wyerd 11 Posted December 17, 2016 Posted December 17, 2016 (edited) I'm just finishing off the settings to get Emby up and running after migrating over from the old version, but I'm having problems getting the External Player working correctly. With the previous version I used the command arguments:- {path} -termend -nl -ol:AMD Stereoscopic Play then ran the selected 3D file in full screen. Now all I get is Emby minimising and Stereoscopic Player opening in Window mode without playing the file. Any ideas what the issue could be? I've also tried searching for the External Player XML file but I'm unable to find it. Edited December 17, 2016 by wyerd
wyerd 11 Posted December 18, 2016 Author Posted December 18, 2016 Figured it out. I needed to add -file: before {path} so the arguments now look like:- -file:{path} -termend -nl -ol:AMD 1
