pedulla 0 Posted December 20, 2016 Posted December 20, 2016 I have a legacy HDHR-US with the latest firmware installed. It looks like this version doesn't support the new JSON interface to schedule direct. I have been using this for years with mythtv via the older SD-DD (XML) service. I was looking to move from mythtv to emby, but I have been unable to get the schedule interface working. Does emby support the SD-DD interface? Thanks for any help! Logs follow: 2016-12-19 21:29:28.7623 Info ServerManager: Sending web socket message ScheduledTaskEnded2016-12-19 21:29:28.7623 Info TaskManager: ExecuteQueuedTasks2016-12-19 21:29:28.9395 Info HttpServer: HTTP GET http://192.168.1.11:8096/emby/LiveTv/Info. UserAgent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Ubuntu Chromium/53.0.2785.143 Chrome/53.0.2785.143 Safari/537.36 2016-12-19 21:29:28.9395 Info HttpServer: HTTP GET http://192.168.1.11:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Ubuntu Chromium/53.0.2785.143 Chrome/53.0.2785.143 Safari/537.36 2016-12-19 21:29:28.9592 Info HttpClient: Checking for cache file /var/packages/EmbyServer/target/var/cache/httpclient/13ad2eb1271be1def06488155cc6d89b2016-12-19 21:29:28.9613 Info HttpClient: HttpClientManager GET: http://192.168.1.54/tuners.html2016-12-19 21:29:28.9685 Error HttpClient: Error getting response from http://192.168.1.54/tuners.html *** Error Report *** Version: 3.0.8500.0 Command line: /var/packages/EmbyServer/target/server/MediaBrowser.Server.Mono.exe -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe Operating system: Unix 3.10.77.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/packages/EmbyServer/target/var Mono: 4.6.1 (Stable 4.6.1.5/ef43c15 Mon Oct 17 22:24:51 CST 2016) Application Path: /volume1/@appstore/EmbyServer/releases/v3.0.8500/MediaBrowser.Server.Mono.exe One or more errors occurred. System.AggregateException at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <1170fb08300b4d0db71c1d1db8555768>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>d__20.MoveNext () [0x00377] in <a23c0a9d5681469e972438ec14840d10>:0 InnerException: System.Net.WebException The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <59be416de143456b88b9988284f43350>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <1170fb08300b4d0db71c1d1db8555768>:0 2016-12-19 21:29:28.9769 Error App: Error getting tuner info *** Error Report *** Version: 3.0.8500.0 Command line: /var/packages/EmbyServer/target/server/MediaBrowser.Server.Mono.exe -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe Operating system: Unix 3.10.77.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/packages/EmbyServer/target/var Mono: 4.6.1 (Stable 4.6.1.5/ef43c15 Mon Oct 17 22:24:51 CST 2016) Application Path: /volume1/@appstore/EmbyServer/releases/v3.0.8500/MediaBrowser.Server.Mono.exe One or more errors occurred. MediaBrowser.Model.Net.HttpException at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>d__20.MoveNext () [0x00612] in <a23c0a9d5681469e972438ec14840d10>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <1170fb08300b4d0db71c1d1db8555768>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsync>d__17.MoveNext () [0x0009f] in <a23c0a9d5681469e972438ec14840d10>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <1170fb08300b4d0db71c1d1db8555768>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<Get>d__14.MoveNext () [0x0006f] in <a23c0a9d5681469e972438ec14840d10>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.TaskAwaiter`1[TResult].GetResult () [0x00000] in <1170fb08300b4d0db71c1d1db8555768>:0 at MediaBrowser.Server.Implementations.LiveTv.TunerHosts.HdHomerun.HdHomerunHost+<GetTunerInfos>d__16.MoveNext () [0x00154] in <d11e7966dee843669f858dd23d499955>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <1170fb08300b4d0db71c1d1db8555768>:0 at MediaBrowser.Server.Implementations.LiveTv.TunerHosts.HdHomerun.HdHomerunHost+<GetTunerInfos>d__17.MoveNext () [0x000d8] in <d11e7966dee843669f858dd23d499955>:0 InnerException: System.AggregateException One or more errors occurred. at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <1170fb08300b4d0db71c1d1db8555768>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <1170fb08300b4d0db71c1d1db8555768>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>d__20.MoveNext () [0x00377] in <a23c0a9d5681469e972438ec14840d10>:0 InnerException: System.Net.WebException The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00064] in <59be416de143456b88b9988284f43350>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00014] in <1170fb08300b4d0db71c1d1db8555768>:0
Luke 42237 Posted December 20, 2016 Posted December 20, 2016 Hi, not at this time. It's a possibility for the future.
