zgarretson 0 Posted December 18, 2016 Posted December 18, 2016 Done some searching but can't seem to find an answer. Has anybody figured out a shortcut for skipping chapters with a Harmony remote on the Shield? Using mcebuddy to mark chapters for commercials and this is the only thing stopping me from switching over completely from Kodi.
ebr 16337 Posted December 18, 2016 Posted December 18, 2016 No, there are no shortcuts for this because none of the device remotes have buttons for it so almost no one would be able to take advantage of them. You can access the chapters from the OSD though and, when you bring them up during playback, it will automatically scroll you to the proper chapter so you would just need to move over one and select it.
zgarretson 0 Posted December 18, 2016 Author Posted December 18, 2016 Gotcha. Guess I'm spoiled with Kodi's remote mapping where the up on the d-pad moves to next chapter. I'll try to build a macro in the Harmony software to select the next chapter in Emby.
