fuzzthekingoftrees 10 Posted December 18, 2016 Posted December 18, 2016 Just got the latest Emby update on my Fire TV. On the whole it's great, everything now direct plays no transcoding required. Only problem I've noticed is on videos with an ac3 audio track. When the VLC player is chosen audio is downmixed and passed as stereo PCM. If I click the button to say that audio or video is not working, the app switches to the internal player and the ac3 is bitstreamed to my amp. Is the VLC player capable of passing ac3 to the amp on a fire TV? If not then can the app send the stream as multichannel PCM? This works fine for videos with a DTS track. Mediainfo for a file I'm having problems with below, but this seems to affect anything with ac3. VideoCodec H264AVC YesProfile HighLevel 31Resolution 720x384Aspect ratio 15:8Anamorphic NoInterlaced NoFramerate 25Bitrate 1976 kbpsBit depth 8 bitPixel format yuv420pRef frames 10NAL 4 AudioLanguage engCodec AC3Layout 5.1Channels 6 chBitrate 448 kbpsSample rate 48000 HzDefault Yes
ebr 16339 Posted December 18, 2016 Posted December 18, 2016 When you force it into the internal player isn't it also transcoding?
fuzzthekingoftrees 10 Posted December 18, 2016 Author Posted December 18, 2016 I don't think so. I think it starts off as Direct/V then switches to Direct/I then if I press again it goes to Trans/I. I'll check next time I'm in front of the TV and I'll let you know.
fuzzthekingoftrees 10 Posted December 21, 2016 Author Posted December 21, 2016 I've watched a few things over the past few days. For videos with ac3 audio it's always Direct/V which is output as downmixed stereo PCM. If I press the ! button it switches to Direct/I which plays fine with ac3 passthru. If I press ! again it goes to Trans/I.
fuzzthekingoftrees 10 Posted January 6, 2017 Author Posted January 6, 2017 Any thoughts on why this doesn't work with VLC?
ebr 16339 Posted January 6, 2017 Posted January 6, 2017 Any thoughts on why this doesn't work with VLC? Bitstreaming of AC3 through libVLC on the Fire simply isn't supported. Are you sure you're getting stereo PCM though and not 5.1 PCM? The release that is going out now will favor the Google player with AC3 tracks in order to bitstream them.
fuzzthekingoftrees 10 Posted January 6, 2017 Author Posted January 6, 2017 Yeah it's definitely stereo PCM on my amp. If I play a video with 5.1 DTS then I get 5.1 PCM.
greenlava 2 Posted January 19, 2017 Posted January 19, 2017 I'm seeing this same problem, 1st gen firetv(box) with VLC from amazon app store. hitting the '!' icon makes audio work, while still appearing to direct stream. Is there a way to make this the default?
ebr 16339 Posted January 19, 2017 Posted January 19, 2017 I'm seeing this same problem, 1st gen firetv(box) with VLC from amazon app store. hitting the '!' icon makes audio work, while still appearing to direct stream. Is there a way to make this the default? What version of the app (please don't say 'latest' the version is displayed in the settings page)? Whatever VLC you installed separately is not related to our playback (unless you set it up to use an external player).
greenlava 2 Posted January 23, 2017 Posted January 23, 2017 (edited) sorry, I mis-reported when I try to direct stream though VLC, I get picture but no audio. when i click the 'I', it switches to Trans/V (if i recall correctly), so OP and I are not seeing the same problem, I think. Sorry to thread-jack. I'll troubleshoot some more and open my own thread if needed. Edited January 23, 2017 by greenlava
