jmassaro87 28 Posted December 22, 2016 Author Posted December 22, 2016 (edited) What file does it point to? It launches Emby Server. And now that installed Theater there is one for that as well edit: C:\Users\HTPC\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Edited December 22, 2016 by jmassaro87
Luke 42197 Posted December 22, 2016 Posted December 22, 2016 so when your machine boots up, just login as the HTPC user and it will start Emby Server.
jmassaro87 28 Posted December 22, 2016 Author Posted December 22, 2016 (edited) so when your machine boots up, just login as the HTPC user and it will start Emby Server. Thats how it has been running for a long time, recently i now have to launch server manually. and it will become much more annoying if i am using theater for live tv as well. edit: do we think an uninstall and reinstall might help? Edited December 22, 2016 by jmassaro87
Sammy 790 Posted December 23, 2016 Posted December 23, 2016 Is there a shortcut for Emby in your startup folder C:\Users\HTPC\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup Maybe this is what I was thinking when I said there was two servers...
Sammy 790 Posted December 23, 2016 Posted December 23, 2016 (edited) I believe this log is from the last time I rebooted and I had to manually start Emby Server. server-63617775678.zip Edited December 23, 2016 by Sammy
Solution Luke 42197 Posted December 23, 2016 Solution Posted December 23, 2016 So try deleting both shortcuts. 2
Sammy 790 Posted December 23, 2016 Posted December 23, 2016 So that will force Emby Server to create a new one and only one?
Sammy 790 Posted December 27, 2016 Posted December 27, 2016 I did this and behavior is as expected as far as putting only one shortcut into the start up folder. I didn't reboot to test it out because I had no other reason to reboot and don't reboot unless absolutely necessary. I will report back whether on not the Emby Server loads when I have to reboot.
Magic815 18 Posted January 2, 2017 Posted January 2, 2017 I might be having a similar issue with Emby server starting on Windows startup (I'm on Windows 8.1). It's been working great for about 4 months now, but as of a couple days ago, I noticed that the service does not start up automatically. In 'Settings' I have 'Run Server at Startup' checked. However, I don't currently have a shortcut to Emby in the Windows startup folder (and can't remember if I ever did). Do I need to manually make a shortcut to the startup folder in addition to having the setting checked?
Happy2Play 9802 Posted January 2, 2017 Posted January 2, 2017 (edited) Are you wanting the service to start automatically or the server to run at startup/login? Edited January 2, 2017 by Happy2Play
Magic815 18 Posted January 2, 2017 Posted January 2, 2017 Are you wanting the service to start automatically or the server to run at startup/login? I guess I didn't realize those were two different things? My goal is to have Emby always running on my computer. To me that means to automatically turn Emby server on when my computer is started up - does it not?
Happy2Play 9802 Posted January 2, 2017 Posted January 2, 2017 (edited) Well one requires a user to login and the other runs in the background without any user intervention needed. Sounds like you want to run as a service. Uncheck the "Run server at startup" option then shutdown server. In Windows you want to open the Services, find Emby Server on the list and open it, change startup type from Manual to Automatic (Delay Start) click ok, then select "start" service. Edited January 2, 2017 by Happy2Play
ebr 16309 Posted January 2, 2017 Posted January 2, 2017 And be sure to configure proper credentials for the service so that it can access your media.
Sammy 790 Posted January 6, 2017 Posted January 6, 2017 Although this has been marked as solved already, I know you guys like feedback.. Something happened last night when streaming to my tablet tethered to my phone hotspot via LTE, which worked great BTW. At any rate I had a crash and it crashed my HTPC at home. I haven't checked the logs yet but I'm thinking it wasn't related to Emby as before I left there were network issues and my wife had to reset the modem and router with my instructions via text.. She's a trouper and wants to learn! So things may have been a little unstable on the Server machine but I'll check the logs when I get a chance.. Now that the background has been set I want to report back to @@Luke and @@ebr that after all this I was forced to reboot. Emby Server Loaded on boot as expected. I suppose having that old Media Browser Server short cut in the Startup directory was the issue. Thanks for the support on sorting that out, Luke! Keep up the good work! 1
