jimboz333 1 Posted January 27, 2014 Posted January 27, 2014 How do I get to play games on the emulator? I downloaded the plugin and the image file that came with it. How do I get square box? I know this one has been answered. It the only major difference the color and style?
BATTLE DONKEY 98 Posted January 28, 2014 Posted January 28, 2014 Ur gonna have to be more specific, what exactly have u done. Have u installed a nes emulator and have actual ROMs on ur pc? Does it work properly outside the MB environment? And have u configured the emulator and ROMs in both the server configuration and MBClassic and/or MBTheatre? Ur question is very vague so its kind of hard to give u a proper answer or any sort of help. Please check the post on how to report a problem and give more details on what exactly the problem is so we can work out what the issue is.
jimboz333 1 Posted January 29, 2014 Author Posted January 29, 2014 Battle, Thanks for the input. I had no idea I needed to do any of that. Nor, do I know if I have. I have not tried to use the rom's any where else, and i think I only downloaded the emulators that came from here. I did not configure theater. I havn't used it. Thanks for your patience in all of this. I guess a better question for me to ask, is there an instruction sheet on how to set this up?
BATTLE DONKEY 98 Posted January 29, 2014 Posted January 29, 2014 http://mediabrowser.tv/community/index.php?/topic/2720-gamebrowser-3-plugin/?fromsearch=1 Also what do u mean u downloaded the emulators from here? Do u mean NESbox and SNESbox? If so, those aren't necessarily emulators, what they do is link ur physical ROMs library to the NESbox website which allows u to play ur games from any compatible web browser
