thiagomnk 0 Posted December 16, 2016 Posted December 16, 2016 I've done more than once and downloaded more than once the same file and so far so the error when I go to apply the folder path, I knew it was too easy hehehehkkkk someone a light with this error??
Luke 42244 Posted December 16, 2016 Posted December 16, 2016 Also try pointing to the ffmpeg application path.
Guest plexman Posted December 16, 2016 Posted December 16, 2016 (edited) If you are on Ubuntu 16.04 install ffmpeg from repository: sudo add-apt-repository ppa:jonathonf/ffmpeg-3 sudo apt-get update sudo apt-get install ffmpeg Then point emby to the ffmpeg installation /usr/bin/ffmpeg Edited December 16, 2016 by plexman
