maegibbons 1287 Posted December 19, 2016 Posted December 19, 2016 Hi Any reason why the custom ffmpeg path has been removed on Ubuntu 16.04? The stock version is quite old but working. However, it may be better to choose a later version. Krs Mark 2
maegibbons 1287 Posted December 21, 2016 Author Posted December 21, 2016 @Luke Any comment on the above please? Krs Mark
Luke 42244 Posted December 21, 2016 Posted December 21, 2016 It's decided on a per platform basis. The package for your distro is specifically specifying a particular version, and when this happens, the server currently assumes it should not be customized.
sualfred 677 Posted December 24, 2016 Posted December 24, 2016 (edited) It's decided on a per platform basis. The package for your distro is specifically specifying a particular version, and when this happens, the server currently assumes it should not be customized. Luke, my Debian only ffmpeg 2.2.1 installed and I have to set a custom path to 3.1.6 to get ffmpeg working with the UWP Emby Theater version. But with the missing setting it's not possible anymore. Is there any config where I can hardcode the path? encoding.xml has a <EncoderAppPath> value, but it seems to be ignored. Edit: Uninstalling the system ffmpeg makes it appear again. Please consider adding this setting back. Edited December 24, 2016 by sualfred 1
SuperCurro 4 Posted December 24, 2016 Posted December 24, 2016 (edited) I have the same problem due to android app problems. I have downgrade, make and compilate the FFmpeg 3.1.6 "Laplace" versionhttps://ffmpeg.org/download.html#releases cd ffmpeg-3.1.6 ./configure --disable-yasm sudo make sudo make install man ffmpeg ffmpeg ffmpeg version 3.1.6 Copyright © 2000-2016 the FFmpeg developers built with gcc 5.4.0 (Ubuntu 5.4.0-6ubuntu1~16.04.4) 20160609 configuration: --disable-yasm libavutil 55. 28.100 / 55. 28.100 libavcodec 57. 48.101 / 57. 48.101 libavformat 57. 41.100 / 57. 41.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 47.100 / 6. 47.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 1.100 / 2. 1.100 Hyper fast Audio and Video encoder usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}... but I can not set encoder apppath Now I will tray to uninstall the default package... but this make thing less easier. Edited December 24, 2016 by SuperCurro 1
n0ne 0 Posted December 28, 2016 Posted December 28, 2016 To use a different ffmpeg you can change the PATH in /etc/emby-server.conf: PATH=/usr/local/bin:$PATH I have ffmpeg and ffprobe in /usr/local/bin and this PATH will make emby choose those over the ones in /usr/bin
Luke 42244 Posted December 29, 2016 Posted December 29, 2016 if you are on the dev or beta branches it should be coming back in upcoming updates. thanks.
