xunix 0 Posted December 18, 2016 Posted December 18, 2016 Hi Guys . I have problem, couldn't encode audio with video at the same time by using ffmpeg This my avs script ( I tried both of them ) V= FFvideoSource("Detective_Conan.mkv") A = FFAudioSource("Detective_Conan.mka") AudioDub(V,A) trim(0,400) FFmpegSource2("Detective_Conan.mp4",atrack=-1) trim(0,400) and this's the command line avs2yuv 842.avs - | ffmpeg -y -i - -c:v libx264 -c:a aac -b:a 128 output_.mp4 the result is video without audio.
Waldonnis 148 Posted December 18, 2016 Posted December 18, 2016 While I love AviSynth for a lot of things, it looks like an operation that would be more easily done with just ffmpeg. You're passing the output to ffmpeg anyway and it's just remuxing to add an audio stream. Specifying the video and audio files as inputs, then using the appropriate -map options should work just fine. That being said, do either of the scripts play properly (with audio), out of curiosity? Also, I don't think avs2yuv handles audio, as it was intended to be used with video-only encoders like x264. ffmpeg should be able to take avs files as inputs (at least on Windows it does), so you can try that as well.
Luke 42241 Posted December 18, 2016 Posted December 18, 2016 Hello and welcome ! We love talking encoding and codecs.
