denz 501 Posted October 5, 2017 Posted October 5, 2017 Good luck with that it would be helpful to hear your experience with xdotool. I only managed to map few keys with keymap.
Luke 42239 Posted October 30, 2017 Author Posted October 30, 2017 To @@denz and our other international friends, there's a new display setting that will allow you to have a separate datetime format setting from the display language. Enjoy.
Luke 42239 Posted November 25, 2017 Author Posted November 25, 2017 You'll notice the movie list and tv list screens have a new 3-dot button. this is the beginnings of a view menu for that screen that will allow you to customize and make it your own. the settings will be saved on the server which means they will work across multiple installations. For example @@AdrianW, you'll be able to hide the movie titles from under the posters if that's what you prefer. Enjoy.
rechner123 12 Posted December 23, 2017 Posted December 23, 2017 (edited) Hi Today i tried my first emby setup on rpi. I have the same problem with the dark picture as cbradley69 described. I have a very dark picture when using omxplayer on a Raspberry pi 3. Everything looks great using the HTML5, but i'd rather use the app. I have my back light maxed out and it's still very dark. Any suggestions? Also i have not a smooth interface. Rpi 3 Is there something i can do? Edited December 23, 2017 by rechner123
miniz98 73 Posted December 23, 2017 Posted December 23, 2017 Im installing on my raspberry and i get to the step installing electron and i get this error sudo npm -g install electron npm ERR: 404 not found how do i fix. Thanks
rechner123 12 Posted December 23, 2017 Posted December 23, 2017 To resolve the issue of installing electron on the latest version of raspbian 2017-04-10 there is a script that will update nodejs, NR and npm (for NR): Once you run this script you should be able to install electron. It worked for me on a PI3. update-nodejs-and-nodered Im installing on my raspberry and i get to the step installing electron and i get this error sudo npm -g install electron npm ERR: 404 not found how do i fix. Thanks This worked for me
miniz98 73 Posted December 23, 2017 Posted December 23, 2017 Thanks a million that worked should be in the instructions thanks again.
rechner123 12 Posted December 24, 2017 Posted December 24, 2017 Have anyone a solution for me because of the dark screen?
rechner123 12 Posted December 27, 2017 Posted December 27, 2017 Because of dark picture playing, can anybody help me? Is there some setting i can do?
rechner123 12 Posted December 27, 2017 Posted December 27, 2017 As cbradley wrote in post 286. I think it is the same problem. My picture while playing the video, is too dark. The emby interface is normal.
latinumking 7 Posted January 4, 2018 Posted January 4, 2018 I did order my first Raspberry (Model 3B), as I want to use it for Emby Theatre purposes as well. Is there in the meantime a new client available or do I have go to through this thread? Cheers, Lati
denz 501 Posted January 4, 2018 Posted January 4, 2018 You have to go through much longer thread in emby theater called emby theater for linux 1
latinumking 7 Posted January 7, 2018 Posted January 7, 2018 (edited) I got my raspberry 3B, I did install on latest raspbian stretch dated 29.11.17. In order to get electron running, I needed to run update-nodejs-and-nodered (thanks to Rechner123) I suggest that this information will be amended in the install instruction of the first posting. I am able to run emby theater, (without the cec hdmi support), but I also encounter very dark display, it looks like brightness has been reduced by 50%. Can someone help me on that one? I would appreciate to have a real emby theater client for raspberry in the future. (wish list :-) ) Edited January 7, 2018 by latinumking 1
Luke 42239 Posted January 7, 2018 Author Posted January 7, 2018 Is the darkness only during video playback?
latinumking 7 Posted January 7, 2018 Posted January 7, 2018 Is the darkness only during video playback?Yes, only in video playback.If a movie stops, the darkness is gone. I found that chromium emby does not have it, but playback stops and hangs. This does not happen in the playback of the client. Gesendet von meinem MI MAX 2 mit Tapatalk
mookiie2005 0 Posted January 7, 2018 Posted January 7, 2018 Hello I am getting stuck when trying to run the command: sudo npm -g install electronI get the below errors:ERR: 404 /use/bin/node.js /user/bin/npm -g install electron "types/nodes" is not in the npm registry.error code: E404 node -v 4.8.2 npm -v 1.4.21 please help!
rechner123 12 Posted January 7, 2018 Posted January 7, 2018 This should help update-nodejs-and-nodered https://emby.media/community/index.php?/topic/42760-emby-theater-on-raspberry-pi/?p=460655 1
latinumking 7 Posted January 10, 2018 Posted January 10, 2018 This should help update-nodejs-and-nodered https://emby.media/community/index.php?/topic/42760-emby-theater-on-raspberry-pi/?p=460655 Is there a plan or a time schedule how to proceed on the darkness issue or the further development of an official emby theatre client for rasbian? I'm sure there are a couple of guys outside looking forward to this. Smile. Regards out of cold Switzerland Gesendet von meinem MI MAX 2 mit Tapatalk
rechner123 12 Posted January 14, 2018 Posted January 14, 2018 Anyone who could help because of the dark picture please?
Luke 42239 Posted January 14, 2018 Author Posted January 14, 2018 have you tried pulling down the latest updates?
rechner123 12 Posted January 14, 2018 Posted January 14, 2018 have you tried pulling down the latest updates? Hi How can i do this? As described in first post: git clone https://github.com/MediaBrowser/emby-theater-pi.git ? Thanks
denz 501 Posted January 15, 2018 Posted January 15, 2018 you type git pull but it hasn't been updated since March i wish i could use this version one again as it supports deinterlacing but for some reason the dark overlay does not disappear.
rechner123 12 Posted January 15, 2018 Posted January 15, 2018 it hasn't been updated since March ok thank you, but i have installed this on december. so i there is no update for me
