close', 162 silly registry.get 'x-served-by': 'cache-bos8234-BOS', 162 silly registry.get 'x-cache': 'MISS', 162 silly registry.get 'x-cache-hits': '0', 162 silly registry.get 'x-timer': 'S1520946103.700079,VS0,VE123', 162 silly registry.get vary: 'Accept-Encoding' } ] 163 http 200 https://registry.npmjs.org/extract-zip/-/extract-zip-1.6.6.tgz 164 silly lockFile f348eb0d-types-node-8-0-24 types/node@^8.0.24 165 silly lockFile f348eb0d-types-node-8-0-24 types/node@^8.0.24 166 verbose about to build /usr/local/lib/node_modules/electron 167 verbose lib/node_modules/electron unbuild 168 info preuninstall electron@1.8.3 169 info uninstall electron@1.8.3 170 verbose true,/usr/local/lib/node_modules,/usr/local/lib/node_modules unbuild electron@1.8.3 171 verbose /usr/local/bin,[object Object] binRoot 172 info postuninstall electron@1.8.3 173 error 404 Not Found 173 error 404 173 error 404 'types/node' is not in the npm registry. 173 error 404 You should bug the author to publish it 173 error 404 It was specified as a dependency of 'electron' 173 error 404 173 error 404 Note that you can also install from a 173 error 404 tarball, folder, or http url, or git url. 174 error System Linux 4.9.59-v7+ 175 error command "/usr/bin/nodejs" "/usr/bin/npm" "-g" "install" "electron" 176 error cwd /home/pi 177 error node -v v4.8.2 178 error npm -v 1.4.21 179 error code E404 180 verbose exit [ 1, true ]
tdiguy 99 Posted March 13, 2018 Posted March 13, 2018 I was able to find this: https://blog.marekkraus.sk/linux/how-to-make-electron-run-on-raspberry-pi/ Following that i had no errors. I cant confirm right now because i dont have the pi connected to a tv and i am at work but i think its running: pi@raspberrypi:~/emby-theater-pi $ ps -aux | grep electronpi 5444 0.0 0.0 4376 536 pts/0 S+ 13:20 0:00 grep --color=auto electron If I can get either a nice simple remote like the mi box bluetooth remote to work well with this I think it will make a really nice low cost emby device. Pretty sure i have seen info online on how to use a bluetooth remote with the pi.
darkassassin07 674 Posted April 4, 2018 Posted April 4, 2018 (edited) This has become a fairly long thread with several different sets of install instructions, not all of which work completely. I figured id post what I have done to setup my rpi today, maybe someone will find it useful. First things first, Install Raspbian Once you have booted into Raspbian on your RPI open a Terminal and enter the following: sudo apt-get update sudo apt-get dist-upgrade sudo apt-get update sudo apt-get install npm sudo npm -g install electron@1.4.16 cd ~ git clone https://github.com/MediaBrowser/emby-theater-pi.gitTo start Emby Theater, you can open terminal and run: cd emby-theater-pi electron .Or you can navigate to /emby-theater-pi/ and run start.sh. I also decided to make a desktop icon to launch emby. You can do this by creating a text file on the desktop named 'emby.desktop' with the text: [Desktop Entry] Name=Emby Type=Application Comment=Start Emby Theater Categories=Application Exec=/home/pi/emby-theater-pi/start.sh Terminal=false StartupNotify=false Icon=/home/pi/emby-theater-pi/icon.icoAs a work-around to the issue with dark video: If you edit /emby-theater-pi/playbackhandler/playbackhandler.js And change "var args = ["--alpha", "80"];" the value is a number between 0 and 254. 0 being completely black, and 254 the controls aren't visible over the video. I find 200 to be pretty good. I actually find this to be a handy feature. The tv I'm using is far too bright in a dim room. Edit: If you need audio to play from the analog output instead of only the hdmi, open the file 'playbackhandler.js' and directly after: var args = ["--alpha", "180"]; Add the lines: args.push("--adev"); args.push("both"); Edited April 26, 2018 by darkassassin07 3
darkassassin07 674 Posted April 11, 2018 Posted April 11, 2018 (edited) I know some people avoid the pi as a emby client because you have to manually start theater once the pi boots. A solution for the time being: In a terminal on your pi once you have theater installed and running: cd /home/pi/.config/lxsession/LXDE-pi sudo nano autostart At the bottom of this file add: @xset s off @xset -dpms @xset s noblank @/usr/local/bin/electron /home/pi/emby-theater-pi Once you have done this, emby theater will start when the pi boots and you can then control it via another emby client (like android). No need for a mouse / keyboard, or any other hardware for that matter. Because of the lack of audio via analog out, im using the web app atm via chromium. To auto start that add this to the file instead: @chromium-browser --start-fullscreen http://<your server url here> Edited April 11, 2018 by darkassassin07
tdiguy 99 Posted April 11, 2018 Posted April 11, 2018 I finally got a chance to test this but something must be off. After i type electron . cec-client or electron . i get a black screen and the only thing that shows up is the mouse cursor. I let it sit like this for 2 minutes before i figured nothing was going to happen. Are there logs or something i can look at?
cybergrimes 93 Posted April 11, 2018 Posted April 11, 2018 (edited) I just installed Raspian (Stretch w/Desktop) on a Pi3 I had laying around, ran the update commands but keep getting 'unable to locate package' when trying to install npm never mind, ran sudo apt-get update again and it's installing npm now Edited April 11, 2018 by cybergrimes
darkassassin07 674 Posted April 11, 2018 Posted April 11, 2018 Added a second update line to my instructions. I think I had ended up doing that twice as well.
cybergrimes 93 Posted April 11, 2018 Posted April 11, 2018 Up and running! No grid guide for live TV?
Luke 42239 Posted April 12, 2018 Author Posted April 12, 2018 Up and running! No grid guide for live TV? Are you not able to locate it?
cybergrimes 93 Posted April 12, 2018 Posted April 12, 2018 No, I tried changing the display from desktop / TV & horizontal/vertical. I didn't see any change between horizontal/vertical, maybe I'll try restarting the app to see if that helps the layout update
tdiguy 99 Posted April 12, 2018 Posted April 12, 2018 I know some people avoid the pi as a emby client because you have to manually start theater once the pi boots. A solution for the time being: In a terminal on your pi once you have theater installed and running: cd /home/pi/.config/lxsession/LXDE-pi sudo nano autostart At the bottom of this file add: @xset s off @xset -dpms @xset s noblank @/usr/local/bin/electron /home/pi/emby-theater-pi Once you have done this, emby theater will start when the pi boots and you can then control it via another emby client (like android).No need for a mouse / keyboard, or any other hardware for that matter. Because of the lack of audio via analog out, im using the web app atm via chromium. To auto start that add this to the file instead: @chromium-browser --start-fullscreen http://<your server url here> Not sure if this is normal or not but for me to install electron without errors i had to use: sudo npm -g install electron@1.4.16 --unsafe-perm=true --allow-root I am re-running my install since i cant figure out why running ET just gives me a black screen. Ran out of time to test it tonight but now everything installed without errors.
darkassassin07 674 Posted April 12, 2018 Posted April 12, 2018 That's odd, using the instructions above I had no errors during installation, and haven't had any issues with a black screen.
